02-11-2024, 10:24 AM | #1 |
BMW X5M (F85) & BMW M5 (E60)
15
Rep 14
Replace Parking Brake Switch
Has anyone had to change their own Parking Brake Switch in the center console? How difficult is it? Looking for any quick tips. Mines cracked and Im worried it will soon crumble apart. Thanks in advance.
02-11-2024, 03:48 PM | #2 |
Rep 2,665
Drives: Goggomobil
I haven't yet, but it is very easy. On the weekend I removed the console to replace the idrive with the ceramic part and it is easy. Just pull the top trim with your hand slowly and underneath everything just unscrewing and putting it together. Just be careful when removing the connectors especially the one for the /// settings. Good luck.
F86 X6///
02-12-2024, 01:23 AM | #3 | |
Rep 503
I purchased the entire switch new and replaced it. The reason I did replace it was because the actual lever was scratched and it bothered the hell out of me. I tried changing just the lever and ended up cracking one side of the clip inside that holds the lever. At that point I put it back and ordered the entire assembly. It took me a few hours being careful not to break anything important. I’ll look for the picts so I can post them for you. Hopefully it will help. I’m trying to recall what I did after I installed it because I did have a few error codes but I believe they cleared themselves after turning the car of and back on. I may have drove around the Neighborhood after making sure that the brake worked in my parking spot.
2018 X5M- Black Sapphire Edition
02-12-2024, 01:57 AM | #4 |
Rep 503
Found some images. I hope this helps to some extent. Be careful once you remove the cover. If I recall correctly do not pull the cover completely off once you snap it out. There are cables attached to it.
