08-19-2024, 03:54 PM | #1 |
Rep 41
2017 F85 - Suspension (Thrust Rod / Lower Wishbone / Control Arm) Issue
Hi everyone, I recently went to the dealership because I had to get an oil change and let the advisor know that I had been recently hearing a little screeching type of sound from the front wheels when turning the wheels at slow speeds and when i first start the car up after a while. For $179 they took a look and shared a $4700 estimate. I have attached both the estimate as well as the service advisor's video showing the issue:
Both files can be found here as well: https://workdrive.zohoexternal.com/e...32d5664539ad8f I was just hoping for a second opinion from someone here who would be more knowledgable than I am. Basically is the repair needed and is the price reasonable? I was already planning on selling the car before the end of the year anyways, but now this came up. Any insight or advice would be greatly appreciated. Thank you!
2012-2020: 2011 Infiniti G37 Sedan
2020-Present: 2017 BMW X5 M |
08-19-2024, 04:10 PM | #2 |
Rep 2,727
Drives: e92 + f15
Brutal quote mainly in terms of labor costs. Do you have a euro indy shop that you trust in the area?
I'd suggest ordering the parts (you have the part numbers in the quote) from FCPEuro, and bringing them to a euro/BMW indy shop. Each part looks like it has a 20% markup + what I assume quoted 6+ hours for control arm install? |
08-20-2024, 07:43 AM | #3 |
Rep 425
From what I've gathered these are pretty common failure points. Feel like endless people here have changed the lower control arms. I have't done it yet, but I think there are way less expensive replacement parts. Either OEM or Lemforder. A quick search and you can get OEM Thrust arms and lower control arms for $1000 less than the quote.
08-20-2024, 10:18 PM | #5 |
Rep 784
Do you ever do work on your own car? If so, it is a REALLY easy job to change out the lower control arms and front thrust arms. I just did mine a week and a half ago. Only special tool you’ll need is a 27mm wrench, and a 27mm 12pt socket is helpful for removal.
I put it up on jackstands and had at it. Remove the control arm first and then the thrust arm can be removed by rotating it towards the rear of the vehicle to clear the axle boot. When installing don’t tighten the inner bolts/nuts fully, just snug them up. The outer ball joint you can go ahead and tighten with the wrench and I think 6mm allen as a counter hold. Then with the weight of the car on the wheel on a rhino ramp (or you can jack up the front suspension) you can torque the inner bolts/nuts. They need to be torqued at ride height. |
08-21-2024, 07:38 AM | #6 | |
Rep 425
08-21-2024, 09:36 AM | #7 |
Rep 784
Yeah, it’s relatively easy…not complex at all, only difficulty is on jackstands there’s not a lot of room to get good leverage on the bushing nuts/bolts to loosen and tighten. And make sure to have a good size hammer to knock the ball joints out of the hub. Lol
08-22-2024, 06:19 PM | #9 |
Rep 784
Ha yeah, you definitely need a hammer with some a$$ behind it. Using a regular hammer was a no-go, I used a 3lb Fiskar isocore hammer…that got it right out after a couple whacks lol
09-12-2024, 03:53 AM | #10 | |
Rep 1
Tags |
2017, f85, suspension, wishbone, x5m |
