      05-22-2008, 03:38 PM   #1
whiplash
Private No Class
whiplash's Avatar
Drives: Depends on the day
Setting the E-brake after a track session
OK, everybody knows you're not supposed to set the hand-brake after a track session or autocross run or even really 'spirited' driving but I've been thinking about this lately. If the 135 hand-brake is the same as the E36 M3, it doesn't clamp the pads onto the rotor, it has an actual drum brake assembly (with two brakes shoes) inside the rear rotor hat.
Does anybody know if it's the same on the 135? If so, what's the downside of setting the brake after a run? All it does is press the brake shoes against the inside of the rotor hat, nowhere near the hot rotor surface, so it shouldn't cause any warpage.
I sure as heck don't plan to test this theory and will still never set my hand-brake after a track session but the mechanical engineer in me is beginning to wonder if that concept applies to this type of hand-brake set-up?
They followed me home...can I keep them?
Dan in Houston / CCA # 93849
      05-22-2008, 06:40 PM   #2
KRZY1
Drives:
Shouldn't be that hard to see pop the wheel off pull the handle. Should be able to get a view if the pads are moving. Its a good question tho as a lot of cars have the hat/drum setup.
      05-22-2008, 07:34 PM   #3
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
Every modern BMW has drum-in-disc parking brakes.
      05-22-2008, 10:37 PM   #4
Spec Volcanic
Spec Volcanic's Avatar
Drives: 2011 BMW 1M
I still wouldn't set the park brake, you could warp the drum.
      05-22-2008, 11:01 PM   #5
Doolab
Drives: '96 Maxima SE 5MT, '04 MB E500
Yep.
Get yourself on of these, they work very well at the track and when working on the car.
      05-23-2008, 12:03 AM   #6
alexp1_tx
Drives:
Cant you just put the car in First or Revs?
      05-23-2008, 01:07 AM   #7
Spec Volcanic
Drives: 2011 BMW 1M
Originally Posted by Doolab View Post
Yep.
I use a piece of 2 X 4
      05-23-2008, 01:09 AM   #8
Spec Volcanic
Drives: 2011 BMW 1M
Yes and no...
no if you want to let the car run for for a couple of mins before turning it off.
      05-23-2008, 01:42 AM   #9
alexp1_tx
Drives:
Why would you let it run for a couple of min?
      05-23-2008, 01:52 AM   #10
Spec Volcanic
Drives: 2011 BMW 1M
To let oil and coolant circulate after a track session, to help prevent oil from cooking in the turbos, as an example
      05-23-2008, 02:27 AM   #11
Rye
Drives:
That's why you take a cooling lap, no? I could understand if driving local twisties, but on a track, you take a cool-down lap..or 2.
Wheel chocks work nicely also.
      05-23-2008, 08:17 AM   #12
jeremyc74
Drives: '08 135i Montego/Terra
Just an FYI these cars have an after-run oil pump to prevent that.
(I'd probably still do a cool down, but I don't think cooking the oil in the turbos is going to be an issue for us.)
      05-23-2008, 09:34 AM   #13
BMWeber
Drives: 08 135i
I'm not positive but I believe it just runs the coolant not the oil after you shut the car off.
      05-23-2008, 10:39 AM   #14
Spec Volcanic
Drives: 2011 BMW 1M
In the time attacks I run you get one cool down lap, some cars need more.
      05-23-2008, 10:41 AM   #15
Spec Volcanic
Drives: 2011 BMW 1M
just the first example I could think of
      05-23-2008, 02:31 PM   #16
jeremyc74
I'm pretty sure it's the other way around, but I could be wrong. I'll have to dig into it a little.
Edit:
I dug into it and you're right. It's the coolant pump that runs afterwards for cooldown.
Here's what the N54 tech documents say about it:
After-running of electric coolant pump = improved heat dissipation from engine switch off
point. Allows protection of turbochargers by
reduced oil “coking” during heat soak.
Sorry about the thread jack!
1addicts
