      10-05-2024, 10:23 AM   #1
pglover19
Drives: BMW X5
2015 BMW X5M 38k Miles - Check Engine Light On
After filling up with gas yesterday, the check engine light came on. Since we were near a BMW service center, we took the vehicle to the dealership and they checked the gas cap and reset the code. The check engine light disappeared. In addition, the service technican indicated that I needed to drive the car for some miles and start and stop the car for 3 times. That really confused me.
Well this morning, the check engine light (orange color) is appearing again.
What are some things I need to check before taking it back to the dealership? I do have a Peake Research R5 FCX-3 code/reset tool for BMWs. Not sure if it will work on a 2015 BMW X5M.
FYI.. I found this article. I'm wondering if I need to drive the vehicle for 20-40 miles for the light to disappear after retightening the gas cap.
https://www.richmond-bmw.com/bmw-che...xoCbucQAvD_BwE
      10-05-2024, 11:01 AM   #2
Djhumvee
Drives: 2017 X5 50i
Read the code and look it up to see what it is, if the dealer checked a gas cap and reset the code it must have been an eval leak code, mostly like you'll need a smoke test to see what's wrong which it sounds like you won't be able to do yourself..
      10-05-2024, 11:05 AM   #3
pglover19
Drives: BMW X5
Do you know if the Peake Research R5 FCX-3 code/reset tool will work on a 2015 X5M? The tool has the OBD connector.
      10-05-2024, 06:53 PM   #4
pglover19
Drives: BMW X5
Lately the vehicle has been idling rough on start-up. It eventually smooths out as I drive off.
      10-05-2024, 07:26 PM   #5
MBoss_F86
MBoss_F86's Avatar
162
Drives: 2016 BMW X6M
check codes, but it sounds like you need new spark plugs and/or ignition coils. If stock they need to replaced every 40k ish miles. It tuned every 20k miles
      10-05-2024, 07:29 PM   #6
pglover19
Drives: BMW X5
This is a stock 2015 X5M.
Any clue what spark plugs and ignition coils cost if the BMW dealership does the job?
      10-05-2024, 08:15 PM   #7
MBoss_F86
MBoss_F86's Avatar
162
A lot! I wouldn't do it at the dealership. You can get the parts from fcp euro or getbmwparts and have an indi shop do it.
      10-05-2024, 08:19 PM   #8
pglover19
Drives: BMW X5
ok. Would the Peake code scanner tell me if the issue is spark plugs or coil?
      10-05-2024, 08:27 PM   #9
MBoss_F86
MBoss_F86's Avatar
162
Not sure, never used it. You can always go to Autozone or Pepboys and they will scan codes for free
      10-05-2024, 08:29 PM   #10
pglover19
Drives: BMW X5
ok. I will test the Peake scanner once my wife returns home tonight and let you know what I discover.
      10-05-2024, 08:38 PM   #11
Djhumvee
Drives: 2017 X5 50i
IDK why it wouldnt
      10-05-2024, 10:10 PM   #12
pglover19
Drives: BMW X5
Unfortunately, the Peake scanner tool does not work on a 2015 X5M. I'm getting a flashing error code of "E10" from the tool. E10 means "communication error".
      10-06-2024, 07:19 PM   #13
Chilled
Chilled's Avatar
Australia
592
Drives: F85 X5M
You are probably going to need something that was made in the last decade.
Allot of people are going for something like a wifi adapter with android/iphone software. Something like a HMD universal/modBMW adapter with Bimmerlink/HMD Tuning (reads codes for free, thnx MHD) or any other app that uses wifi. ISTA does work with these wifi adapters.
      10-06-2024, 07:21 PM   #14
pglover19
Drives: BMW X5
Where can I purchase this software and adapters?
      10-06-2024, 07:35 PM   #15
Chilled
Chilled's Avatar
Australia
592
Drives: F85 X5M
For the MDH, here is the vendors site. Just google the name "MHD Universal" and you will get allot of places that resell it. Find the closest to you.
https://mhdtuning.com/pages/mhd-wireless-adapter
MHD App, free to scan codes.
https://play.google.com/store/apps/d...eries&hl=en_US
BimmerLink. - need to pay
https://play.google.com/store/apps/d...rlink&hl=en_US
You also have things like Carly, but i think it needs it's own specific adaper.
      10-06-2024, 07:40 PM   #16
pglover19
Drives: BMW X5
So, this would definitely work for a 2015 BMW X5M?
      10-07-2024, 07:50 AM   #17
MBoss_F86
MBoss_F86's Avatar
162
This will work very well - https://www.amazon.com/gp/product/B0...TSRUAKKQ&psc=1
      10-07-2024, 10:16 AM   #18
Qsilver7
Qsilver7's Avatar
Are you sure you connected and used the tool you have correctly? Only asking since the CEL (check engine light) illuminates due to a fault code set by something in the vehicle's emissions system...and OBD II goes back to 1996 in the USA. Any generic tool should still be able to pull a DTC (diagnostic trouble code) set by the vehicles OBD II system.
Perhaps tell us what you are doing when you connect the tool. Are you turning the ignition on (pressing the START button with foot OFF the brake pedal) prior to trying to get the tool to retrieve the fault code data?
Again, make sure you're connecting & using the tool correctly for retrieving OBD II fault codes.
FYI..I have an old Autel Maxiscan MS300 OBD II scanner that I've had since my old e38/e39/e53 (1997/1998/2006) days...and it still works on my 2014 F15 X5 50i & 2015 F06 650ix GC to pull generic DTC (aka 5 digit "P" codes).
      10-07-2024, 10:36 AM   #19
Qsilver7
Qsilver7's Avatar
Before throwing money at coils & plugs...find out which sensors set the fault codes. This will send you in the direction of what needs to be diagnosed. Once you pull the 5 digit "P" code or 6 digit BMW hex code...google it or go to this website and select your engine (if there are multiples listed) and see if there's any info as to what may be the cause and/or a solution: https://bmwfault.codes/
      10-07-2024, 11:02 AM   #20
pglover19
Drives: BMW X5
The dealer has diagnosed a bad oxygen sensor and misfires on a number of banks.
      10-07-2024, 12:45 PM   #21
pglover19
Drives: BMW X5
Would constant misfires cause a bad oxygen sensor, or would a bad oxygen sensor cause misfires?
I ended up replacing the bad oxygen sensor and the spark plugs. Not cheap at the dealership.
      10-07-2024, 05:57 PM   #22
Chilled
Chilled's Avatar
Australia
592
Drives: F85 X5M
In short yes.
Yes.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
