      07-30-2008, 09:38 PM   #1
pkcormier
Drives: 135i
Anyone installed new pads on 135i?
If someone wanted to ... say... put track pads on for the weekend and buzz around for no good reason, but accidentally find themselves on a race course, how might said person perform a pad replacement on a 135i? Fronts only.
      07-30-2008, 10:33 PM   #2
WhiteOut
Drives:
      07-30-2008, 10:38 PM   #3
WhiteOut
Drives:
      07-31-2008, 12:29 AM   #4
scottn2retro
scottn2retro's Avatar
496
Drives:
We changed pads (put in custom machined race pads from TMS) and definitely did not re-flash the ECU. We did not do anything to disable ABS either.
But we installed pads on all 4 corners.
2015 M4 BMW Club Racer
SCTS Racing
https://www.facebook.com/sctsraceteam/
      07-31-2008, 01:25 AM   #5
emm3tt
Out Driving
emm3tt's Avatar
29
Drives:
Why would you need to reflash the ECU????????
Emmett
01 E46 M3
      07-31-2008, 08:27 PM   #6
WhiteOut
Drives:
      07-31-2008, 10:20 PM   #7
scottn2retro
496
Drives:
Originally Posted by WhiteOut View Post
No idea about why. I have a feeling whoever told me that was incorrect. scottn2retro, wanna give some info about how to change pads? Do the calipers need to come off?
Unfortunately, for whatever reason, BMW had Brembo make a caliper that was not like most of their kits and you do have to remove the front caliper.
Which makes the rears really seem strange, because they do slide out the top after pulling the retaining pins.
SCTS Racing
      08-01-2008, 12:30 AM   #8
WhiteOut
Drives:
      08-01-2008, 07:28 PM   #9
pkcormier
Drives: 135i
I just put in track pads. Not too bad. You have to remove the pins holding the pads in place and remove two 10mm hex bolts holding the caliper to the brake assembly. The pads drop out from the bottom. You'll need to push the pistons back in, install new pads, then reverse. I'm trying the Cool Willy pads from Turner on 8/9. I toasted my stock pads after a track day a couple weeks ago. These pads along with motul brake fluid should do the trick.
      08-01-2008, 10:53 PM   #10
wu2x
wu2x's Avatar
36
Drives: 2011 E90 M3 6MT
Which pads did you end up using?
      08-01-2008, 11:08 PM   #11
pkcormier
Drives: 135i
Cool Willy's. I've never used them before, but choices are limited right now. Got them through Turner. Pricey too. I opted for just the fronts.
1addicts
