      08-29-2008, 08:51 PM   #1
akak1997
akak1997's Avatar
64
Drives: BMW 135 @ 135mph
2008 135i  [0.00]
"Stuff" in the hood leaking out
There some "grease" or "oil" type fluid coming out of 3 holes on the underside of the hood, at the front. I don't know how to describe the consistency of the stuff, it's kinda sticky.
I took some pic:
This one is showing it's leaking out onto the hood:
This one of the "source" of this stuff, not a lot is coming out from this hole tho:
the following 2 pics show the two holes where the hood line begins. these two holes are the Major source of the stuff:
Anyone know what this stuff is? and where it it coming from? There's No sign of this stuff in the engine bay. it seems as if it's from the inside of the hood. What could be in there!? Shall I take it into the dealer?
Thanks
      08-29-2008, 09:08 PM   #2
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Cosmoline used to anti-salt prep the car for its ocean voyage. No worries, other than it's not the easist to remove.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      08-29-2008, 09:52 PM   #3
akak1997
akak1997's Avatar
64
2008 135i  [0.00]
Oh! that's what it is... how come it's "Inside" the hood? they dip the car in that stuff or something!?
I guess now I've to go search on the detailing forum and see how to remove it. Thanks for the help!
      08-29-2008, 10:21 PM   #4
Redbeemer
Ne Plus Ultra
Redbeemer's Avatar
Drives: Portimao Blue 2022 M240iXdrive
Yep, I had the same stuff on the lower lip of my hood near where it meets the headlight and also along the bottom edge of the hood; it could be seen when you opened the hood. Anyway, I didn't know what it was and the stuff on the outside was a concern to me that the paint might be damaged. Anyway, I took it back to the dealer and they took one look at it and said it was cosmoline and called their detail man who had some type of professional paint cleaner and took it right off. It won't hurt the paint, it just looks bad, but will come off with no damage to the paint at all.
      08-30-2008, 01:33 AM   #5
gan08
Drives: Fatty X5 and Pot-bellied 135
couple times i drive over 100 mph... the snot comes out
how fast did you go? :biggrin:
      08-30-2008, 01:52 AM   #6
Oregon
NRA Life Member, BMW CCA 30 year member
Oregon's Avatar
Drives: 04' M3
1971 2002  [0.00]
2004 M3  [0.00]
2008 135i  [0.00]
Hey Akak,
Considering it's summertime, plus, you are in sometimes-hot SoCal, the odds are in your favor, the cosmoline should leach-out in a few weeks. Good luck.
Resigned 1ADDICTS Moderator
“To disarm the people is the best and most effective way to enslave them.” – George Mason
      08-30-2008, 04:30 AM   #7
akak1997
akak1997's Avatar
64
2008 135i  [0.00]
I'm not really going that fast, I'm sure I'm below 100 :P
it's probably just so hot here in SoCal, the comosline becomes more liquidy or something.
Now that I know it's comosline, I'm not worry that it'd damage the paint at all. I mean, they put that stuff there to protect the paint. still. it looks ugly and I'm sure dirt will stick to it real good. gonna have it washed tomorrow.
      08-30-2008, 11:24 AM   #8
1er junkie
Drives:
I just plugged the holes with some paper towel for around a month and replaced the plugs daily. It seemed to do the trick. No dripping anymore
wheels have been sold!
      02-07-2009, 08:37 AM   #9
Carbonic
South Africa
Drives: 135iM
2008 135i Coupe  [0.00]
Its called cavity wax, and is injected / sprayed into all sheet-metal body cavities at the end of the paint process, for corrosion protection, as there is no paint inside these cavities, only e-coat (electrocoat).
Cars which are shipped by sea are also covered with a wax coating, to prevent paint damage as a result of salt spray and other contaminants. The VPCs (Vehicle Processing Centres) then de-wax the cars with a high temperature, high pressure spray. I'm not sure if any solvents or detergents are added.
2008 Alpine White 135iM, High gloss black / satin chrome trim, Xenon lights, Hi-Fi sound, ext. lighting package, BMW Performance wheels, side skirts, pedals, gear knob, exhaust, high gloss black grills, carbon mirrors, carbon decklid spoiler, 35% security laminate, Tii graphics
      07-26-2009, 09:35 PM   #10
emm3tt
Out Driving
emm3tt's Avatar
29
Drives:
Finally figure this out. Very annoying!
Emmett
01 E46 M3
      07-27-2009, 10:10 AM   #11
shawshank772
shawshank772's Avatar
Drives: 08 135i and 16 M3
yeah its annoying...after a year I still have it dripping from my doors and onto my sidskirts.
      07-27-2009, 05:37 PM   #12
xantdieselx
Kingslayer
xantdieselx's Avatar
411
Drives: 23' M3 Base
+1
It washes right off, but what a PIA. I had it in the door jambs and under the hood. I took some pre-cleaner and wiped the jambs and underhood. It works for a little bit. You just have to stay on top of it.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
1addicts
