09-11-2008, 03:59 PM | #1 |
Rep 1,592
Cup holder covered by warranty?
I have iDrive so I also have one of those little auxiliary cup holders on the passenger side of the console. The other day I was driving along when all the sudden the little spring loaded tab inside went flying off. I tried snapping it back into place but as soon as I put something in the cup holder it just pops off again. I've been driving around for a few days without it, but it's annoying as my drinks slide around and tip over. (I only take things with lids like bottled water or snapples, so no spills)
Anyway my question is will BMW replace this under warranty? And if so is it possible to call the dealership and ask them to order the part instead of having to take it in to show them that it's broken? My dealer is about 40 minutes away so having to drive there to show them the problem, then having to drive back after they order the replacement to actually get it installed is going to be a bit inconvenient. Dan |
09-11-2008, 04:12 PM | #2 |
Rep 1,609
They will replace it first time for good will. It won't hurt to ask and hear what they say.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
09-11-2008, 07:31 PM | #3 |
37
Rep 311
Drives: F31 M Sport
Hey, the exact same thing happened to me... Guess I'll visit my dealer...
09-11-2008, 08:29 PM | #5 |
Rep 6,968
Even if you replace it the tab will still fly out when you have a big cup in there. Poor design.
- There's nothing in my pocket other than knives and lint
09-11-2008, 09:54 PM | #6 |
Rep 5,627
09-12-2008, 06:20 AM | #8 |
Rep 244
Same thing happened to me, guess I should go see my dealer.
09-12-2008, 07:33 AM | #10 |
Rep 2,200
turn in all those broken ones, they may not even know there's a problem with the design yet
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
09-12-2008, 01:17 PM | #11 |
19
Rep 709
You can fix it pretty easily, the problem is the spring is overwound. If you unwind the spring A TINY BIT it won't pop out as easily.
Since that little tab is the only thing holding your quadruple strawberry mocha frappe in place they put a lot of strain on the clip. When the drink shakes sideways it can pop the clip out.
09-12-2008, 02:13 PM | #12 |
37
Rep 311
Drives: F31 M Sport
That is, if you can find the spring after it went flying
09-13-2008, 04:08 AM | #14 |
Rep 243
i had a bmw before and they were really good about replacing parts, even if it's a minor thing... like my cupholder was wearing out (normal wear and tear) after 3 years and they replaced it without a question either. so i m pretty sure they would replace this cupholder without a question also.
09-13-2008, 04:53 AM | #15 |
Rep 45
Mine broke within the first two weeks. It took my dealership about three weeks to get a new one in. They were quite nice about replacing it. As I was driving off in front of the dealership I placed my coffee mug in to optest it and the new one broke. I just gave up...I don't really need the spring loaded clip that bad to drive another 40 minutes to the dealership for a cup holder.
09-14-2008, 12:35 AM | #17 |
Rep 3,350
09-16-2008, 12:23 AM | #19 |
Rep 1,917
Mine popped off too when trying to put a big slurpee in it. I found it and popped it back in and it's been good since.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport |
09-16-2008, 01:30 AM | #20 |
1addict, and proud
40
Rep 1,019
I'm in the same boat. Damn thingy poped out and hit me in the nose, I spun the car around a telephone pole and ran over .....
Caugh lawsuit..Caugh caugh...lawsuit... ROFL Yoda |
09-16-2008, 01:30 PM | #21 |
Rep 1,592
I took the little clip apart and bent the two prongs on spring upward so that there is a tiny bit of give before the spring catches. Then I used some super glue to build up a layer around the two insets which hold it in place. (took a while as I painted a little bit, then let it dry, then painted more, and let it dry, so on and so forth for about 5-6 layers) After I was done it was really hard to get it back in, but I eventually forced it in. It's been working for the last couple of days without popping out so who knows maybe it will hold.
Dan |
09-16-2008, 06:41 PM | #22 |
76
Rep 5,970
Mine popped off within a week of having the car. I put it back on and it was pretty good until my road trip last weekend. Now it flies off if I look at it wrong.
I'm thinking they may just have to replace this with every oil change I'd love to see them offer real fix for it though. I really like the cupholder, but the spring loaded part is just crap. |
