      09-15-2008, 02:13 PM   #1
Bitterm3
Drives: White.Coral 135i
A/C Blowing Warm Air
With 4500 miles, my 135i starting blowing warm out of the drivers side vents and cool air, not cold air, out of the passenger vents. Now, it seems like all the vents are blowing warm air, which sucks in AZ. I've tried every setting possible, and the same thing continues to happen. I have an appointment with the dealer to have it checked....any thoughts of what may be going on? :iono:g
      09-15-2008, 05:28 PM   #2
gio
Drives:
It's possible your AC compressor failed. Turn up the AC all the way and look in the engine and see if it is running. I had the clutch fail on my AC compressor ones and it never engaged so the AC never went on. It could also be a leak in your AC which caused all your refrigerant to run out. If that is the case it could be very difficult to track down and fix. Luckily it's under warranty. Finally, it could be your thermostat.
Waiting on a 2015 M235
      09-15-2008, 05:46 PM   #3
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
As Gio said, you have a refrigerant problem. For some reason, that can manifest itself on a BMW as cool air from some vents and hot air from others.
Hope your dealer takes care of it quickly.
Tom
      09-16-2008, 02:53 AM   #4
Bitterm3
Thanks Gio and tom. I hope the compressor didnt fail...The cars going in this morning, ill post the results.
      06-26-2009, 10:52 AM   #5
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
Don't mean to bring up an old thread but until today my a/c has been working fine. On my drive to work, however, I was only getting slightly cool air while I had the a/c on max for my entire 25 minute commute. This was sort of all of a sudden. Do you guys think I may have a leak as well?
      06-26-2009, 10:56 AM   #6
shodanusmc
Drives: 09 135 Vert
Leak, clutch or compressor. Dealer will get you fixed!
      06-26-2009, 11:12 AM   #7
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
Ugh...I hate removing mods. Thx.
      06-26-2009, 11:30 AM   #8
KeithLM
Proud 1er
KeithLM's Avatar
24
Drives: Crimson/Coral 135i
What mods have you got? Is your dealer uptight about it? They most likely can't have caused an AC problem unless during the installation you damaged something.
Stett Performance Charge Pipe with DDV, Cold-Air Intake, Front Mounted Intercooler, and Stage 1 Oil Cooler.
I've recently moved my photos to Google's web albums. Photos can be found here, here, and here.
      06-26-2009, 11:49 AM   #9
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
Guess the only thing I need to remove is the JB3.
      06-26-2009, 01:53 PM   #10
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
So I can't get into the dealer until Tuesday. They are booked with 120 appointments for Monday and a majority of them are a/c related. Hmm...
      06-28-2009, 10:58 PM   #11
Slay0r
Slay0r's Avatar
Drives: 08 135i, 08 E92 ///M,13 535i
yeh,..mine was an odd issue. After being at the dealership for a week, i pick it up and the AC wasnt blowing cold. I think it was the fan or something. Just bring it in, they'll take care of you
      06-30-2009, 09:59 PM   #12
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
So the diagnostic findings showed there was a leak in the line from the compressor and the line has since been replaced. Just a stroke of bad luck it seems.
      12-27-2016, 04:35 PM   #13
Chihuahua
Chihuahua's Avatar
4076
Drives: E30 329iS, E65 Alpina B7
sorry to revive such an old thread, but I wanted to put this somewhere in the hopes that someone else down the road with a similar problem finds it.
my 2011 128i started exhibiting this problem a couple of days ago; I had cool air coming from the passenger vents, lukewarm air from the drivers side vents. There was a significant temperature difference between drivers and passenger side vents.
I hooked the car up to an AC machine, system was quite a bit low on refrigerant. I filled it back up to spec, now I get consistently cold air on BOTH sides of the car. the system was simply low on refrigerant. We couldn't find any visible leaks (tracer dye).
I read somewhere that SAE (society of automotive engineers) states that acceptable spec on a car AC system fitting is .25 ounces of refrigerant loss per year. multiply that figure by the number of fittings on your car, and you can see how it is at least possible to lose refrigerant over time without having a significant leak.
again, didn't mean to 'grave dig' an old thread, just thought my experience might help someone down the road.
      10-17-2017, 11:16 AM   #14
PDACPA
Drives: F33 M Sport 435i
2012 135i Warm air from the driver two vents and cold air from the passenger.
It seems weird to me that low refrigerant would be the cause as the passenger side feels correct. It is almost like the cool are is being blocked.
I have a BMW extended warranty, so will take it in to the dealer, but thought I would post to see what others had found to be the issue to "guide" the dealer.
Thanks
2014 F33 Blk/Blk MSport 435i (sold)
2012 135i Blk/Blk
      10-17-2017, 05:31 PM   #15
puppydax
puppydax's Avatar
Drives: E82 135i
2009 BMW 135i  [0.00]
2016 Viper ACR  [0.00]
2007 BMW 335i  [0.00]
Thanks
It's really low refrigerant if the passenger side is cold. I just had this issue 2 weeks ago and had my AC system tested for leaks and refilled. Back to normal now. My two driver vents were ambient (if not warmer) air and the passenger was chilled air. I had 0.44lb of refrigerant in the system. Way too low.
1addicts
