      10-16-2008, 10:23 AM   #1
My135
Drives:
Scratched Head Light
My head light was hit by something on the road. How much to replace the head light cover or can it be buffed out? If any one know, please let me know. Thanks.
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
      10-16-2008, 12:27 PM   #2
modbargains
modbargains's Avatar
170
Drives: 08 E90 335i & 01 Toyota Avalon
How deep is the scuff?
Depending, you can buff it out or just use PlastX if the it is really light.
      10-16-2008, 02:10 PM   #3
My135
Drives:
You can easily see it and feel it. It is not light but not deep scratch neither. I will try Pastx first and see what happen. Thanks.
      10-17-2008, 06:01 AM   #4
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
What's your deductible? The only way to get it replaced is to buy the entire headlight assembly, and they cost over $1000.
      10-17-2008, 02:43 PM   #5
Sherifftruman
Drives:
If you can actually feel it, you can expect it to take about 5 days more than forever to do anything with Plastx. You will have to go much more agressive.
If you are truly contemplating getting a new cover, you should probably get some rubbing compound and try that. If it does not work, start with some super fine sandpaper and wet sand it. Something like 4000 or 2000 grit. Keep getting more abrasive until it makes a difference, then work your way back down through the various products until you are back to Plast-X
      10-17-2008, 04:53 PM   #6
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
I'm curious - can the cover be replaced on a 128i with halogen lights? And, if so, what is the cost?
Tom
      10-17-2008, 05:42 PM   #7
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
Unfortunately, none of the headlights are available in anything less than a complete assembly.
1addicts
