      12-02-2008, 01:01 PM   #1
arok
Drives: BMW F30 335i M-Sport
any rear camber solutions yet?
I'm still a bit new to BMW suspension, but I was curious if there were any solutions to adjust the rear camber yet.. links, arms, bolts, etc... enlighten me please .
thanks!
2013 BMW 335i M-Sport
      12-04-2008, 07:00 PM   #2
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
The rear uses eccentrics. So no problem there!
      12-04-2008, 08:17 PM   #3
KerryE
Drives: 135i
I just had the Dinan camber plates installed today and had the tech dial out alittle camber in the back, went from 1 50 to 1 35. The two together seems to have freed the car up. I am tracking it this weekend so I will let you know.
      12-04-2008, 10:18 PM   #4
pkcormier
Drives: 135i
Kerry, it's Philip. Are the Dinan camber plates adjustable? What was your final camber reading? What did you set the toe at? Let me know how your event at MSR goes. I'm buried this weekend with Honey-dos otherwise I'd drive out. Have fun. BTW, what track config are you running?
      12-05-2008, 05:52 AM   #5
KerryE
Drives: 135i
I do not have the info infront of me, but, I believe it is at "55". I think the factory setting is around "25". I will pull the paper work and get the exact degree. Took it out last night and pushed it alittle and maybe it is better, we will see. Let me know next event you are doing and I will be sure to sign up.
On the 19th there is a 1 day event in Austin, the cost is 220 with all the driving you want. No sessions, just driving, probably 20 cars.
      12-05-2008, 05:55 AM   #6
KerryE
Drives: 135i
1.whatever clockwise. I believe the Dinan camber plates are adjustable but I will have to check. The tech at the BMW store led me to believe they were, but, I could have misunderstood, will check on that as well.
      12-05-2008, 09:50 AM   #7
ajshanny
111
Drives: 1M
I understand that the BMW factory specs for rear camber are -1.83 with 0.25 tolerance in both directions. Why did you go with -1.35? Is less negative camber than the the factory spec supposed to improve the handling of the car?
      12-05-2008, 11:47 AM   #8
KerryE
Drives: 135i
it was at 1 50 from factory, according to the tech 1 35 is still within specs, I am no expert though, just hope some of the understeer is gone.
      12-05-2008, 12:56 PM   #9
ajshanny
111
Drives: 1M
Has someone said that less negative camber reduces understeer on these cars, or is that just a logical guess based on general principles? Theoretically, it does make sense to go with less negative camber in the rear if you're already maxed out on negative camber in the front and still having understeer problems. If you can't increase grip in the front, then reduce it in the rear.
      12-05-2008, 01:21 PM   #10
arok
thanks, good to know
      12-05-2008, 01:26 PM   #11
pkcormier
Drives: 135i
Kerry, can't do the 19th. Company xmas party that afternoon. Good luck this weekend.
1addicts
