12-16-2008, 08:05 AM | #1 |
Rep 1,288
KW Spring Rates ?????
Never used KWs before. Used ground control on a couple prior BMWs. Ground Control always let me spec the spring rates I preferred.
What are the KW spring rates? Can you spec your own spring rates, or locked into their standard springs? Thanks. |
12-17-2008, 01:30 PM | #3 |
Rep 59
It depends... KW Clubsport range does not use progressive springs... they are linear.
Maybe you should point out which coilovers are you looking at... KW Clubsports are also the only ones with adjustable front camber plates.
12-17-2008, 08:31 PM | #4 | |
Rep 1,764
KW2012 570 lb/in Orb |
