New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > 2009-Current Z4 Forum (E89) General Discussion
      05-19-2009, 07:08 AM   #1
Nebraska99
Drives: CLK 500, RX350
Can you lower the roof....
..remotely using buttons on the key?
      05-19-2009, 07:22 AM   #2
Niels
Belgium
Drives: '85 Citroën 2CV / '09 BMW Z4
Jeps... When you have the "comfort access" option.
      05-19-2009, 07:45 AM   #3
JJ_Wonderboy
JJ_Wonderboy's Avatar
11
Drives: 2009 Z4 35i
Yes, I believe so.
      05-19-2009, 08:05 AM   #4
jlstyle
jlstyle's Avatar
355
Drives: Porsche Panamera
2014 Audi S7  [0.00]
2015 BMW X5  [0.00]
Wow you now need to add an option to lower the roof by a key????
      05-19-2009, 08:09 AM   #5
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
Drives: 2009 Z4 sDrive 23i
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
You can lower and raise the roof without having comfort access (certainly on UK cars).
E89 Z4 sDrive 23i... for the more discerning driver
      05-19-2009, 08:45 AM   #6
Niels
Belgium
Ok, I might be mistaken by information.
If you have comfort access the roof goes up a bit so it's easier to access luggage in the boot.
Sorry for the misinformation!
My cars:
1985 Citroën 2CV Spécial ~ 28 horses
2009 BMW Z4 sDrive23i ~ 204 horses
      05-19-2009, 10:14 AM   #7
zEdP
Ed
Netherlands
18
Drives: Z4 sDrive30i
They say you can't open or close the roof when driving (3th brake light is not visible when roof is busy opening/closing)...
BUT what happens we you start driving during when the roof is busy opening? It just stop opening and you have to stop the car and press again the opening button?
EdP
      05-19-2009, 11:28 AM   #8
JJ_Wonderboy
11
Drives: 2009 Z4 35i
EdP
I doubt you'll actually be able to drive the car (i.e. accelerate) whilst the roof is in motion.
      05-19-2009, 11:32 AM   #9
zEdP
Ed
Netherlands
18
If this is the case, the roof can only be moved when the engine is not running?
      05-19-2009, 11:45 AM   #10
Shakal
Shakal's Avatar
5
Drives: BMW
Probably you must turn e-handbrake on and its impossible to turn it off until roof isn't closed / opened.
      05-19-2009, 12:29 PM   #11
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
On the old Z4 you could hold the button in and then drive off, but keep the button held to complete the operation. If you let go of the button whilst the car was moving, the roof wouldn't move until you completely stopped! I think there will be a speed detector and the roof will only move if you are stationary.
      05-20-2009, 06:12 AM   #12
KWY91
KWY91's Avatar
Singapore
37
Drives: 2015 BMW M3 (on order), 458
I think if u are moving at speeds lower than 30km/h, the roof would still be in motion and won't make u look like an idiot with a half opened roof :-P
Wanna know my mods for my 335i? It's here! http://www.e90post.com/forums/showth...ght=blue+water
Lamborghini's Mica Orange E93 M3
Akrapovic Exhaust //Challenge Rear CF diffuser//ESS VT-575 Supercharger
      05-20-2009, 02:20 PM   #13
john08135i
john08135i's Avatar
Drives: 2013 M Sport, 2010 bmw S1000RR
I was told on z4 you MUST insert the key in the door lock to open from outside or comfort access option to do it with the FOB
M Sport Line Estoril Blue
      05-20-2009, 04:34 PM   #14
milhouse
Norway
37
Drives: M4
you can open the roof with the key and you can only cloesd it with the key if you have comfort access,
2015 M4 MG on SS.
X:2002 M3 ESS JeppeJ edition,2011&2010 335i DCT,
98 M Coupe, 10 X6 30d, 09 z4 23i +++++
      05-20-2009, 06:25 PM   #15
Yunes7
Drives: Bmw E89
Where is the button to do that? I have a sdrive 2.3 and my remote control has just 3 buttons...
      05-20-2009, 07:12 PM   #16
milhouse
Norway
37
Drives: M4
It is just to hold the button to unlock the car! If you have comfort access yoc just hold the button to luck the car to but it back on.
you have to hold it the hole time
2015 M4 MG on SS.
      05-22-2009, 06:28 AM   #17
Rubber Ducky
Rubber Ducky's Avatar
47
Drives: 2020 M340i
Comfort Access in the E89 works same-same as E93. Info above is mostly correct.
Close to car (13 feet for E93 and probably same for E89 - antenna range), press and hold LOCK on fob to raise roof, UNLOCK to lower. Car does not have to be running.
Car must be stopped to raise or lower roof from the buttons on the dash. Roof stops where it is if you start moving.
The other interlock is the panel in the trunk. Must be in down position to lower the roof (and has interlocks on both sides - both must be engaged).
Having lived with the hardtop for over two years now in my E93, these comments:
Absolutely trouble-free (after early replacement of faulty interlock switches in top of windshield - no longer an issue in cars built after earliest runs).
Extra headroom from the design, confirmed also in E89 on test drive.
Ultra-quiet with roof raised.
Except in a pounding rain, when you really know it's a tin roof. It do get noisy in a Florida downpour.
In all, no one should hesitate because of the roof. It's a BMW home run and the E89 has two years E93 design and field experience.
      05-22-2009, 08:24 AM   #18
siscobmw
freude am fahren ....scheiden freude...
siscobmw's Avatar
Italy
17
Drives: Z4 Sdrive30i tiefseeblau
...and certainly on Italian market cars.....
SiSco from Italy
      05-22-2009, 09:57 AM   #19
arisk
arisk's Avatar
Greece
10
Drives: BMW Z4 sDrive23i
And where are the photos my friend...?? We want photos of the members cars...!!
      05-23-2009, 04:50 AM   #20
BMW-NC
Selling drugs to BMW addicts
BMW-NC's Avatar
Germany
17
Drives: 135i e82 6MT N55
US SPEC:
Lowering / Raising via FOB no problem /w ComfortAccess 302
The Roof will not move while driving. Reason Nr1: You will risk deforming it (the mechanics) since it will act as a big sail while moving.
The Roof will stop moving and the car will inform you in a very -well- obvious way that the roof operation has not been completed.... PING PING PING
No E-Brake needed.
Just tried it outside.....
Ray
Quality US Spec Used Cars for Military Members stationed in Europe. Specialized in BMWs and MINIs up to 10k miles.
      06-26-2009, 02:43 PM   #21
JohnT
United Kingdom
4
Drives: Z4 sDrive23i
Hi,
I have just got this car without comfort opening and can open the roof with the key fob button but not close it, for that I have to use the key in the door lock.
Z4 beemer guy, can you really do both with the key fob buttons. If so how?
Thanks
John
      06-26-2009, 03:02 PM   #22
Z4 Beemer
Z4 Beemer's Avatar
Scotland
84
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Originally Posted by JohnT View Post
Hi,
Thanks
John
Ok, just tried this and it seems you can indeed only open the roof with the remote and not close it! A quick read of the manual suggests that if you have comfort access then you can also close the roof remotely. My dealers demo car which must have had comfort access definitely allowed the roof to be opened and closed with the remote, but I'm sure the sales guy said you could do both from the remote control without needing comfort access.
I tend to only operate the roof with the engine running as it apparently puts less strain on the battery.
zpost
