03-01-2011, 09:18 PM | #1 |
Rep 126
Front Sway Bar Installed - WTF?
So finally got around to installing an M3 front sway onto my 2011. The install went smoothly, its not a difficult procedure. But when I went out for the test run I got clunking from the bar over bumps. Thinking something wasn't tight enough I went back and re-torqued everything, but no change. Then, in case something was too tight I loosened everything up, but that wasn't it. Then I took the bushings back out and re-lubed them, this time using a ton of lithium grease - still no good.
Upon closer inspection I found that the bar was making contact with part of the aluminum frame at each "shoulder" of the bar, just before it bends downward to meet up with the drop link on each side. It almost looks like a fitment issue with not enough clearance at that spot, but a lot of people have done this mod with no problems. For now I've fixed it by attaching my original rubber bushings onto the sway bar at exactly the point of contact on each side, thereby creating a rubber buffer between the bar and the frame. It's quiet now and the improvement made by the upgraded sway is everything it has been made out to be. But I'd like to find a better solution to that banging. |
03-01-2011, 10:15 PM | #2 |
Rep 2,233
Take a look at the pics with this DIY. Maybe something will look different on your install.
http://www.1addicts.com/forums/showthread.php?t=217262 |
03-01-2011, 11:12 PM | #3 | |
Supreme Allied Commander
3886
Rep 54,503
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
03-01-2011, 11:20 PM | #5 |
Rep 1,552
Drives: '19 M2C | '20 100AE ND2
I think HPA nailed it.
2019 M2C - Alpine White - 6MT
2023 Supra 6MT - Deposit and Wait |
03-02-2011, 12:05 AM | #6 |
Rep 118
I've got the Hotchkis 32mm bar, and my clunking problems have always been where the end link bars attach, usually on top at the strut, but also sometimes at the bar.
I really don't like the Hotchkis end links with the allen socket in the end of the bolt that otherwise spins. Those UUC end links look much better. But in any case, I've found that it really doesn't take much un-tightened thread to get noise.
2008 135i Sparkling Graphite Metallic - 6Sp - Black Boston Leather - Gray Poplar trim - Sport Package
Premium Package - Comfort Access - iPod/USB - HD FM - Premium Hi-Fi - Heated Seats 5/27 Euro Delivery Welt - 6/5 Drop off AMS - Re-Delivery 8/8 - SOLD 8/2015 |
03-02-2011, 12:18 AM | #7 | |
3886
Rep 54,503
Drives: F80 M3
03-02-2011, 01:38 AM | #8 |
Rep 1,552
Price?
03-02-2011, 01:47 AM | #9 |
Resident Kerbalnaut
477
Rep 10,703
That was my question
03-02-2011, 07:23 AM | #11 |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
03-02-2011, 05:05 PM | #12 | |
Rep 126
Yes, I'm an idiot. The bar is on upside down. I wouldn't have thought it was even possible to put it on upside down so I didn't really think about that. I did have faith in getting some answers from the forum though. Thanks guys! |
03-03-2011, 08:46 AM | #13 |
Unloved BMW Addict
86
Rep 1,185
Drives: Z3 Coupe, 3 318Ti
You're not alone.
03-03-2011, 01:31 PM | #14 |
Rep 4,528
Drives: M2 CS
haha it happens
03-03-2011, 01:40 PM | #15 | |
Rep 4,070
I looked at pics and DIY's 50times before I installed mine because I was afraid of doing that very thing! |
03-03-2011, 05:10 PM | #16 | |
Rep 126
03-03-2011, 05:20 PM | #17 |
3886
Rep 54,503
Drives: F80 M3
