10-16-2012, 01:00 AM | #1 |
Rep 760
Drives: E82 135i & F80 M3
Anyone running E90/92 spec coilovers
As titled, anyone running E90/92 spec coil overs? I know they bolt straight up to our suspension no problem. Only difference are some slight mis-matched adjustments (in which im not even 100% sure of) due to the differences in weight I believe.
There are so many more used coilover options on the e90post forums. So I'm wondering, any of you 1addicts rocking e90/92 spec suspension? I'm eyeing the KW V1/2/3's mainly but open to any other quality brands as well. |
10-16-2012, 08:12 AM | #3 |
Rep 441
I would guess that they are generally different spring rates...heavier cars generally have heavier spring rates
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
10-16-2012, 05:26 PM | #4 |
Rep 760
10-16-2012, 06:56 PM | #5 |
Supreme Allied Commander
3886
Rep 54,510
Drives: F80 M3
Location: Santa Barbara, AP, Brembo, GIAC, Koni, Ohlins, Performance Friction, www.hpautosport.com
10-17-2012, 01:18 PM | #7 |
all day
48
Rep 1,181
Drives: 2012 135i
very interested in this also!
10-18-2012, 05:29 PM | #10 | |
Rep 760
I'm primarily looking at some KW V2/3's as their pretty common and what I consider to be fairly high quality. Anyone know the spring rates on those? |
10-22-2012, 02:02 AM | #11 | ||
Rep 3,099
Everything i know is that ohlins are the ones to get, nothing better for the price |
10-22-2012, 12:14 PM | #12 |
3886
Rep 54,510
Drives: F80 M3
10-24-2012, 04:19 AM | #13 | |
Rep 552
10-24-2012, 04:42 AM | #14 | ||
Rep 3,099
10-24-2012, 07:07 PM | #16 | |
Rep 3,099
Says includes camber adjustable mounts So does the road and track website If not, well that's not good! False advertising :/ |
11-14-2012, 03:11 AM | #18 |
Rep 760
My price range is around the $1200 ball park. Ohlins would be too pricey for what I am looking for.
I've been checking the E90post sale forums lately and honestly the only brand that ever pops up are KW's & ST Speed Tech coils. Which also happen to be under the same company. How much more are the spring rates for the E90/92 spec coils vs. the E82 1-series ones. I looked at the thread on e90post and I see the rates here: http://www.e90post.com/forums/showthread.php?t=235797 Lastly, since I'm looking on the used market. How long do coils generally last? |
11-14-2012, 04:57 AM | #19 | |
Rep 3,099
wow, yeah, fronts are 7kg/mm (390lb/inch) rears are 11kg/mm often (615lb/inch) for mine as you see in that post, it varies per brand/model 3 series and 1 series coilovers are 100% identical though (spring rates and all) unless you customize them |
11-14-2012, 10:01 PM | #20 | |
Rep 760
Thats where my question lies, what are the spring rates on KW V1's for E82 vs the ones on E90/92. |
11-20-2012, 09:17 PM | #21 | ||
Rep 760
Just an update on some added information for all you guys. I still hadn't found my definite answer as to the differences are between the E90/92 vs E82 coilovers on the KW/SpeedTech [made by KW, essentially same as V1] brand. So I decided to shoot an email to the company directly.
What I had sent: Quote:
E82 Drop: KW Coilover Kit V2 KW Coilover Kit V2 BMW 1series E87 Learn More Part #: 15220039 Front Lowering: 1.4" to 2.5" Rear Lowering: 1.4" to 2.1" E90/92 Drop: KW Coilover Kit V2 KW Coilover Kit V2 BMW 3series E90 Learn More Part #: 15220032 Front Lowering: 1.2" to 2.3" Rear Lowering: 0.9" to 2.1" |
