12-23-2012, 09:40 PM | #1 |
Addicted to Speed.
714
Rep 2,375
other parts needed for an suspension install?
Hi guys,
I searched and read through several threads regarding installing new suspension on my 135. I wanted to double check and makes sure that I had all the parts required before tearing down my car. I am doing: Koni yellows, BMW Performance yellow springs, Dinan rear shock mounts, oem shortened bump stops, M3 front control arms/headlight adjusting arms. I am going to reuse all the stock mounting hardware I can. My question is whether I need any other parts (gaskets/mounts/etc) to install the parts. ie are any of my mounting hardware incompatible with my new setup? thanks in advance |
12-24-2012, 07:30 AM | #2 |
Rep 1,293
Just a helpful suggestion... Make sure you order the correct rear shock mounts. Dinan offers two sizes (10mm and 12mm I think). I believe Koni shocks require the larger size, but you should definitely confirm with Dinan.
12-24-2012, 08:00 AM | #3 |
Rep 2,696
I don't know if with the koni's you'll need a different top nut in the front. I know with my kw's i needed new ones and different ones.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
12-28-2012, 09:17 AM | #6 |
Rep 494
Depending on miles, you may want to replace the rubber spring perches and dust boots with fresh ones. The Koni struts definitely take a different top nut from stock. If the nuts don't come with the strut, make sure you get some before starting the job. I think if I were doing it all over again, I probably would have bought new hats, spring perches, and dust boots and pre-assembled the new struts as a complete units and left the old stock struts assembled. I like to put my stock parts in storage in case I ever want to go back to stock. Once you take apart the front struts, you'll have to take them to a shop to have them reassembled. The stock springs are too long and the stock struts won't stay extended. It's virtually impossible to reassemble the stock struts with a garage mechanic spring compressor.
12-28-2012, 09:14 PM | #7 | |
Rep 2,556
Dinan's top adjust Koni sports=12mm
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
