Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (F01) 7-series General Discussions
      11-06-2013, 09:09 PM   #1
A B Able Truck
Drives: 2006 BMW 550I V8 (N62TU)
New N62 valve stem seal tool by AGA
The cost of replacing valve stem seals on a N62 is about to drop considerably
Authorized sneak peek of new N62 valve stem seal tool by All German Auto - Escondido, CA
Allows you to replace the valve stem seals on a BMW N62 without removing the cams.
The tool kit will be complete.
Valve compression rods for intake and exhaust.
Brushes to plug oil returns.
Ratcheting wrench for compression.
Control handle for compression rods.
Spark plug hole plugs with center bore for T. D.C indicator.
6.0 mm valve keeper install tool.
** Will be available in about a month **
      11-17-2013, 09:00 AM   #2
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [10.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [10.00]
2006 BMW M3  [10.00]
This is great news!
      12-12-2013, 05:45 PM   #3
A B Able Truck
It is now available;
http://www.bimmerfest.com/forums/sho...d.php?t=733856
      12-13-2013, 10:01 AM   #4
A B Able Truck
I think the new style valve stem seal - updated version not allowing the oil to pool inside the seal should make a big difference. After thinking about AGAs description of the improvements, it makes perfect sense on why the old seal style allowed so much oil consumption. The top of the valve guide was constantly submerged in a puddle of oil. The new style has removed that cavity, so even as the new seal wears, the oil will naturally want to expel to the outside of the seal. So the moral of this story is, be sure when you replace your seals you have purchased the new style (red in color).
7post
