11-21-2013, 10:03 AM | #1 |
Rep 293
Headlight unit failure or normal?
My M5 has LCD headlight units and today I noticed a small patch of condensation on the inside of the glass, right by the section that has the BMW Adaptive signage.
I haven't used the car for 4 days and the outside temp is 8 degrees. Question: is this normal or are both units faulty? |
11-21-2013, 10:16 AM | #2 | |
Rep 7,885
11-21-2013, 10:32 AM | #4 |
Yankee Air Pirate
151
Rep 978
Me three... very minor condensation that evaporated out
2020 ///M5 || 2019 540XI || 2014 ///M5 w/CP || My Epic ED trip report|| || 2009 BMW R1200RT
11-21-2013, 10:33 AM | #5 |
Knight Commander
559
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
This was considered normal with Xenons.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
11-21-2013, 10:38 AM | #6 | |
Rep 293
11-24-2013, 04:00 AM | #7 |
Rep 2
The light unit is not air tight or you would not be able to change the bulbs. The condensation is caused by water vapour in the air inside the lighting units and is not in itself a problem unless it damages electrical connections or starts any kind of corrosion or mildew infestation. It should go away with warmer weather, but if not have the lamp units checked for water ingress. A hair dryer will usually dissipate the condensation itself but will obviously not resolve any underlying problem.
11-24-2013, 04:03 AM | #8 | |
Rep 293
I've done a bit if driving with the lights on and it seems to have improved. Will keep an eye on it just in case |
11-24-2013, 04:45 AM | #9 |
Curve Thrasher
623
Rep 3,773
Agreed its not air tight. Just take it in as its under warrantee and they should replace w no questions asked. You don't want to be somewhere where failure could happen when you need those lights.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run |
