02-17-2014, 09:43 AM | #1 |
Rep 46
Key Lock inside car in case no comfort Access key
Hi Everyone. Currently i drive a 2011 Z4 which has a key less entry, It was a $500 option so i went for it. I am so use to it now in past 3 years, on several occasion i left my key inside my car but and my car never locks out and i remember to take out my key from the car. For my new 2014 X5 I am not planning to take the comfort access as it is not a standalone option. But i am little worried as i run the risk of locking the keys inside the car. Any thoughts/suggestions, If anybody has faced this situation.
02-17-2014, 10:51 AM | #2 |
Rep 49
I'm probably missing something here, but how would you lock the car without the key fob if you don't have comfort access?
I understand the car is smart enough to realise the key is inside. All F15s have keyless start as standard but the start function only works if the key is physically inside the car. So it does have a way to detect the key is in the car. But I don't see how the lock function would be activated without using the key fob when the engine is off. |
02-17-2014, 10:59 AM | #3 | |
Rep 46
"Door Unlock: If you ever lock your keys in your BMW, call our Response Center toll-free at 1-888-333-6118 and we will send a signal to your driver’s door to unlock it, after you provide your name and password." |
02-17-2014, 11:24 AM | #5 |
Rep 46
02-17-2014, 11:26 AM | #6 |
98
Rep 385
In my 2012 x5 the doors won't lock if the key is inside .. So u won't have to worry. This is from my own experience. Give it a try
02-17-2014, 01:49 PM | #7 | |
Rep 1,368
02-17-2014, 01:57 PM | #8 |
Rep 3,307
Only way you should ever be able to lock your keys in the car is if you toss them in the trunk when the doors are already locked (open trunk with the trunk button and it doesn't unlock doors). Even then, I'm not sure it wouldn't unlock the doors automatically. Key has a chip in it, car knows when it's inside.
02-17-2014, 07:41 PM | #9 |
Rep 1,417
Owners Manual: only hits I found were: ( with or w/o C/Acces should be same)
Take the remote control with you and do not leave it in the cargo area; otherwise, the remote control is locked inside the vehicle when the tailgate is closed.◀ The tailgate is locked again as soon as it is pushed closed. |
02-17-2014, 11:30 PM | #10 | |
Rep 3,307
02-18-2014, 10:14 AM | #11 |
Rep 118
Here is my take: keep the key in your pocket and never worry. If you never get it out of your pocket in or around the car then you can't lose it or lock it in the car. The only problem that I can see is someone who prefers to keep their key in their purse or briefcase or other bag.
thanks,
someguy |
02-18-2014, 07:22 PM | #13 | |
Rep 423
02-19-2014, 06:19 AM | #14 | ||
Rep 3,307
Btw, the BMW remote app can also be used to unlock the doors from your phone. Unless of course that's locked in the car too |
02-19-2014, 10:06 AM | #15 | |
Rep 423
I hear what you are saying, however, I have a Chevy Cruz and if you try and leave your keys in the car: 1. It won't lock the doors if the keys are inside and you leave 2. It will sound a horn 3 times telling you of your mistake 3. you can't lock the door from the outside if the keys are in |
02-19-2014, 10:46 AM | #16 |
Rep 72
My new x5 behaves a little differently to some of the examples here, so I suspect there may be some variability based on exactly where in the car the key is sitting. For me, if there was only one key around the car and it was inside the car, (i.e. I did not have a second key in my pocket), the car refused to lock, either with the door handles or the tailgate lock button. On the other hand, if I had a second key in my pocket, the car would lock as normal, even with one key in the car. I tried it with one key in the luggage area and no key in my pocket, and the tailgate would not close when I used the "lock" button while the key was in the vehicle - as soon as I picked the key up from the cargo area, the tailgate closed normally.
Also, if the car was locked and the key was in the car, it would not unlock unless I had a second key with me at the door. To me, all this means that it will be pretty hard to lock myself out (I wasn't able to do it, but I don't dispute others may be able to), but it is possible to lock the car if (for example) my wife's purse with the second key in it is left in the car. |
02-19-2014, 06:30 PM | #17 | ||
Rep 3,307
03-14-2022, 01:11 PM | #19 |
Vida
Rep 1
I turned my engine off and got out of my X5 to talk to a friend. My doors locked with my keys inside my purse that was still inside the car. This just happened on Saturday and we're all still baffled and wondering HOW it happened. I had to call my fiancé to bring my spare key. My doors doesn't lock with the keys inside AT ALL.
03-14-2022, 06:51 PM | #20 | |
Rep 7,477
It is an obscure feature that some use to make sure the car is locked if they unlock the door but never open it…the door will then relock. When I read that setting…I made sure it was turned off to prevent what happened to you. Also, going back in this old thread…the OP did NOT have comfort access so some of the situations mentioned would not apply to them. But there is an anti-lockout feature that wasn’t mentioned….the OP was worried that the could lock the keys inside if they pressed the lock/unlock button on the door. Well, that wouldn’t be an issue because you can’t lock the doors with the central lock/unlock button when the driver’s door is open. That is a BMW feature that goes back for decades.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-14-2022 at 06:57 PM.. |
03-14-2022, 08:57 PM | #21 | |
Rep 243
03-16-2022, 12:50 AM | #22 | |
<3 Flat Four
215
Rep 754
2011 335is Le Mans Blue
