03-10-2014, 03:09 PM | #1 |
Rep 203
Front Pad Wear Sensors Swap
Hi all. Just had a set of track pads installed over the weekend. My front pads were getting low and starting to grind down one of the wear sensors. They were tied back after the install but the sensor light went off so assume they now need to be replaced. Question is, can the front sensors be swapped without removing the wheels if they are tied off or just easier to pull the wheels for access?
Thanks |
03-10-2014, 03:46 PM | #2 |
Rep 2,342
Seeing how they're clipped in is inside the fenderwell I don't see how you could get to them without removing the wheel.
03-14-2014, 02:42 PM | #3 |
Rep 294
Going to be a real PITA if you don't take off the wheel. Turns a 5 minute job into probably a 30 minute job, if you can even twist your arms around enough to do it.
2012 X5 35D - Platinum Gray / Cinnamon Options: Sport, Tech, Cold Weather, comfort seats, leather dash, high beam assist, lane-departure warning, soft-close doors, two-row, self-leveling suspension, hi-fi stereo
Tracks driven (in any car): Nürburgring Nordschleife (05/2011), LeMans (ok, just the public part), Eagles Canyon Raceway, MotorSport Ranch Cresson, COTA Austin |
