03-13-2014, 10:57 AM | #1 |
Rep 74
PFC 08 pad failure
I bought a set of PFC 08 brake pads to use in my stock calipers for track days.
These pads had a total of 1.5 track days on them, and I am a beginner so I am not that hard on brakes. I removed the PFC 08's at the track to swap back in my OEM pads and found that the spring clip had detached. When I went to do the other front pad, I noticed the spring clip had also become detached and when I removed it from the caliper, the pad separated from the backing plate. PFC has a good reputation, but I am worried they are having quality control issues. Is it safe to assume I should get a new set under warranty? Apparently, I'm not the only one that has had this issue: http://www.m3post.com/forums/showthread.php?t=913823 |
03-13-2014, 11:31 AM | #2 |
Scythe-Meister
90
Rep 1,053
I've had corroded PFC 08 replaced under warranty. Yours should definitely be replaced under warranty. They clearly have a manufacturing defect that could have resulted in an incident given pad separation.
03-13-2014, 06:08 PM | #3 |
Rep 2,792
Track noobs are harder on the brakes. Once you get faster, you brake less.
Good luck on getting PFC to replace them, that should not happen.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
03-14-2014, 12:41 AM | #4 |
Rep 294
Not inspiring confidence given I just installed the same pad type to run next weekend.
2012 X5 35D - Platinum Gray / Cinnamon Options: Sport, Tech, Cold Weather, comfort seats, leather dash, high beam assist, lane-departure warning, soft-close doors, two-row, self-leveling suspension, hi-fi stereo
Tracks driven (in any car): Nürburgring Nordschleife (05/2011), LeMans (ok, just the public part), Eagles Canyon Raceway, MotorSport Ranch Cresson, COTA Austin |
03-14-2014, 01:58 AM | #6 |
Admiral
933
Rep 3,886
It's really not a very big deal in reality. Most "race pads" don't even come with a spring clip.
However, since these aren't a race pad, they should stay attached, and you should get a new set under warranty. To all you others worrying about your pads, don't.
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 |
03-14-2014, 08:15 AM | #7 |
Rep 10,176
Well, if when the rivets fail, the pad material separates from the backing plate, then there is a potentially "big deal".
03-14-2014, 09:34 AM | #8 | |
37
Rep 381
As to being a "big deal" I can only say that it wasn't in my case. The pad was fully contained within the caliper and functioned normally and showed no uneven wear - I was at COTA. I didn't know I had a problem until after I drove home and changed out the pads a few days later.
03-14-2014, 10:07 AM | #9 |
Rep 3,633
In theory, yes it seems like an issue but being that the pad is compressed by the pistons there's very little chance of something bad happening. (you wont shoot a pad out of the caliper).
03-14-2014, 10:52 AM | #10 | |
Rep 74
My thoughts are that since the pad was so new and thick, that it would be hard for the pad material to drop out while driving. Even when I pushed back the pistons to remove the pad, I did not even notice the problem until and I held the pad backing plate up after removal and the pad material dropped to the ground. Also, those 4 dots also helped hold the pad material in place. PFC has asked for photos and some details how the pads were used for purposes of failure analysis, but bottom line is that they are going to replace them for me. |
03-14-2014, 12:00 PM | #11 |
Stop the hate, get a V8
3853
Rep 8,625
Any sort of problem with brakes IS a big deal. I don't know why people would say it isn't.
OP: contact PFC immediately about that.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
03-14-2014, 12:04 PM | #12 |
Admiral
933
Rep 3,886
I see. Didn't notice that the pad material separated from the backing on my first look at the photos on my phone... That's definitely a defect
03-14-2014, 02:09 PM | #13 |
Rep 74
03-14-2014, 03:45 PM | #14 |
Rep 734
Yikes!
I have PF01 pads for track days. They didn't come with spring clips. Noisy! But they work great. Doing HPDE sharing car with wife so it does double duty and the brakes are fine. |
03-14-2014, 04:14 PM | #15 |
Rep 2,342
I hated those spring clips! Sometimes those things were so damn stubborn. Track pads - who cares if they make noise! not like the potential ticking is worse than the loud wailing screech.
03-14-2014, 05:42 PM | #16 |
Rep 2,792
The pads don't need the spring clips. My Project Mu Club racers don't have any. The pad material DOES need to stay bonded to the backing. It coming loose can cause a wheel lock up when it jams in the caliper.
