      12-15-2015, 05:40 AM   #67
dmnc02
dmnc02's Avatar
Drives: 2015 M4
A couple of small clarifications regarding the coding instructions I posted:
  1. As pointed out by wearenh, there is a typo at the beginning of Section 3: "2016 F15 vehicles produced since July 2016" should read "2016 F15 vehicles produced since July 2015".
  2. Also, the description of the first step for both pre-2016 and 2016 vehicles states "Remove 5AP and 8S4 from the VO and VO code". VO stands for Vehicle Order (it specifies the alphanumeric codes for each option installed on your car). Some coding guides call this the FA: FA stands for FahrzeugAuftrag (Vehicle order in German) and it is the same thing as VO.
2015 Mineral Grey ///M4 6MT
      12-15-2015, 08:20 AM   #68
MrTookies
MrTookies's Avatar
Drives: 2011 E90 328i, 2015 F15 35D
Thanks for that, was about to write a PM pointing that out. One quick thing that came to my mind... 2015 X5 35d here in the US was built until December I wonder how its set up here, have to check that out tonight.
      12-15-2015, 08:37 AM   #69
dmnc02
dmnc02's Avatar
Drives: 2015 M4
It is pretty easy to determine which are the relevant coding instructions for your car: once you have connected to your car with E-Sys and read your SVT, if you see that you have the LHM ECUs follow Appendix 1 and if you see that you have the FLE ECUs follow Appendix 2.
I believe that the switch to the FLE ECUs occurred starting with the July 2015 production, but let me know if this is not the case.
      12-15-2015, 08:41 AM   #70
MrTookies
MrTookies's Avatar
Yes just my thinking I'll connect tonight to my X5 35d (built 11/15) and let you guys know.
      12-15-2015, 11:10 AM   #71
alphaod
alphaod's Avatar
You guys are awesome... If I did the pre-December coding that didn't really give the tunnel effect, after I do the VO coding, since I did code BDC_BODY and KAFAS already (in my previous attempt), can I just skip that go ahead and just recode TMS and LHM? Obviously, I ask since I want to avoid having to recode values I already did.
Anyways I have a June 2015 build F15, so I'll let you guys know if I have the new or the old ECU.
      12-15-2015, 12:19 PM   #72
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Yes, if you already VO coded BDC_BODY and FLA/KAFAS after removing 5AP and 8S4, there should be no need to do this again. This way you will also preserve any additional coding you did in BDC_BODY.
      12-15-2015, 01:38 PM   #73
alphaod
alphaod's Avatar
Thanks.
And to confirm, I do have have the old ECU on my 06/2015 build F15.
      12-15-2015, 02:14 PM   #74
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Originally Posted by alphaod View Post
Thanks.
Thanks for the confirmation. The reason I believe the ECU switch occurred starting with the July 2015 production is that the ETK database indicates a change in the part number for the LED headlights effective July 1, 2015: I am assuming that the new ECUs are needed to support the new headlights.
      12-15-2015, 08:26 PM   #75
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Somebody has asked for instructions on how to modify the FA/VO and VO code. Read the attached PDF or watch the video (or, even better, read the PDF while watching the video ).
      12-16-2015, 01:57 AM   #76
alphaod
alphaod's Avatar
I did some tests and looks like the tunneling is working!
I did find two main problems:
1) The reaction time is kind of slow, so it doesn't work for windy roads at high speeds where cars will be coming and going quickly. For slower one-lane roads it works perfectly.
2) The car would mistake some road markers like cat eyes and signs for other cars. For example on one road there are cat eyes, reflectors on the center and side crash barriers, and lots of signs. It would constantly think there were other cars. Also stop lights in the distance could be mistaken for tail lights, so it would be creating a tunnel with nothing inside. Very weird.
Anyways thanks for you guys who did the hard work!
      12-16-2015, 04:17 AM   #77
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Both of the issues you mention are acknowledged by BMW: see the screenshot below from one of their training manuals. Nevertheless, you should find that the camera reacts very quickly once the headlights of an oncoming car come into its direct view.
      12-16-2015, 07:13 AM   #78
MrTookies
MrTookies's Avatar
I checked my ECU's yesterday on my 2015 x35d (11/15 built) and I do indeed have the new set of ECU's. I assume that its going, like you where saying according to production date and not really "set" production year e.g. 2015,2016...
I followed all of the instructions and not sure what I did wrong but its not working. I can tell that the light output is totally different under normal driving condition and A LOT brighter than the "old" bright light but the function of moving "brights" is not working. Is there anybody that can maybe do Team-Viewer tonight to help me and see if I maybe overlooked something...?
      12-16-2015, 07:39 AM   #79
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Do the following.
First, make sure you coded both of your FLE ECUs.
If are sure of the above, then:
  • Connect to your car and read the SVT as usual.
  • Right-click on each of the following three ECUs and select "Read Coding Data": BDC_BODY, FLA or KAFAS and either one of the two FLE. This will update the CAFD files for those ECUs in your C:\Data\CAF directory.
  • Email me (or upload or post if you prefer) the following three files from your C:\Data\CAF directory:
    CAFD_000017BE_xxx_yyy_zzz.ncd
    CAFD_00001148_xxx_yyy_zzz.ncd
    CAFD_000024C3_xxx_yyy_zzz.ncd
    (I am assuming you have the KAFAS camera).
This will allow me to check if there is anything wrong with the coding you did.
      12-16-2015, 07:52 AM   #80
MrTookies
MrTookies's Avatar
Do the following.
Yes I do have the KAFAS camera . BTW the ECU said KAFAS2 does it matter what number is behind, since it wasn't mentioned in the instructions?
I will do that and let you know, THANKS a bunch!
      12-16-2015, 07:58 AM   #81
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Everything is fine: KAFAS2 is what you should have.
      12-18-2015, 01:58 PM   #82
Stinkyxy
Drives: X5
I read in BMW's global materials that anti dazzle is a feature for adaptive lights (led and Xeon lights). Do you think this coding will work for Xeon too? Has anyone tried.
      12-18-2015, 05:00 PM   #83
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Yes, anti dazzle in principle works with adaptive Xenons too.
The issue however is that the adaptive Xenons that BMW fits to US-bound cars (at least on some car series) do not have the required rolling shutter (or walze in German) within the headlamp that is used to create the tunnel. As a result, if you enable anti-dazzle with these Xenons, while the high beams will split and point away when other cars are detected by the camera, the tunnel is not fully active and glare is produced.
Somebody on the other forum actually proceeded to take out and disassemble a Xenon headlamp on his brand new M3 just to confirm that the walze was missing (he really wanted anti-dazzle!). So we know thanks to him that there is no hope to fully enable anti-dazzle on US F30/F80 with Xenons.
I suspect that the walze is also missing in the adaptive Xenons fitted to US F15/F85, although I am not aware of anybody who has disassembled a headlamp to confirm.
      12-18-2015, 10:34 PM   #84
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
SOLVED - Codes
From user 2014F15 complete code.....sorry if I missed this PDF in other threads, but it is good enough to be duplicative. This code changes US VO values to ECE VO values, and user are reporting perfect anti dazzle
NGHB How To_F15.pdf
      12-19-2015, 12:24 AM   #85
MrTookies
MrTookies's Avatar
Originally Posted by MattBianco View Post
From user complete code.....sorry if I missed this PDF in other threads, but it is good enough to be duplicative. This code changes US VO values to ECE VO values, and user are reporting perfect anti dazzle
Attachment 1334463
Thanks for sharing all though the guy that wrote it, has already posted this here a little earlier and every post in this thread after post number #64 is about it, well pretty much http://f15.bimmerpost.com/forums/sho...1110249&page=3 POST #64
      12-19-2015, 12:57 AM   #86
MrTookies
MrTookies's Avatar
It would be great to see a better video of NGHB in action on an F15 at some point.
Thank you so much for this!
Alright here we go... after looking at the PDF and determining that my 2015 X5 35d (11/15 built) has the new ECU's, I coded it with Option #2. Taking it for a couple of test-drives I am very please to say that the function itself seems to be working even with the tunnel; The regular high-beam is so much brighter then the stock. The only thing I am not happy with yet is that; when the headlights go into split mode they seem to point up more and dim down the brightness, that I sometimes get this feeling "its on low beam" rather then high-beam. dmnc02 and I had talked about it a little bit and I told him I was going to take some clips tonight...I hope you can see what I am talking about. Apologies for the "amateur" video, only had a iPhone camera handy and filmed one handed while driving . There are 4 Clips # 1-4 at the beginning of the title.
JUST FYI if you open it in Youtube set the resolution to the highest.
#1
#2
#3
#4
      12-19-2015, 07:02 AM   #87
dmnc02
dmnc02's Avatar
Drives: 2015 M4
#1
#2
#3
#4
The videos are still uploading and Im not going to wait 4hrs - all night, they will post automatic when they are uploaded, in the background. Ill give you all the individiual links in the morning, sorry did not think my internet was that slow tonight.
PlayTookies, thank you for the feedback and videos. I have only watched the first one as the other ones are still uploading, but it is of very good quality and it clearly supports what you are saying. The tunnel on your car does look different from that on delviacv2's shown in the second video in post #64.
The thing to keep in mind here is that the PDF in post #64 contains two completely different codings, one for F15s built up to June 30, 2015 and one for F15s built starting July 1, 2015, as the headlights and ECUs that control them switched as of that date. Unfortunately, there aren't too many F15's with the new ECUs around yet and so the second coding was only tested by one forum member and he felt it was working as it should, but your video shows otherwise.
I know that all the steps in Appendix 2 are correct, in that they mimic the way the car would have been coded at the factory if sold on the European market, but there appears to be an additional step still missing.
Hopefully, we will be able to get this sorted out quickly.
      12-19-2015, 07:40 AM   #88
MrTookies
MrTookies's Avatar
@dmnc02 and @all . I updated the post above with the links. I'm convinced that we will solve this one as well, and I am happy to help as much as possible, especially since I want this to work, BAD!
