| 04-30-2015, 07:45 PM | #1 |
Rep 1,886
Engines: X5 F15 Performance Stats for 25d vs. 30d/35d vs. 35i vs. 40d vs. 50d
Last week I read somewhere that you can't tell the difference between the 50i and 35d in 0-30. Actually, you can, but the Ds show really well up to 0-50 mph.
Quite a shame that we will see a hybrid before we will ever see a 40d or 50d in the US market. Note: where data was unavailable (such as regulated max speed on US cars), I used data from the European equivalent. ![]()
10
schaeffs45.00 42pilot623.00 PnP208.00 F15GorDe261.00 JustChris17824.50 Billaeon42.00 swood023.00 Teufelshund155.50 LateParty2018X535d166.00 Harshan0.00 |
| 04-30-2015, 09:45 PM | #4 | |
Rep 1,886
Jenya B147.00 LateParty2018X535d166.00 |
| 05-01-2015, 09:01 AM | #7 |
![]() ![]() ![]() ![]() 623
Rep 710
The US is still a developing country in terms of fuel quality and performance (cetane rating) in terms of diesels.
| 05-01-2015, 09:16 AM | #9 | |
![]() 45
Rep 103
| 05-01-2015, 02:36 PM | #11 |
Rep 900
So this makes it look like real-world performance between the 35i and 35d are probably too close to be distinguishable.
That's good and bad for a guy considering a 35d. Good because it makes a strong case for fuel efficiency without performance compromise against the 35i. Bad because the buzz is that that 35d feels just as strong as the 50i in the "stoplight to normal speed" meter, where most of us want to feel like we have fast cars. These numbers don't say that. Maybe there's more to it than the numbers suggest.
-Will
2013 535i xDrive M-Sport | 2005 545i Sport (Retired and missed) | 2001 X5 3.0 Sport (Retired) ![]() |
| 05-02-2015, 06:53 AM | #14 | |
![]() 45
Rep 103
On a side note - the 8 speed ZF box has made the diesel cars even better relatively as they mask the diesels shortcoming top end wise by being able to drop the engine back into that massive torque curve on each upshift. The move from 6 to 8 speeds was a huge improvement in the E70 diesels and that continues and has been nicely refined in the F15. |
| 05-02-2015, 12:35 PM | #15 | |
Rep 1,886
At any rate, for those in the States, the 0-60, for the three available engines are: And, for US, "As of October 2014 production, there will be an engine displacement change on the N55 engine (X5 sDrive35i and X5 xDrive35i) that increases displacement from 2979 cubic centimeters to 3001 cubic centimeters". |
| 05-02-2015, 09:35 PM | #16 | |
Rep 710
In real world driving, like 0 - 60 or 70 like entering a motorway/freeway, the two engines are nearly identical and I would argue it's really up to the driver. By the numbers, they are essentially the same. If you want to talk about the 1/4 mile, they are identical - torque always trumps HP. So, except for the V8, as far as performance is concerned, the diesel has the edge because of efficiency - there is no masking of the diesel's short-comings because, by the numbers, it really doesn't have any. Transmission technology and ECU strategy has come a long way in the last 5 years. My F10 550i had an 8 speed and I got great economy. And when I stepped on it, the ECU always chose the right gear for the given RPM/condition. I would never go back to standard transmissions (yikes, can't believe I'm saying that being a track guy since 1989) because you cannot chose the right gear faster than an ECU and you certainly cannot shift faster than an auto. On the track, a paddle shifter is the best option. Again, for street purposes it's the ECU that's doing the real work, admittedly in an excellent ZF package - keeping the diesel or the petrol in sweet spot. Tuning trannys is equally important as the engine now. Push the sport button on our F15 and it will select the right gear for the given RPM and lock the torque converter at a lower RPM. Line pressures are probably higher too which give crisp shifts rather than butter smooth of comfort settings. The good thing these days is, you can chose a petrol or diesel and not lose performance - it is now completely a personal decision. You can't lose.
MarineOh3114.00 |
| 05-02-2015, 09:37 PM | #17 | |
Rep 710
| 05-02-2015, 09:58 PM | #18 | |
Rep 1,886
It makes no sense as so many jurisdiction tax based on cc, hence every manufacturer producing engines that are few cc shy of the round-up number. Germany ![]() US shows 3004! A number only disclosed in the detail specs on the website that is different from their own press release and rest of the world specs. ![]()
| 05-02-2015, 11:20 PM | #19 |
Rep 1,886
But it does so well against other cars in its class. Performance is not an issue whatsoever. I will start a thread
| 05-03-2015, 07:03 AM | #20 | ||
![]() 45
Rep 103
I've noticed the shift action in sport in the F15 gives the car a perceptible sense that you are changing gears - unlike the comfort setting which is totally smooth - it makes the car feel more sporty in that setting so matches its billing well. It also makes the car feel like one of my other cars in this respect and that has a single clutch robotised manual gear change - racy stuff for a two tonne SUV!! |
| 07-29-2016, 10:35 AM | #21 |
is just a Regular guy
76
Rep 114
Drives: BMW X5 x25D and 640i Cabrio
Guys, am new to this forum and am currently awaiting the delivery of a new X5.
I am puzzled by one thing, which is the power discrepancy and update from 2015 http://www.carspecsguru.com/bmw/x5/iii/group-offroad_5d Is there a reason why the x25D power have been revised from 218HP to 231HP from 2015 onwards? I have not found anything much on the net on the reason why, and not many has reported this change officially. The official information I have received from the dealer suggested I have ordered the 170kw (which is the 231 Hp version), but I have found very little mention of it, versus the 160Kw version on release. |
| Bookmarks |
| Tags |
| bmw engines, diesel, diesel vs gas, f15 engines |
