05-31-2022, 01:58 PM | #67 |
Rep 137
Subscribing for future reference 👍
2015 X5 50i Msport - RIP 10/2017
2016 M6 Competition Package - lease end 2018 540i Msport - enjoying now Thinking of F85 🙏 |
07-16-2022, 04:25 PM | #68 |
Rep 1,152
Got this done on my F85 at 52,000 mi. It was out spec. Per my indy shop guy, the oil pump chain had 17mm of play, spec is 10mm +/-2. Set oil pump chain play to 10mm.
My car did have some weird noise as if something is loose upon start-up and when initially pressing on the gas, this seemed to have eliminated that noise. Either way, I am glad this was addressed. Good lookin out OP! Last edited by Bobby_Drake; 07-16-2022 at 04:42 PM.. |
08-10-2022, 08:29 AM | #69 | |
Rep 104
Best, Frank |
10-07-2022, 04:31 PM | #70 |
Rep 464
Got my chain tightened today, had pretty major slop in it, have 70k miles on my f85. Fairly easy job overall, i reused oil pan bolts and replaced oem gasket with the elring part
10-07-2022, 07:32 PM | #71 | |
Rep 901
GotV8?1052.50 |
10-07-2022, 10:11 PM | #72 | |
Rep 836
Drives: Jerez E92 M3 ZCP "12"
10-07-2022, 11:15 PM | #73 |
Rep 901
I'd also order the reinforcement plate bolts - it'll be the last time you spend money on them. A word of caution on the oil pump T45 torx bolt - take it easy, obviously, while tightening. Silly me overtightened it to the point it snapped - what a nightmare to replace it.
GotV8?1052.50 |
10-11-2022, 07:35 AM | #75 |
172
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
I ordered too. Will be doing this in the next month or so and will report back as well. 54k
2023 GMC Denali Ultimate
2021 Porsche Cayenne GTS 2019 Ford Raptor SuperCrew 2015 Porsche GT3 2004 Ferrari 360 Spider 6M |
11-12-2022, 07:20 AM | #76 |
Rep 90
I just did this today and my 2016 at 64k had double the 10mm total play. I used high tack to keep the gasket in place while I started the bolts. Overall about a 45 minute job on top of an oil change.
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts |
11-12-2022, 08:21 PM | #77 |
F15 daddymobile
2358
Rep 3,534
so basically all these cars out of spec, some at relatively low miles. Is this something that will have to be checked every couple years?
11-15-2022, 08:53 PM | #80 |
Cattlecar
45
Rep 141
As far as doing this every 40K: On ATV and motorcycle timing chains and some other chains in oil baths, I have always found the wear is loaded up front. Roller chains run on gears that are usually not precision ground and will have wear-in polishing and then little wear afterwards. Has anyone done their oil pump chain a second time? I'm curious if this chain does see similar wear in the next 30K or more after being checked and adjusted the first time.
01-28-2023, 07:18 AM | #82 |
172
Rep 340
Drives: Several
So I did this a couple of weeks ago. Pretty easy DIY. Except I snapped one of the oil pan bolts due to over torquing. My wrench didn’t click! So I kept turning and then “pop!” So that was my bad. I ended up with a leak and long story short had to take to an Indy to extract the bolt and basically redo the gasket and lower drain pan. Argh!! $2 bolt cost me $1,300! Tried to extract myself but I didn’t want to botch it up and ruin the lower housing.
But the car is definitely quieter at startup with whatever slight “rattle” I was hearing now gone.
Chilled370.50 |
01-29-2023, 11:47 PM | #83 | |
Rep 1,038
01-30-2023, 07:06 AM | #84 |
172
Rep 340
Drives: Several
It’s wasn’t awful but it definitely needed adjustment. Meaning it wasn’t on the verge of falling off. It was similar to the videos that were posted. I’m at about 57k
Chilled370.50 |
01-30-2023, 09:53 AM | #85 |
F15 daddymobile
2358
Rep 3,534
thanks all for sharing your experiences and links here! 50i owner here but i'll be doing this around 50k. i'm at 33k now
01-30-2023, 11:32 PM | #86 |
Rep 39
This is so epic, it ought to be considered for a sticky. I’ve saved it in my phone to review with my service guy whenever i do service.
I have/currently own MB so, i’m new to BMW cars but this, in my mind, is tantamount to the head bolt issue with the w204 c63. Well, not exactly, but in some ways. And probably many other car situations have similar ‘ounce of prevention’ tips/issues. Thanks again. Point of the post is to consider this a sticky. |
05-23-2023, 05:00 PM | #87 |
Rep 644
Curious as to what others paid to have this done. Had a local Indy shop do a quote and they said $1100 in labor and parts.
05-24-2023, 06:04 PM | #88 |
Rep 644
Update… $781 for labor and a recommendation to replace the chain since they are in there already.
