12-30-2021, 04:06 PM | #1101 |
Rep 63
Mine been pretty solid, 110K miles knock on wood. the only major issue was Radiator and the last two times I disconnected the battery had to get the steering reset, don't ask me why the stabilization light comes on
01-04-2022, 08:05 AM | #1102 | |
Rep 10
01-04-2022, 08:28 AM | #1103 |
Rep 10
No auditory cue when locking vehicle.
I've had my X5 for a little over a year now but I got bored of that "Space Gray" color so I got it wrapped a darkish blue. I was surprised but happy when it came back with no proximity sensor or adaptive cruise control sensor issues. The functionality of the car is perfect, it starts fine, it runs fine, the AC is a bit slow to heat up or cool the interior but it's always been like that. However once the car is parked and I get out of it, I press the lock button on the key fob and the light blinks indicating it's locked but it won't produce the auditory "chirp" noise to indicate that it has locked. The locking mechanism works so I'm not worried about it getting stolen, however I lock it and tend to second guess myself, so I unlock it, then lock it again to hear the locks click into place. I have already tried calling my local BMW dealership and got no response from them. Does anyone know if there is a "quick fix" for this issue?
01-04-2022, 08:57 PM | #1104 | |
Rep 2,528
https://f15.bimmerpost.com/forums/sh....php?t=1572659 https://f15.bimmerpost.com/forums/sh....php?t=1326878 https://f15.bimmerpost.com/forums/sh....php?t=1785357 Last edited by RED_Y_; 01-04-2022 at 10:19 PM.. |
01-04-2022, 10:05 PM | #1105 |
156
Rep 358
Quick fix? lol. That does not even make sense in the context of BMW. Sorry.
First thought... try pressing your panic button on the key fob. That chirping noise comes from the alarm siren module located under right rear bumper. The panic alarm sound comes from the same module. It is a $250 part. If you or your local Indy connect with ISTA+, you may see a stored fault code pointing you in this direction, too. |
01-04-2022, 10:19 PM | #1106 | |
Rep 2,528
01-10-2022, 07:11 AM | #1109 |
Rep 10
01-11-2022, 12:37 AM | #1110 |
Rep 2
Comfort seat issue
Hi all,
I have an issue with my f15 electric comfort seat thigh support. For some reason it stoppet working not moving at all when I push the button forward, I can hear the electric motor clicking, sounds like it has something stuck in it. I assume it has a plastic gear in it which is broken just like in the e70. I could not find any information on the internet. The whole mechanism is complitely different from the e70's. I've tried to remove the electric motor but I could not due to the seat frame. The seat on the picture I attached is the same as mine. Do you have any suggestion how could I remove the motor form it or do I need to remove the whole seat before ? Any Idea is much appreceated! |
01-11-2022, 08:12 AM | #1111 | |
Rep 10
Seat motors
https://www.bmwpartsdeal.com/parts-l...em_drives.html |
01-19-2022, 05:30 AM | #1113 | |
Rep 3
01-19-2022, 05:35 AM | #1114 |
Rep 3
Might get a new car soon. My car has a little scratch on the bumper
01-25-2022, 04:39 PM | #1118 |
Rep 71
Only had one issue with my 2017 F15 diesel, and it had strange symptoms. Never affected driving or anything, but occasionally would pop a code for P0675 and either P02D5 or P02CF. I couldn't ever find any info on those code combinations anywhere and it drove me nuts until I finally took it into the dealer expecting to get some use out of extended warranty. I had worries of everything from fuel contamination to just a glow plug module.
The fix ended up being the fuel injectors, which apparently had a service bulletin/recall/extended warranty from BMW for defect, which I wasn't aware of. They replaced 5 of the 6 injectors, and I never had a CEL or hiccup ever again. It was strange that there was an issue with fueling because my fuel economy was never bad, acceleration was never bad, never any roughness... just that little annoying light. I would've never known otherwise. Other than that, it was truly one of the most reliable cars I've owned. |
Seattlesquash915.50 |
02-08-2022, 08:16 PM | #1120 |
Rep 1
F15 Steering Angle Sensor
Disconnected battery the other day and the stabilizattion light come on the dash and the indicators dont turn off automatically been told i need to recalibrate the steering angle sensor can anybody do this in manchester for me if i pay you or can do it over teamviewer or something.
02-21-2022, 04:15 AM | #1121 |
Rep 4
No real issues with my car so far, but what i do find annoying is the available space in the storage compartment between the front seats. Half is taken up by the unused, non-removable car kit, which means that usable space is minimal. The available compartments in the cabin are small for such a spacious car.
