08-09-2015, 10:21 PM | #67 | |
53
Rep 343
2015 X5 35i M Sport
08-09-2015, 10:58 PM | #68 |
Rep 1,762
Drives: Porsche Panamera
With constant MAX A/C setting, I literally get brain freeze so I usually keep it at 2 bars after 5~10min of Max A/C in the beginning at around 64~67 degrees. Anything lower would freeze my body.
08-09-2015, 11:28 PM | #69 |
Rep 79
08-10-2015, 06:09 AM | #70 |
Rep 473
Drives: 2016 Mini Cooper S 5 Door
Don't get me started... I should've thought about the 117 Degrees we get when I chose "Black Sapphire" and I didn't expect the AC to be so Weak even on the highest fan in Auto Mode! It kinda becomes powerful when I turn on MAX AC
08-10-2015, 07:32 AM | #71 |
Rep 8,821
I guess I am a minority here but I find my 2015 X5's AC more than enough even in 95 degree weather. In fact I almost never have it higher than half way.
I have the rear climate control on my car so I am wondering if those with issues have this option too? Wondering if the blower is stronger in cars with it. Alan |
08-10-2015, 09:35 AM | #72 | |
Rep 525
Im not sure if everyone understands that this is really only a problem when the car is left in the sun... if i pull out of my 100 degree garage, it will cool no problem(no direct Sun). but get in it after direct sun weather 100 Degrees. its a HOT BOX OF HELL.... IT has no problem keeping a cold car cold, but a hot car does not cool down for me in time, Fan on high temp on Low, sounds like a train, but cant quite do it... my X5 would keep me ice cold after coming out of a freezer into 120 degree weather, but not if it was in the oven first. Ive begun to research aftermarket options for AC control
08-10-2015, 10:43 AM | #73 |
Rep 164
I think it is the windshield that is a big culprit. It let's in more heat the any other car I have driven, including an X3. Just a sunny 70 degree day can still cause you to bake in direct sunlight.
08-10-2015, 11:29 AM | #74 |
Rep 11,136
The A/C in BMWs is my wife's biggest gripe about the brand. She hates the A/C in our X5 (E70) and in her 135i. I agree they're not very good. Blows hard, makes way too much noise, but doesn't exactly cool very well. I had an F15 X5 was a loaner last week, and the A/C was worse than my E70. Living in Texas, that's enough not to consider buying one, especially with a little one in the back.
What gets me is that I've driven the worst loaners, such as the Chrysler 200 but the A/C just froze me out. |
08-10-2015, 09:49 PM | #75 |
Rep 164
08-10-2015, 11:07 PM | #76 |
Rep 451
The AC in my 2014 X5 isn't really coping with the 90-100 degree weather here whereas my wife's 2014 335 cools in no time. I've tried with rear off/on, can't really tell a difference. When holding my hand to feel how cold the air is coming out of the vents it doesn't really feel too cold in the X5 whereas my hand gets really cold in the 335. Definitely feels as if something isn't right in the X5, will have them look at it next it's in for service.
08-10-2015, 11:26 PM | #77 |
Rep 11,136
08-11-2015, 12:31 AM | #78 |
Rep 1,170
Ford Explorer's A/C is unbelievably cold!
2014 X5 xDrive50i |
08-11-2015, 03:29 AM | #79 |
Rep 52
We’ve had some extreme temperatures here in Luxembourg lately and my A/C dealt with it flawlessly. I always leave my car outside when I’m at work and even when it was 95 degrees and the car was hot as oven, it cooled down pretty quickly. What I always do is to open all my windows and panoramic roof when I’m approaching the car and keep it that way for about one minute drive to let the hot air get out of the car. Then I simply close everything up and leave the A/C in auto mode with temperature set to 63 degrees. If you don’t let the hot air out, your A/C will take much longer to cope with the extensive heat. I only have 2-zone climate with rear fans always open. My space grey color also helps a little
Perhaps US market F15s use different cooling liquid? |
08-11-2015, 08:34 AM | #80 | |
Rep 525
all my lines had pressure, blower works well, they attribute it to -As stated on the service sheet- "air is in proper order. customer has stated weak AC cooling capability, the car cools to spec in reference to a Large Cabin of the X5 and the black interior and exterior color"
08-11-2015, 10:21 AM | #81 |
Rep 431
just an observation ...... this is all very subjective..... what may be useless to one person may well be acceptable to another ..... has anyone actually measured the temperature of the air coming out of the vents as a benchmark ?
08-11-2015, 10:26 AM | #82 |
Rep 11,136
08-11-2015, 10:49 AM | #83 | |
Rep 1,886
I have had the car in the high 90s, and it took a few minutes longer to cool than hoped after it was parked in the sun, but then it was able to maintain temperature well. |
08-11-2015, 12:58 PM | #84 |
Rep 5,066
I have 4 zone climate and for me.. some days it doesn't work well and some days it does.
I have messed around with the rear climate turned off and on.. Good news is it works more times than not |
08-11-2015, 03:12 PM | #85 |
Rep 525
never said it wasnt cold enough!! just not enough of it! i will take my laser out tonight to test it
08-11-2015, 07:11 PM | #86 |
Rep 172
Stand by my original post. A/C in the X5 is a joke. Have black/black in Southern California and it barely keeps up. Worst a/c in a BMW I have ever driven. No complaints about prior X5 which was fine. This is prob last BMW I will buy, this is just one of the reasons.
08-11-2015, 08:18 PM | #87 | |
Rep 1,170
2014 X5 xDrive50i |
08-11-2015, 08:35 PM | #88 |
Rep 172
Indeed! And if the car is left outside for any period of time and even partially heat soaked, the a/c is totally useless. Windshield bad, glass roof worse.
