04-07-2015, 03:11 PM | #1 |
Rep 455
Blind spot indication not bright enough
Does anyone else feel that the blind spot indicator in the mirror isn't bright enough? In my wife's 335 the triangle lights up with a bright yellow light that, even through 35% tints, I notice in my peripheral vision. On the X5 with 50% tint I can barely tell that it's on. I was looking at the code cheat sheet to see if there was a way to get an indicator in the HUD but doesn't seem to be?
04-07-2015, 03:49 PM | #2 |
Rep 1,886
Agreed on all accounts and hope for a HUD solution. I tried transparent red tape to see if it improves contrast when driving with the sun in the rear; my experiment was a fail.
EDIT: Meanwhile, I can see the bright red triangle on the outside mirrors of MBs I pass, and I am 20-50 feet away.
04-07-2015, 04:02 PM | #3 |
176
Rep 360
Drives: 1M; E90 M3 ZCP; M4 GTS
Agree as well. On my now departed 2014 Audi S6, I had the option to adjust the brightness through the MMI...that capability is needed here.
-kskpsu
04-07-2015, 04:30 PM | #4 |
Rep 1,771
It's not only too dim, it's also late or unreliable in certain situations, but too sensitive in others like when there is a car directly behind you or tailgating you, it is vibrating and blinking, I always panic thinking there was someone on my blind spot.
I wish Blind Spot monitoring was an additional option and not a part of a package. HUD solution is not really effective, in my opinion you should be looking at the mirror, so the only solution would be much brighter blind spot indicators. My other theory about why they are dim (but bright enough when flashing) is because it is coupled with steering wheel vibration. I didn't test drive recent MB's but do they also vibrate with blind spot? I was imagining the other day that vibrations were originating from left or right side depending on which side you were steering (off lane or blind spot warning) but if course that's not true.
2024 X3 m40i
04-07-2015, 04:55 PM | #5 |
170
Rep 386
Much like when I had to adjust voltage/resistance sensitivity (through coding) for the LED turn signal bulbs to keep them from constantly blinking, why cant we do the same here? If we could we could replace the bulb with something brighter correct?
04-07-2015, 04:59 PM | #6 |
Rep 5,066
The blind spot warning vibrates? I thought that was only for lane change warning which can be turned off. I only turn that feature on during night time driving when I may doze off or something.
To me the blind spot indicator is not as bright as it should be, but I can see it fine. Other Mfg. do seem to have a brighter LED light which is usually on the side mirrors instead of mounted on the stalk such as ours. |
04-07-2015, 05:08 PM | #7 | |
Rep 1,886
BTW, new Cadillacs have a blindspot-free rear view mirror. |
04-07-2015, 05:35 PM | #8 |
Rep 1,449
If we cannot get a warning in HUD, then I wish for a brightness solution. It does me no good to know the steering wheel will only vibrate too late as I change lanes at the wrong time.
I mentioned this issue to the sales' person as it bothered me on day one.
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
04-07-2015, 05:41 PM | #9 |
Rep 455
Good to see I'm not the only one. I even asked my service advisor today and he said there was nothing that could be done in terms of brightness. He also acknowledged that the 3 series blind spot indicator is much brighter but had no insight into why the F15's is much weaker.
04-07-2015, 08:26 PM | #10 |
Rep 95
I've been saying this for a while. The indicator is not bright enough and is also located in a poor spot. MB and some Japanese automakers have it right.
04-08-2015, 12:38 AM | #11 | |
Rep 1,887
04-08-2015, 05:29 AM | #12 |
Rep 5,066
04-08-2015, 06:20 AM | #13 |
Rep 188
But it only vibrates (gently) if you change lanes without signalling or more violently if you signal and there is a car in your blind-spot. If you always signal before changing lanes it will only vibrate if there is a potential collision - isn't that what you want?
06-16-2015, 05:07 PM | #15 |
Rep 1,886
I used the contact form and sent a polite note complaining about he inadequacy of the light. Others feeling the blindspot warning light is not adequate, should do the same.
https://www.bmwusa.com/Secured/Conte...ctaBMWRep.aspx The warning light is even worse than I recall it, having driven the wife's car yesterday. It gradually dims up and dims down, as if a courtesy light, or an old incandescent bulb. With the sun behind you, it is completely pointless. The warning should additionally be appear in HUD if they cannot fix it. Meanwhile, I can see the red triangle in MB mirrors from several car lengths back.
06-16-2015, 10:27 PM | #17 |
Rep 31
On my f16 it's ok. I wouldn't say it's bright, but it is noticeable when looking in the mirror.
I don't really trust it anymore, as others have mentioned its not a very good system. light comes on slow... goes off slow, and does not recognize stationary objects when making turns with your blinker on and vibrates my steering wheel. Sometimes it reports that there's a car in my blind spot and there's nothing there, but I think it's catching the car one lane over. The system needs much improvement before i trust it. My former 12' acura mdx bsd was much much better. oh and i had to code my car so the bsd works at lower speeds. |
06-16-2015, 10:47 PM | #18 |
53
Rep 343
My light is perfectly visible on an F15...its not overly bright, but bright enough in daylight to see without issues. My works well, I generally look at the light before looking in the mirror and every time the light is on, a car is in the lane next to me. I haven't yet experienced the opposite.
2015 X5 35i M Sport
06-17-2015, 12:06 PM | #19 | |
Rep 1,771
Another alternative would be to have a camera view with distance markers on HUD or dash display when the signal is turned on.
2024 X3 m40i
06-17-2015, 06:37 PM | #20 | |
Rep 431
06-18-2015, 12:49 AM | #21 | |
Rep 1,771
I also initially thought HUD indicator is not necessary, but over time I realize it could be useful. You will see when you get your X5, I am not sure if you were referring to blind spot monitoring on mirrors for the slow speeds or not, but the minimum speed for blind spot to be active is way too fast, believe or not, 30mph is actually pretty fast and serious accident can occur at those speeds and the blind spot monitoring is not active unless you go faster. (I forgot the exact speed) I was able to code it to turn it on at lower speeds. It's on always, regardless of speed in all other vehicles. (as far as I know)
2024 X3 m40i
