10-07-2014, 07:56 PM | #243 |
Rep 1,759
You know where the instructions say "Look for EDIABAS folder in your downloaded E-Sys,"
I don't have this folder in E-Sys installation.
2024 X3 m40i
10-07-2014, 07:58 PM | #244 |
Rep 3,990
That's an old instruction. You don't need EDIABAS anymore. It's just a diagnostic tool, and I have included the information about ESYS's own diagnostic/code clearing tool in the OP.
10-07-2014, 08:12 PM | #245 |
Rep 1,759
Thanks!
2024 X3 m40i
10-08-2014, 04:37 AM | #247 |
Rep 113
Drives: 16 M3, 15 X5 3.5d
Coding Help
Anyone out there willing to code a few options for me when I receive my X5? I am located in Germany.
Thanks |
10-08-2014, 04:53 AM | #248 | |
Rep 208
10-08-2014, 10:13 AM | #249 | ||
Rep 1,133
It's good to be bad
10-08-2014, 11:33 AM | #250 | |
Rep 208
I didn't get my permanent tags yet temp tags are expired dealer's licensing department has an awesome woman who doesn't work at all ... its a long story ... finally she sent the registration document last friday. talked to DMV today and they asked me to come in tomorrow and will be getting my tags over the counter. i will be coding the features today and will do the test tomorrow night.. will post the results in a day or two. any suggestions on how to test it? i am planning on going in a 2 way local road with HBA on and it should do the splits. I will ask my wife to make the video for us to analyze it. sorry for the delay .. having the car but no tags kind of sucks |
10-08-2014, 03:28 PM | #251 | ||
Rep 1,133
It's good to be bad
10-11-2014, 01:01 PM | #252 |
Rep 1,886
Mac / Macintosh Installation
More Mac guidance using VMware (vs Bootcamp) to replicate Windows on the 6th PDF linked here: http://www.bimmerfest.com/forums/sho...d.php?t=654990
Sorry, @Opasha for throwing this in there, but it can possible go in the first page with other Mac instructions. |
10-11-2014, 04:14 PM | #253 | |
Rep 3,990
Just added it to the OP.
10-11-2014, 04:45 PM | #254 |
Rep 3,990
Thread updated with F15 coders by location that you can contact. PM me if you would like to help and be on this list. Thank you .
10-11-2014, 06:28 PM | #255 |
Rep 14
Just got my first lesson in coding thanks to Hang0ver, had a whirl-wind training session (where most of the info has already left ) but had a few questions:
1) we coded the variable light distribution (correct me if I am wrong Hang0ver) and when I turn the steering wheel to the right, the lights follow the input of the steering wheel and turn, but the headlights do not do that when I turn the wheel to the left. Is that normal? or did I forget to code something other than KAFAS2, BDC_BODY, LHM, and TMS?? (I hope I have all that typed down correctly) 2) For some reason the KAFAS2 folder would show up sometimes, but then we would go and look for it, and it was not there. Had to disconnect and then re-connect to have the folder show up again. Is that due to some kind of timeout? Thanks! |
10-11-2014, 06:32 PM | #256 | |
Rep 3,990
1) Yes, that is normal. They operate at a set MPH. 2) Under what conditions does it appear and disappear - is it before you enter your PIN in or after where it appears or disappears. More details will help.
10-11-2014, 06:37 PM | #257 | ||
Rep 208
That's pretty weird. |
10-11-2014, 06:52 PM | #258 |
Rep 3,990
Ok, so it's there before you READ ECU? Or after you READ ECU?
10-11-2014, 07:07 PM | #259 | |
Rep 208
10-11-2014, 07:09 PM | #260 |
Rep 3,990
Here's what I'm thinking. After you VO Code...things go back to factory settings right? I think the KAFAS camera take a bit longer to restart whenever you change anything with it, so the system probably does not read it immediately as it's restarting (therefore, disappears). That makes the most sense.
10-11-2014, 07:21 PM | #261 | |
Rep 14
I also should have mentioned, this was just sitting stationary in the friendly confines of my garage (so I could see the headlights move ) so I have not tested the left side at speed yet. But as long as it's acting normal... whew! |
10-11-2014, 07:24 PM | #262 | |
Rep 3,990
I do all my coding in my garage as well with AC Power on usually. If it gets really hot in my garage/car from the weather or I need to code A LOT of things at once, I turn my engine on so that the battery is not affected.
10-11-2014, 09:28 PM | #263 |
Rep 3,990
Ok, @skalberti just finished testing his car after converting his CAFD all to Euro spec CAFD files (thanks to @shawnsheridan), and he found that the Anti-Dazzle (GFHBA) is not codeable for any non-Euro vehicle. It appears that we don't have the HARDWARE (the headlights for the Euro cars seem to have a different part number and have a specific module that deals with the Anti-Dazzle feature). It seems that the biggest issue that we have been facing is the blinding of the driver ahead of you. As you have seen in @CatFlap's video who has the European headlights, a black shadow box is created around the vehicle in front of you to avoid blinding them when the high beams are engaged. From the members that have tested on their US LED cars, that box is non-existent, therefore blinding the front person. It seems we're out of ideas. Anyone who knows coding and has an LED car tested correctly, please post a video or comment if you have this black shadow box. Thanks.
10-12-2014, 01:21 AM | #264 | |
Rep 208
