02-18-2015, 06:38 AM | #23 |
Rep 1,448
Another one bites the dust ... 2015 X5.
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
02-18-2015, 08:09 AM | #24 | |
Rep 450
My blades are sprung, the backbone is in like 3 parts that can articulate to fit the windscreen shape. Like I said, never had an issue with mine unless the wipers are frozen stopping the articulation. Has anyone else with a RHD F15 seem this wiper issue or is it isolated to LHD versions? |
02-18-2015, 08:33 AM | #25 | |
Rep 781
02-18-2015, 08:55 AM | #26 | ||
Rep 205
02-18-2015, 10:21 AM | #27 | ||
Rep 1,746
Also, at the airport, I always have to place my plate on my dash because even with EZ Pass they are required to record tag #, so in several cases the booth guy had to step out and manually write my tag number off my windshield sticker.
02-18-2015, 10:36 AM | #28 |
Rep 1,746
Friends over at Bimmerfest have the same issue:
http://www.bimmerfest.com/forums/sho...d.php?t=827300
02-18-2015, 01:07 PM | #29 | |
117
Rep 324
I guess you have the new small tag like hyde posted before... Mine is the traditional one, hard to hide. |
02-18-2015, 01:10 PM | #30 |
Rep 1,886
Mine are fine. But between the two threads (many reported cases on bimmerfest here) it is clear something isn't.
My guess is that it is the (mis)shape of part 2 in the diagram below, and/or poor install of parts 4 and 2. Parts are interchangeable with the F16 only. Click on "Appliance" to see models in which the wiper system fits: http://www.etk.cc/bmw/EN/search/sele...27/61610039697 |
02-18-2015, 01:14 PM | #31 | |
117
Rep 324
I'm not sure if it's going to work well here. First of all, the gate won't lift up if the tag isn't read. More than half of tolls still use gates. Second, the possibly additional fee may be added and I won't be able to enjoy the EZ-rate. The official website also says so. From https://www.e-zpassny.com/en/about/terms_ind.shtml "You must properly install your Tag in or on your vehicle pursuant to the mounting instructions provided with your Tag(s). Failure to do so may result in your Tag not being read in the lane, the gate not being raised at some facilities, and may result in a violation for which you may be assessed administrative fees or other penalties as provided by law. Failure to properly mount your Tag may also result in images being taken of your license plate to identify the registered owner and the addition of your license plate to your Account based on motor vehicle registration records. These images may be used to post toll charges at the cash rate and/or additional administrative fees to your Account." |
02-18-2015, 01:49 PM | #32 | |
Rep 1,746
02-18-2015, 02:07 PM | #33 | ||
Rep 1,886
02-18-2015, 02:24 PM | #34 | |
Rep 55
Regards, Niclas |
02-20-2015, 10:40 AM | #35 |
Rep 1,547
No issues here on my F15 X5...only area the passenger wiper struggles to clear is the last 1-2" from bottom at the furthest point (tip).
02-20-2015, 10:55 AM | #36 |
Rep 450
That blade looks the same as mine, two sections are articulated, one at each end.
What do service say? I haven't checked but are the blades the same length, if they are has anyone tried swapping them over so make sure it isn't a blade issue. |
02-21-2015, 11:55 AM | #37 |
Rep 423
I just checked and the driver side is 24" and passenger side is 20"
2015 535d Xdrive Sophisto Grey Metallic
-DUDMD Stage 1 -xHP Transmission Flash 2014 X5 50i Carbon Black/ M Sport -BM3 Stage 1 |
04-02-2016, 08:49 PM | #39 |
Rep 440
Has anyone tried the Bosch Icon wiper blades? I have used these on my Audi with great results. I plan to replace the crappy OEM wipers with these
. http://www.autozone.com/ignition-tun...?checkfit=true |
04-02-2016, 10:11 PM | #40 |
Rep 289
same here EU spec car 2016....
design flaw I guess, the wipers are outsourced by third party sub supplier anyway. but still, made me wonder how this could be worse on the F15 then on my previous E70 |
04-03-2016, 11:46 AM | #41 |
Rep 440
http://www.tirerack.com/wipers/detai...oModClar=xLine
These are the wipers I purchased for the car and will be putting them on this Tuesday. Bosch ICON wipers in my experience perform a lot better over OEM in cold, sleet, rain, and snow. They also last 4-5 months longer then the 6 months on OEM wipers with Audi and BMW etc. I will update you guys on my impressions with these on the X5 with the snow this week. |
04-03-2016, 08:34 PM | #42 |
1150
Rep 2,426
When the blades are warm. I lift them up sometimes, clean them, flex them a little, and set them back on. I think this helps.
04-04-2016, 07:57 PM | #43 |
Rep 137
Same issue on my '16 X5, about 6" swath in the upper right side of the passenger side wiper barely touches the windshield, leaves lots of streaks. Doesn't sound like BMW has done anything to fix this.
04-05-2016, 07:41 AM | #44 |
Rep 53
This is not so big problem. There is difference in adjuster of wiper. Get it changed and your problem will be solved. If want more satisfaction get it checked from auto electrician.
