02-02-2015, 03:47 PM | #1 |
Rep 117
M Performance Brakes
Have any of you had the M performance brake kit installed on your f15? If so, could you give some feedback? Is it a big/worthwhile improvement over the stock system?
02-02-2015, 10:14 PM | #3 |
Rep 18,716
@SpdAddictRY, I had it in my car, but then upgraded to Brembo.
I do suggest you to upgrade since I just drove a 50i with RaceChip installed. It seriously need a braking upgrade and MPBK is the economical way to obtain that.
02-02-2015, 11:10 PM | #4 |
Rep 117
Thanks for the responses. I'm likely to add the Dinatronics Stage 1 tuner down the road, and figure if I'm going to upgrade the brakes I might as well get them covered under the initial warranty.
02-02-2015, 11:27 PM | #5 |
Rep 1,377
I've had them on mine for pretty much the entire time I've owned my truck. To me they were a worthwhile upgrade. Add in that they're covered by factory warranty and it's a strong value.
I drive aggressively (defensively, really). In the city they help when dealing with errant drivers.
02-03-2015, 11:19 AM | #7 | |
Rep 117
02-03-2015, 11:46 AM | #8 |
Rep 1,377
Installed myself almost immediately after delivery. Brought to the dealer after to update the VO in the car to indicate sport brakes and also warranty coverage.
02-03-2015, 11:50 AM | #9 |
Rep 1,886
There are some amazing people in this forum with immense breadth of skills. I think you said you were a tech investor. You can also install complete brake kits. what can i say....impressive.
02-03-2015, 02:35 PM | #10 | |
Rep 609
Joe |
02-03-2015, 02:36 PM | #11 |
Rep 609
02-03-2015, 02:47 PM | #12 | |
Rep 1,377
Good news is that the X5 M I'm expecting has most of the goodies I put on the X5 already installed - big brakes, 21" wheels, etc.
02-03-2015, 02:52 PM | #13 |
Rep 3,990
I agree. I'm going to let my stock brakes wear out since they're still very new and then upgrade to the MBBK later .
02-03-2015, 03:00 PM | #15 |
Rep 3,990
True, I wonder how much that will cost though. Knowing BMW...most likely not cheap .
02-03-2015, 03:05 PM | #16 |
Rep 535
02-03-2015, 03:07 PM | #17 |
Rep 3,990
That I know . However, considering that information, it's been around for much much longer. The F85 X5M isn't even delivered yet to many members, so like all car manufacturers, their new products will always be more expensive .
02-03-2015, 04:49 PM | #18 |
Rep 741
The M50d brakes are different to other models
Brakes, front Twin-piston floating-calliper disc brakes Diameter mm 385 x 36 / inner-vented Brakes, rear Single-piston floating-calliper disc brakes Diameter mm 345 x 24 / inner-vented where as the 30d has Brakes, front Single-piston floating-calliper disc brakes Diameter mm 332 x 30 / inner-vented Brakes, rear Single-piston floating-calliper disc brakes Diameter mm 320 x 20 / inner-vented So I was tempted to upgrade the brakes, however if there is any need I will wait until the stock version is ready to replace. The Blue M callipers do look great though :-)
2018 G30 540i M Sport X Drive
2020 G05 X5 30d M Sport |
02-03-2015, 09:54 PM | #19 |
Rep 117
Did you have a friend at the dealership who helped you out? My dealership wants over 11 hours (at $160/hour) of labor to install the M performance parts. They said the only way it will be covered under the 4yr/50k warranty is if they install the parts before delivery. Otherwise, they will be subject to just a 2 year warranty if installed after delivery.
02-03-2015, 10:07 PM | #20 | |
Rep 18,716
02-03-2015, 10:09 PM | #21 |
Rep 117
02-03-2015, 10:13 PM | #22 |
Rep 18,716
Ahh, that make sense. CF parts won't be that easy though.
