02-10-2015, 04:05 PM | #1101 | |
Rep 3,990
02-10-2015, 04:15 PM | #1102 | |
Rep 6
This are the steps I used http://www.bimmerfest.com/forums/sho...26&postcount=2 |
02-10-2015, 04:19 PM | #1103 | |
Rep 3,990
02-10-2015, 06:04 PM | #1104 |
Rep 17
First, thank you for providing all the information here on how to code the F15. I have done quite a bit and it works GREAT!
Is there a setting on the F15 that disables the dimming of the control display (Nav Screen)? Something I did disabled it. I must of done something wrong. Thanks Last edited by gww50; 02-10-2015 at 07:24 PM.. |
02-10-2015, 07:40 PM | #1105 | |
Rep 3,990
02-10-2015, 08:03 PM | #1106 | |
Rep 17
Have you done any European light flasher mods - the double flash? |
02-10-2015, 08:08 PM | #1107 |
Rep 3,990
I removed the flasher emergency brake coding from the cheat sheet because it doesn't play nicely on US cars.
02-10-2015, 08:19 PM | #1108 |
Rep 1,886
Good move. I would think it interferes with Brake Force Display. We don't have rear fog lights, and no amber rear lights......we know all the wiring and the hardware is different for the rear lights.
02-10-2015, 08:48 PM | #1109 |
Rep 3,990
Yeah, too many people were experiencing these errors due to missing components when it was activated/used. Everyone should delete their old cheat sheets and download the latest version. I'll keep adding to it as I go along, but I updated it a few days ago and it's current with everything including some of the new codes discussed.
02-11-2015, 10:35 AM | #1110 | |
Rep 17
02-11-2015, 12:30 PM | #1111 |
Rep 3,990
Yeah, I understand the code you're looking for now. I looked for it and could not find anything remotely close to that code. All of the flash blinken coding is a bit complicated and nothing related to "one blink" to change to "two blinks." BMW loves to complicate coding .
02-11-2015, 12:49 PM | #1112 | |
Rep 1,886
I've seen the code somewhere but it may have been for e series. better shown here
02-11-2015, 01:17 PM | #1113 |
Rep 3,990
Yep, that's what he is referring to. I looked through all of BDC_Body and found nothing.
02-11-2015, 01:21 PM | #1114 |
Rep 1,886
Re double flash, this is from e series: ALSZ BLINKIMPULS_WARNBLK wert_04. Was werte_01
02-11-2015, 02:16 PM | #1115 |
Rep 3,990
Yep, searched "warn" and "blink" and nothing like that in BDC_Body, unless they decided to be sneaky and throw it somewhere where it is not supposed to be, lol.
02-11-2015, 07:35 PM | #1116 |
Rep 28
Opasha, I remember seeing a cheat sheet code from changing the voice from US voice to British voice. I don't see that on your cheat sheet on page 1. Is there a new cheat sheet I need to download? I'm meeting R33 this weekend and want to make sure I get that feature. maybe I saw it on another model's cheat sheet? I think I'm going bonkers!!!!
02-11-2015, 07:38 PM | #1117 | |
Rep 3,990
02-12-2015, 12:10 AM | #1118 |
Rep 3,990
Just figured out how to keep the codes so they don't get erased. I know Shawn explained that when they update software, it reverts back settings, but it's a good way to test. I just tested and VO Coded ddavtian's HU_NBT folder after I fdl coded everything. This erased all his settings. Then, from the new CODED CAF FOLDER I backed up (the same way I backed up the original CAF folder when I read coding data of his factory CAFD files), I restored the HU_NBT coded files. Simply right click the HU_NBT folder (or any other ECU folder you need to restore), selected NEW, then the long line (must not be greyed out- if greyed out, simply READ ECU again), which gave me access to to any CAFD module location. I selected the backed up CAFD HU_NBT file and simply hit CODE FDL - voila....everything he lost returned coded without me having to individually go in and recode every single thing by editing fdl.
02-12-2015, 12:15 AM | #1119 |
Rep 1,746
To be honest, that draws a lot more attention compared to single on/off hazards, it also can be used to indicate the difference between "I am just chillin' here, waiting for my wife to come out of this shoe store" vs "I need help, something is wrong".. (In this case, it can still be used in wife-in-shoe-store situation, but let's stick to actual emergencies)
02-12-2015, 12:19 AM | #1120 | |
Rep 3,990
02-12-2015, 06:04 AM | #1121 | |
Rep 40,785
02-12-2015, 06:06 AM | #1122 |
Rep 3,990
Yes, you're right. This I understand. Do all the files change or mainly the ones that were trimmed/updated like HU_NBT, which is not functional without adding cafd_00000ded.caf.003_013_025 into the the psdzdata\swe\cafd folder?
