01-17-2015, 03:16 PM | #1013 |
Rep 545
01-17-2015, 07:42 PM | #1014 |
Rep 3,990
PM sent .
01-18-2015, 12:01 PM | #1017 | ||
Rep 3,990
nameisjae1, 예 Cap! Ashot12, you are most welcome, my friend .
01-19-2015, 12:51 PM | #1019 |
Rep 3,990
Yes, it works for the X5 M50D. It's the same platform for all F15s. PM sent .
01-20-2015, 09:48 AM | #1020 |
Rep 1,886
Easy coding with Android devices. I don't think I have seen this in our threads. Could be worth its own thread:
http://www.bimmerfest.com/forums/sho...08&postcount=6 I suspect you don't have access to all coding functions. |
01-20-2015, 10:07 AM | #1021 |
Rep 34
My dear mr.Opasha
I live in Saudi Arabia, my maps does not show traffic information . Do you know if I can activate it by coding? Google map traffic work in my country, does BMW use traffic information from Google? Thanks |
01-20-2015, 10:39 AM | #1022 |
Rep 578
You need 6AK and 6AM options activated...I am not sure if that can be coded... let's wait for Opasha
01-20-2015, 01:27 PM | #1023 | ||
Rep 3,990
1) HU_NBT / NAVI_TRAFFIC_INFO_MAP / nicht_aktiv to aktiv 2) HU_NBT / TI_CA_TMC / nicht_aktiv to aktiv 3) HU_NBT / TI_VINFO / nicht_aktiv to aktiv 4) HU_NBT / TI_TMC_REGIONAL / nicht_aktiv to aktiv 5) HU_NBT / TI_FALLBACK_DISABLED / nicht_aktiv to aktiv Trojanlaw, I've added the Sport Auto Transmission and Launch Control coding to the cheat sheet .
01-20-2015, 01:40 PM | #1024 |
Rep 578
Good to mention... Since I retrofitted NBT a month ago, I did the "Clear all DTCs" function in ESYS, and I thought it was ok...but las weekend my buddy used ISTA/P to scan my car and appeared like 6 error messages...most of them, because of disconnecting CIC cables...so, be careful if you retrofit any hardware, because the only way to clear those error codes, is using ISTA, not ESYS.
01-20-2015, 02:10 PM | #1025 | |
Rep 3,990
01-20-2015, 02:27 PM | #1026 |
Rep 7
Excellent thread opasha
I had my first attempt at the coding and I was unsuccessful Here's a little brief. I have a 328xi 2013 model I believe it was manufactured back in 2012 september. It has both 609 and 6NH. I wish to enable EBT on the car and if possible BMW remote and BMW office apps. I connected the ENET cable, powered up the ESYS 2.26.1 version and it connected successfully. The FA read was successful and I saved the files. I saved the SVT files too by reading SVT files. Next, clicked on the CVT tree and hit red coding so that I have the built in coding info for the car. it popped up one error as shown in the picture. Now I'm stuck. is there anything that I missed or something that I need to fix before I can proceed further or it is none of the concern? Any help is highly appreciated. Thanks |
01-20-2015, 02:30 PM | #1027 | |
Rep 3,990
01-20-2015, 03:21 PM | #1028 |
Rep 7
01-20-2015, 03:27 PM | #1029 |
Rep 3,990
01-20-2015, 07:21 PM | #1031 |
Rep 95
I ordered a nicely loaded 2015 X5D a week ago. I find the BMW blind spot monitor indicator (on the mirror casing) to be inferior to Mercedes ML and many other manufacturers. The Mercedes being a red light also helps as opposed to the dim yellow on a BMW. I currently have a 2013 750i M-sport and I find the blindspot indicator to be dim and just plain hard to see especially in my peripherals. Is there a way to code the indicator to be brighter?
01-20-2015, 07:22 PM | #1032 | |
Rep 3,990
01-20-2015, 07:31 PM | #1033 | |
Rep 95
Changing the bulb to something with more intensity like LED or even in colour red was something I thought of. I just don't want to take apart the mirror housing and open a can of worms so I thought coding might be a good alternative if possible. If you or someone has a parts diagram for the mirror maybe I can run that idea by my mobile audio shop. Thanks again! |
01-20-2015, 07:36 PM | #1034 | |
Rep 3,990
