11-04-2014, 02:29 PM | #23 | |
Rep 1,746
No please don't install a train horn, that's really annoying. You can get a different type of air horn but train horn is just overkill especially for a BMW. It sounds good until someone throws a big rock at your car, even in case of danger I think it just creates more dangerous situation by scaring other drivers. Just check trainhorn scare videos, after first couple of scares it's super annoying. When you take delivery at PC please ask more than one person to see what kind of answer you will be getting about horn delay. BMW is the only vehicle that I know of with this horn delay.
11-04-2014, 03:32 PM | #24 |
261
Rep 733
Yep, you're right about the train horns.
I WILL be asking about the delay. We hope to meet up with some of the other half dozen people picking up at the PC in the morning. Hoping they may be aware of the issue,too. If not, they will be. Update: Mentioned the delay during our delivery experience on 11/5. Received no acknowledgement that there is a problem. Last edited by F15GorDe; 12-15-2014 at 01:49 PM.. Reason: Update |
11-04-2014, 04:42 PM | #25 |
Rep 3,990
Awesome .
11-06-2014, 03:38 AM | #26 | |
Rep 658
To be honest i haven't noticed any delays in acceleration (in comparison to what I had in the E71 where the lag was somewhat annoying), but the horn is definitely something I wish wasn't there. I know it might be for noise pollution reduction and all but some idiots out there just won't feel anything unless you buzz the horn on their heads. Plus over here with the strong sun beams flashing the light during the day has literally NO effect , so it's pretty annoying to actually have to flex a muscle or two just to honk the horn! |
11-06-2014, 09:50 AM | #27 | |
Rep 1,746
I wouldn't mind so much if the horn button was more sensitive, maybe it needs to be broken in but not only it is delayed, it also has low sensitivity so you really have to punch the steering wheel to get that short beep.
12-13-2014, 07:57 PM | #28 |
Rep 1,886
This annoyed me today as a texting driver was drifting into my lane, and the wake up call I was about to send came later than I wanted.
12-13-2014, 08:17 PM | #29 |
Rep 1,746
Welcome to the club. I wish you had this question in your survey, so all those 93 people could be reminded (if they haven't experienced it yet) how annoying it is.
12-14-2014, 02:12 PM | #31 |
Rep 1,170
And I thought I was the only one! Once, this person in front of me was fiddling with his phone and the left turn green light was on for about 2 seconds. I pressed on the horn and nothing happened. He then took off and finally the sound came out as he was turning. I was embarrassed..
12-15-2014, 05:10 AM | #32 |
Rep 450
I can't say I have noticed any real delay on the horn but one thing I have noticed is a delay when flashing the headlights, to the point where it is almost impossible to get a decent short sharp flash or two.
I suspect it is to do with the Adaptive BiXenons I have as it appears that something is moving inside the headlamp to achieve the flash instead of the more normal lighting of the full beam bulb. Anyone else notice this with Adaptive BiXenons with HBA (not in the US as your headlamps are different) |
12-15-2014, 10:27 AM | #33 | |
Rep 8
More tech features seems to be rather complicated to use the car. So much tech makes me question the dependability of these vehicles, but still, I got 5 year warranty, so I am going to make use of the car for the period I have it. |
12-15-2014, 12:44 PM | #34 |
Rep 1,886
My guess is that that the signal goes through an electronic control unit with a processor first, before it is relayed to the horn. Totally unnecessary as a horn should never fail, and a "horn error" should not popup on the screen ever. Nor is it necessary to overcomplicate and capture data as an airplane blackbox, in case we need to dig up data as to when/where the horn was last used.
12-15-2014, 02:05 PM | #35 | |
Rep 1,746
Here is your ticket. But officer, I did not honk. You go show up at the court with a statement from BMW service center, copy of vehicle logs printed, showing that you did not honk at the time. You win. I rather have an instant honk than have the slight possibility of being able to fight a ticket at court. I wouldn't mind seeing the situation in a TV series. CSI: Miami "Get me the logs of his BMW, I see, he honked at 3:42 PM, then the killer must be Richard!"
12-15-2014, 02:31 PM | #36 |
Rep 1,746
No acknowledgment that there is a problem, but at least they should admit that there is a delay, and the reason behind that? Not even that? "It works as designed" fine can you point us to the direction of the fella who designed this?
02-02-2015, 04:10 PM | #37 |
Rep 1,886
Car has been resting at the spa for over a week as they cannot resolve the parking sensor issue. I also mentioned horn delay when I dropped it off. "Horn what?", said the service advisor then; he could not believe it. He called me today and said they fully acknowledge the horn delay and think a software update should resolve it. I'll let you know when it is done. Not holding my breath.
side note: I noted the catalog lists different horns for EU, and for Russia/India. I am thinking Russia and India are likely louder, possibly higher pitch. The EU version should be a higher pitch......there is a thread on this subject already, but as the kids say these day "just say'n". |
02-02-2015, 04:33 PM | #38 |
Rep 1,181
No way you're gonna get the car back with no delay in the horn. It's not a defect. Service just doesn't know that it's designed that way.
My first real need to honk this weekend and indeed, the delay made things more dangerous than needed (lane drifter).
02-02-2015, 10:49 PM | #39 | ||
Rep 1,746
Welcome to horngate.
02-03-2015, 01:07 AM | #40 |
Rep 1,181
In our eyes, it's clearly a defect. You're right in that we are all assuming this was done on purpose to somehow limit the number of road rage events. Maybe this is just one big bug that flew below the QA/validation radar?
You might just be onto something. A quick search for "BMW horn delay" only yields F15 posts. Even if I change it to the higher post volume of F30 cars, only F15 articles come back. Even more interested in your paperwork now, MattBianco!!!
02-03-2015, 09:06 AM | #41 |
Rep 1,886
This will get resolved if every one of us reports it as a problem.
02-03-2015, 10:22 AM | #42 | ||
Rep 1,746
Pinging Barbja .. Does F16 have this problem?
02-03-2015, 11:00 AM | #43 |
Rep 1,886
Posted a thread in F25/X3: http://x3.xbimmers.com/forums/showth...3#post17337113
02-03-2015, 11:11 AM | #44 |
Rep 666
