11-05-2014, 12:36 PM | #375 |
Rep 1,886
The little red light, if for fog, would usually be on the left tail light in LHD cars. They are not illegal, but BMW for each market chooses either fog or to instead have that feature where the lights get really bright if you brake hard. You cannot have both features simultaneously.
I believe to get them to behave as fog involves both coding, and a new switch. That said, there are some threads about hacking the switch. Sorry....cannot point to them now. |
11-05-2014, 12:39 PM | #376 | |
Rep 3,990
11-05-2014, 03:10 PM | #377 | |
Rep 424
X5 F15 - gone after 5 months!
11-05-2014, 03:27 PM | #378 |
Rep 3,990
That's really strange. Hmm... leave it to BMW to make things harder for no reason.
11-06-2014, 08:11 PM | #379 |
Rep 194
So I removed 5AP and 8S4 from the FA and coded KAFAS2, BDC_BODY, LHM, and TMS in order to get the Variable Light Distribution. I then coded quite a bit of FDL coding. Now I see conflicting information where it says to do this (remove 5AP and 8S4), but also says you only need to remove 8S4 and code BDC body. What I want to know is if I need to add back in 5AP and if so what I would need to VO code again? I'm really hoping I don't need to do any more VO coding as it'll wipe all of my FDL coding, correct?
11-06-2014, 08:25 PM | #380 | |
Rep 3,990
For 8S4 (strictly for VLD), BDC_Body is the only thing you must VO Code. I have researched this extensively and found that LED and Bi-Xenon act the same way for this feature. If anyone has further information, feel free to correct me. Also, any time you VO Code a specific ECU folder, you will lose all fdl coding you have done in that specific ECU folder only.
11-07-2014, 12:34 AM | #381 |
Rep 1,133
11-07-2014, 08:15 AM | #382 | |
Rep 194
11-07-2014, 11:44 AM | #383 | |
Rep 3,990
I've recoded BDC_Body about 5 times already, so I know how you feel, lol .
11-10-2014, 09:17 PM | #384 |
Rep 208
@opasha @skalberti @shawnsheridian
does anyone know what module in F15 is equal to REM in F30? I'm trying to find out how to enable all cameras in all speeds and I have codes for F30 from its cheat sheet |
11-10-2014, 09:33 PM | #385 | |
Rep 18,716
F15 uses 1 big module, the BCD_BODY, while other F series are separated into smaller modules.
11-10-2014, 09:41 PM | #387 |
Rep 3,990
You are correct.
@Hang0ver - For F15, BDC_BODY encompasses REM, FEM_BODY, and CAS.
11-11-2014, 05:38 PM | #389 |
Rep 208
@opasha @skalberti @r33
so, i have been going through these for a while trying to find out .. finally able to figure out where these live. As per F30 coding, we need to configure below values in REM. V_SCHWELLE_1 werte = FF V_SCHWELLE_2 werte = FF D_SCHWELLE_1 werte = FF D_SCHWELLE_2 werte = FF I did a search on each CAFD and found that these are now located in PDC under 300D(PKM) section.. atleast for me. I need to code this and test it out. Will report back. However, I didn't find codes for Front Panoramic camera in F30. So, I was digging through different modules and finally found some in iCAM module. There is one config called FV Panoramic Viewport in 3007 section with below comment Kommentar=- Update the Camera Banding Filter value to 50. - Rename the members from activationSpeedForward_kmh and activationSpeedBackward_kmh to deactivationSpeed_kmh and reactivationSpeed respectively. - Update the deactivationSpeed_kmh to 3.6 and change the type to Float for both CTA-F and CTA-R. Just want to get your thoughts on it. I know these cameras coding is useless, but I just want to find something new and which is kind of fun |
11-11-2014, 05:41 PM | #390 |
Rep 1,133
The camera values listed are in icam and another ECU I believe it's FZL or FZH. I'd have to go back and look for sure. I'm just going off the top of my head, and givin my track record I wouldn't trust that!
It's good to be bad
11-11-2014, 05:43 PM | #391 | |
Rep 3,990
11-11-2014, 06:00 PM | #392 | ||
Rep 208
I think the iCAM is pretty much the front and side camera speed settings. |
11-11-2014, 07:44 PM | #394 |
Rep 3,990
I believe so, but @skalberti feel free to explain further .
11-11-2014, 09:52 PM | #395 | |
Rep 1,133
It's good to be bad
11-11-2014, 10:46 PM | #396 |
Rep 1,746
Thanks, do they all have the same minimum like blind spot throwing error at 10?
