02-21-2015, 12:04 AM | #1169 |
Rep 3,990
Anytime. Yes, since you have either a Euro or 2015 vehicle, seat belt chimes/gongs for front passenger (Beifahrer) coding is all disabled from factory (default).
02-22-2015, 04:47 AM | #1172 |
Rep 3,990
If anyone with US LED headlights is free, PM me. I want to test something new. It may fix the anti-glare high beams.
Here is the coding I want you to test if you know how to do it on your own: 1) Remove 5AP and 8S4 from your FA 2) VO Code BDC_Body, Kafas2, LHM2 (both folders), TMS_03 (both folders) 3) Right click HU_NBT and fdl code the following: HU_NBT / HIGH_BEAM_ASSISTANT / change to aktiv 4) Right click BDC_Body and fdl code the following so your auto high beam assist and glare free activate quicker: BDC_Body / C_HBA_ENA_V_HI / default value = 46 (43 mph) change this to 2C (27 mph) - this is the speed when the HBA enables BDC_Body / C_HBA_ENA_V_LO / default value = 3C (37 mph) change this to 1C (17 mph)- this is the speed when HBA disables 5) If the above doesn't make it work, add this final step: Right Click LHM2 (both of them) and fdl code the following: LHM2 / M14 / change init_US_F015 to init_ECE_F015 LHM2 / M15 / change init_US_F015 to init_ECE_F015
02-22-2015, 10:11 AM | #1173 |
Rep 18,716
@opasha, let me see if I can try them today.
02-22-2015, 04:32 PM | #1174 |
Rep 3,990
You can also try making the HBA HI to 00 (so that it may enable from start) and HBA LO to FF (so that it stays on always). I'm not sure, but maybe 1 button push will keep it on for good then this way? Who knows? I just posted the lower speeds as a starting point. Thanks for testing, buddy.
02-22-2015, 05:08 PM | #1175 | |
Rep 18,716
02-22-2015, 10:39 PM | #1176 |
266
Rep 345
Drives: 2019 X5 40i M
02-22-2015, 11:38 PM | #1177 |
Rep 18,716
On speed went down to 30mph, and Off speed went down to 20mph.
It is a bit hard for me to find out, too much traffic around here. But, that number should be correct. As far as tunneling, still not happening. Only on or off individually each headlight, instead of together both headlight.
02-23-2015, 01:57 AM | #1178 |
Rep 1,886
I have these in my notes from a while back....not sure if worthwhile:
C_HBA_ENA_V_LO werte=18 (15 MPH) C_HBA_ENA_V_HI werte=28 (25 MPH) |
02-23-2015, 08:57 AM | #1179 |
266
Rep 345
Omar has my files. The default for my MY2015 is on at 25 mph and off at 20 mph.
2019 X5 X40iM
02-23-2015, 11:09 AM | #1180 | |
266
Rep 345
2019 X5 X40iM
02-23-2015, 02:04 PM | #1181 |
Rep 18,716
Instead of creating a tunnel on the oncoming traffic like the Euro version, it just turn off the driver side high beam and turn back on once the opposite traffic clears.
By default, it just turn off or on both headlamp during oncoming traffic.
02-24-2015, 04:38 PM | #1182 | ||
Rep 1,133
It's good to be bad
02-24-2015, 04:44 PM | #1183 | |
Rep 3,990
02-24-2015, 04:47 PM | #1184 | ||
Rep 1,133
It's good to be bad
02-24-2015, 05:04 PM | #1185 |
Rep 3,990
02-25-2015, 08:38 PM | #1186 |
Rep 99
Sorry to go off topic from anti-glare but on a similar topic regarding lighting. I tried searching old posts and cannot find any discussion on possibility to code the US based F15 rear tailights to light up the "panic light" everytime you brake, whether normal or hard braking. In other words, light up the "rear fogs" everytime we brake. Ive seen a few f15 hard brake in front of me and with those add'l lights, it gives car a overall better appearance especially if you have a signal light flashing. This way, there can be a dedicated "brake light" and "signal light".
02-25-2015, 09:58 PM | #1187 | |
Rep 1,746
Before I ask in other forums about this, just wanted to know if you already reached out to anyone about this option? I really would love to have this.
02-25-2015, 09:59 PM | #1188 | |
Rep 3,990
