05-25-2015, 01:11 AM | #2 |
53
Rep 343
are you driving in Comfort mode?
I find the steering way too loose in comfort...switching to Sport tightens it up considerably. On the interstate its a constant job to keep it straight, hopefully this will be addressed in an update.
2015 X5 35i M Sport
05-25-2015, 05:40 AM | #5 |
Rep 781
05-25-2015, 05:53 AM | #6 |
Rep 5,066
I ran 120 - 140 mph from MD to NJ a month ago
By the way no issues of the car moving around at 70+ mph. OP, can you provide more information about your car? 18", 19", 20" all season? Summer? What Line do you have? etc. I do get a slight vibration after 90+ mph.. I believe this is a known issue with some when I was reading the Post your X5 issues here sticky thread. |
05-25-2015, 08:03 AM | #7 |
176
Rep 360
Drives: 1M; E90 M3 ZCP; M4 GTS
Lots of things working against it. As previously mentioned...soft in comfort mode with the most vague steering I've ever felt, uber wide tires (I'm 285 up front, 325 in rear) that follow ruts or imperfections, high profile for cross winds. Overall, pretty planted all things considered...putting the M adaptive suspension in sport definitely helps if you have it.
-kskpsu
05-25-2015, 08:15 AM | #8 | |
Rep 781
05-25-2015, 08:46 AM | #9 | |
Rep 228
05-25-2015, 08:49 AM | #10 | |
Rep 228
05-25-2015, 08:53 AM | #11 | |
Rep 228
05-25-2015, 09:00 AM | #12 | |
Rep 228
I started noticing it on my 400 mile road trip maybe it could be the area |
05-25-2015, 09:50 AM | #13 | |
Rep 1,886
Also see this: http://f15.bimmerpost.com/forums/sho....php?t=1034931 |
05-25-2015, 09:55 AM | #14 | |
Rep 5,066
05-25-2015, 10:00 AM | #15 |
Rep 1,547
No stability issues here, anything more than expected with wide tires. I spend lots of time on the highway travelling for work. I'm typically in Sport mode 95% of the time.
05-25-2015, 11:11 AM | #16 |
Rep 781
Vibration at speed can only come from a balance issue - it may be more pronounced at specific speeds. Check for any of these as imbalance cause:
Improper original balance Missing balance weight Damaged tire or wheel The dealer or any good tire shop should be able to diagnose your problem |
05-25-2015, 05:09 PM | #17 | ||
Rep 1,363
05-25-2015, 05:24 PM | #18 | |
Rep 774
And just to comment on other posts, there is zero vibration and the tyres are therigt pressure and balancedto+-0. |
05-25-2015, 05:32 PM | #19 | |
53
Rep 343
2015 X5 35i M Sport
05-25-2015, 07:23 PM | #20 |
Rep 1,181
For you 120mph+ guys... there's no way I'm getting up that fast unless I was on a stretch of freeway through the desert and could literally see miles ahead. It's never me or my car I'm worried about, rather the yahoos that may do something stupid that I won't have time to react to.
LA to Vegas, def some good stretches to do this, but I'm not familiar enough with MD/NJ Kzang to know whether you have open stretches like in Cali. I wouldn't think so.
05-26-2015, 12:55 AM | #22 |
Rep 1,181
Naturally. Wasn't questioning whether or how quickly we can hit 100mph+. My point was that I'd never hit 140mph unless it was on that open stretch of desert freeway where I could see everything ahead of me for a mile or more. Hell, I get near misses when cruising at 80mph and someone decides to pull into the left/fast lane because they are oblivious.
