07-08-2015, 07:49 AM | #1 |
Rep 748
Applying Rain-X
Last Saturday after 3.5 hrs of driving in pouring rain on Turnpike i decided to apply a Rain-X for the first time ever. Well, followed the instructions, cleaned windshield, applied as stated. What can i tell you, almost immediately ( well first time i turned on wipers) i realized that my wipers are shudder like crazy! To the point they became unusable. Tried to wash windshiel about 10 times with soapy water (car shampoo), cleaned it with windex , used alcohol, nothing, wipers shudder. Went to BMW dealler ( Thompson BMW), told the tech about issue. #0 min later car came back with brand new wipers, and problem gone! Wow, the same Rain-X as i bought is being sold inside BMW dealer showroom.
Any thoughts?
07-08-2015, 07:59 AM | #2 |
Rep 79
I use Aquapel with great results. First I clay the windshield to get all contaminates off so it's very smooth then apply .... Works great and lasts 4-6 months depending on how much rain I'm in.
Here is where I get it but there are tons of places that sell it. http://www.autogeek.net/rain-repellent.html |
07-08-2015, 08:20 AM | #3 | |
Rep 748
07-08-2015, 08:45 AM | #4 |
Rep 5,066
I learned long ago not to use rainx or any other chemical products on your windshield...
RainX used to haze the windshield back in the day and now it affects how the wipers perform. |
07-08-2015, 08:54 AM | #5 |
Rep 5,483
I use RainX all the time on all my cars and my entire family's cars. Never had an issue with it. No hazing, no wiper issues.
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
07-08-2015, 08:57 AM | #6 |
Rep 1,887
I use Rain-X all the time, have for years. I don't have any problems with shudder or any other problems. Works great.
07-08-2015, 09:08 AM | #8 | |
Rep 1,886
I ask because I believe it is mostly a solvent such as ethanol or methyl alcohol, and castor or some other oil. If the solvent does not evaporate, and happens to be a solvent for the type of rubber used on the wipers, it could damage the blade. About 20 years ago someone told me they damage wipers and I never understood why. Your situation was like a clue. I use Maguarie detailer on the windows with decent results.
07-08-2015, 09:22 AM | #9 |
Rep 3,834
I've been using Rain-X 2-in-1 spray can for years on all my BMWs. Never had to replace a single wiper, even at 50k miles. I have heard that if you don't wipe off the excess on the orginal Rain-X, it will deteriorate the rubber of the wipers. That's why the 2-in-1 is much easier to use.
07-08-2015, 12:53 PM | #10 | |
Rep 748
07-09-2015, 05:22 AM | #11 | |
Rep 1,368
07-09-2015, 08:24 AM | #12 | |
Rep 79
Have you ever used clay before? If not you tear off a small piece maybe 1/4 of a bar and flatten it. Use the lube and medium pressure you will feel and hear the difference as you remove the bonded contaminates. Once you do this you'll want to clay the horizontal surfaces of you paint too ... You won't believe the difference. A good test is to place your hand in a plastic sandwich baggy and lightly run your hand over the windshield dry before you start, you will feel and hear all the garbage that is stuck there, then do it again after you finish claying .... Now do the baggy test on your hood .... Hope this helps! |
07-09-2015, 11:20 AM | #14 |
Rep 79
OK you do that, then take a plastic baggy stick you hand in it and wipe across it, then clay that same window and do it again ... Please post your results .... Do you use a safety razor on your paint too?
07-09-2015, 12:49 PM | #15 |
Rep 682
07-09-2015, 02:22 PM | #16 | |
Rep 1,368
I'm a clay virgin so will try it out and be gentle Thanks again. |
07-09-2015, 02:30 PM | #17 |
Rep 748
Again, size zero still wool will never damage you glass, and will produce great result in removing build up from your glass. I was skeptical at first, however ones decided to try. Fell in love right away.
07-09-2015, 04:19 PM | #18 | |
Rep 79
Also use the clay on your paint befor you wax, you'll be amazed. If you ever drop the clay on the ground throw it away, it could pick up a little rock or something and scratch your paint or glass! Here is a nice written thread on a detailing forum from a pro on how to use clay. A good read! It talks about using on paint but use it the same way on glass. http://www.autogeekonline.net/forum/...ling-clay.html |
07-09-2015, 04:42 PM | #19 | |
Rep 748
07-09-2015, 06:02 PM | #20 |
Rep 1,547
I've used both Rain-X and Aquapel, great products...a must in my opinion. I also use a windshield washer solution that has Rain-X built into it, so every time your spray the windshield or rear glass, it re-applies...great product!
07-09-2015, 08:41 PM | #21 | |
Rep 79
Here is a screen shot from the Autogeek forum from one of the nations top auto detailers Mike Phillips who says don't use steel wool, it scratches glass even though you may not see it with your naked eye. He has been the head training guy for Meguires in the past and now Palm Beach Motoring. He has detailed some very famous cars and is one of the best there is. IMO There are better ways to clean glass that is safer and designed to do so. |
07-12-2015, 04:24 AM | #22 | |
Rep 1,368
