      02-13-2015, 12:59 AM   #23
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
Have the 19" PIRELLIs on mine and run F36/R44 with an absolute smooth ride, where possible. Can't do anything about the lousy roads.
      02-13-2015, 07:42 AM   #24
wjbender
wjbender's Avatar
Drives: 2022 X5 40i M Sport
+1 - The ride is quite good, I was expecting a harsh ride as I have never owned a car with run flat tires. All the press on them is negative.
      03-14-2015, 06:59 AM   #25
SUV55
Drives: 2015 X5 35D
This is what I use and it hasn't let me down once: http://www.amazon.com/TEKTON-5941-Di...tal+tire+gauge. It reads out .5-1psi higher consistently on all tires and all my cars. I have one in my mother's ML350 and one in mine. Super easy to use and very light/nice.
Niko, I bookmarked your link just in case since I don't have a spare and plan on keeping that for emergencies as well in the storage area next to my air pump.
Opasha, does this unit have a bleeder button to remove air if the tire is over inflated?
      03-14-2015, 09:13 AM   #26
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
Thanks. Calling opasha
Your link was not working but glancing at the address line I presumed you were linking to http://www.amazon.com/TEKTON-5941-Di...ton+tire+gauge
      03-14-2015, 09:44 AM   #27
SUV55
Drives: 2015 X5 35D
Yes, thanks Matt.
Here is one that is similar to the Tekton, but can bleed air.
http://www.amazon.com/Craftsman-Prog...ref=pd_cp_hi_2
      03-14-2015, 03:13 PM   #28
wjbender
wjbender's Avatar
I hate to disagree with everyone, but you are much better off using an old fashion mechanical gauge. You may not use it until you have a low pressure warning and find the batteries are NG. Newer is not always better i.e digital vs. analog
Here is what I bought
http://www.amazon.com/dp/B003TQ2W44/...pressure+gauge
      06-18-2015, 10:56 AM   #29
wedge000
Drives: N/A
Originally Posted by opasha View Post
Yeah, then you should be running a little lower than what is suggested. I wouldn't go that high. You will have crazy vibration/noise. This topic has been discussed for a while last year and the safe medium is around 34-36 for the front and 40-42 rear for cars with 19-20" wheel.
I also am sorry with the irresponsibility they showed on your service. Unfortunately, careless service departments exist and some people just don't care as much as they should for their customers.
Sorry to rehash an old thread. What would you recommend for PSI on the 18" OEM run flats? Also, after getting a rear tire replaced, I noticed that the PSI difference between left and right (on both front and rear) are off by about 1 PSI according to the TPMS. How accurate is that sensor? Should I care the left/right differ by about 1 PSI, or is that an 'acceptable' difference between them?
Thanks.
      06-18-2015, 07:03 PM   #30
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
Originally Posted by ocman
Good to know. I got pirrelli 20 inch rft on the x5.
Does anyone know what 2/32 wear means?
Tire tread depth is measured in 32nds. So the average tires tread depth is 11/32 - 10/32. So if you get a flat in the first 2/32 of tire wear, it is covered under warranty. 4/32 your tires are close to worthless on snow and water.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      06-18-2015, 07:58 PM   #31
wjbender
wjbender's Avatar
Thanks.
Use a quality tire pressure gauge to measure - TPMS is not ver accurate
      06-19-2015, 10:58 AM   #32
wedge000
Drives: N/A
Thanks, I'll pick up one of the ones referenced in this slide. Any idea as to suggested PSI for the 18" RFTs?
      06-21-2015, 09:34 AM   #33
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
Also you will notice when your tires heat up or get cold the pressure changes as it should.
