03-01-2015, 07:23 PM | #23 | |
Rep 3,990
Then, when I lock the car, the car completely shuts off including the brake lights, gps, and radio (kind of like the old discussion everyone had last year about one button push and then just locking the car to completely shut it down if they forgot two button pushes).
03-01-2015, 07:34 PM | #24 |
Rep 3,990
@r33 (they really need to get your screen name tagging fixed) Ben, I showed Eddie your info. When I take it to him tomorrow, I will make sure he tightens everything. He said he used the right schematics that you showed and assembled everything back the way it should be, but I guess something is loose. The misalignment is also causing my car to be a bit wobbly. I need to get that aligned. Should I get it aligned at my local tire shop (the ones that put on my 22s properly and aligned it perfectly before) or should I drive it all the way to BMW (an hour away) and have them align it, check the struts, and check this break error (killing 3 birds with one stone).
03-01-2015, 07:50 PM | #25 |
Rep 1,181
The key is... #11 needs to be tightened when a) the spring was still compressed, or b) under load (something Ben accomplished by using a jack to raise the bottom of the strut). I'm sure your buddy will get it sorted out.
Brake light issue is a weird one for sure. What happens if you shut the car down while the brake pedal is still depressed?
03-01-2015, 07:58 PM | #26 | |
Rep 3,990
03-01-2015, 08:34 PM | #27 |
Rep 18,716
@opasha, I know, my name somehow is not working. LoL.
Here, check the #10 in this attached diagram. You may this stuck close or shorted.
03-01-2015, 08:44 PM | #28 |
Rep 3,990
That's the odd part, Ben. When I return to the car after is has been locked for some time (I haven't really timed it). When I press one button push, it turns AC POWER ON the way it should. It only does this odd behavior after the engine has been started. So, it can't be that #10 module is shorted if it works correctly after being locked for some time right? It doesn't make any sense at all. Something with the engine starting is confusing the car and preventing it from shutting down.
03-01-2015, 09:37 PM | #29 |
Rep 7,063
Finally gets car back, now riddled with problems. Time to drop it off at the dealership and lock your threads so they can never see your mod journey, hello service advisor and "It's under warranty I expect it working"
03-01-2015, 09:44 PM | #30 |
Rep 1,886
opasha r33. I have r33 on a note so I can copy and past the code: which is: @[r33](contact:76551 with parentheses closed after 76551.
03-01-2015, 09:59 PM | #31 | |
Rep 3,990
Thanks, Niko .
03-01-2015, 11:34 PM | #32 |
Rep 286
Oh no, opasha! I'm so terribly sorry to read about the woes pertaining to your car. I'm sorry I don't have anything helpful to add (remember, I'm the one whose technical inclination stops at the level of using a calculator), but I will keep my fingers crossed for you to have all of these sorted out.
I sincerely hope you don't give up on the X5 - you've been such a source of inspiration to so many - and I hope your car will be "reborn" to give you many happy miles more to come. Good luck, my friend! |
03-01-2015, 11:45 PM | #33 | |
Rep 3,990
Since I never started the engine, I was able to press the Start/Stop button once to completely shut off the car and leave it unlocked. I will check on it tomorrow morning to see if the coding fixed it. If not, then yes, a dealer visit will be 100% necessary. Here's to hoping .
03-02-2015, 05:35 AM | #35 |
Rep 3,990
I just got back from driving and starting and shutting off the car. The VO Coding of every ECU folder except DME did not work at all. Also, the car alignment is very very off to the point where the car shakes slightly (almost like when you hydroplane despite the road being clean pavement) every few seconds (I assume this is due to every rotation or so where the wheels are going against each other or in a different direction than the steering wheel). For safety, I believe I will have to get my local tire shop (that mounted and balanced/aligned my 22s before) to re-align everything. Then, remove my 6WB (so they can use ISTA/P software to reprogram the car) and my RaceChip. Then, I will have to pay BMW a visit. What a pain in my rear end .
Despite this, I still love/enjoy this car. D setting is phenomenal. It handles like a champ on the icy roads without needing traction control mode (leaving DSC on). I tried to turn it off and see what it did, but it just made the car more shaky due to misalignment, so I will retest this feature when aligned. Stay tuned and thank you for following my roller-coaster journey .
03-02-2015, 05:51 AM | #36 |
Rep 1,417
Hey Omar, nice to see that for the love of the car it is all worth it, just takes time & a bunch of patience. Ensure the roller coaster is not an hour drive on icy roads, even with your Delintes.
Best, |
03-02-2015, 05:58 AM | #37 | |
Rep 3,990
The car not turning off with two buttons pushes could have been much worse. At least I can still tap one push, get out, and press lock for it to completely shut down. I'll miss the car again....
03-02-2015, 06:51 AM | #38 |
Rep 286
opasha, thanks for the update - for the many of us who are eagerly following this saga, we're obviously disappointed that things didn't quite work out as hoped - but, chin up, you have the combined best wishes of the forum community going with you on those icy (but well cleared) Maryland roads to the dealer for rectification works!
Drive safe, my friend! |
03-02-2015, 06:57 AM | #39 | |
Rep 3,990
03-02-2015, 07:16 AM | #40 |
Rep 286
You are most welcome ... and, there's a saying, misery loves company, so I thought I'd just share the (my) misery around and hopefully cheer you up a bit - this just happened 2 days ago, and my F13 is now stuck at the work shop. Apparently, some fan-cooling-thing failed for the LED light, and BMW is changing it under warranty (just as well, because the 3 year warranty runs out in a week's time!):
Hope you'll get your car back in tip-top shape again soon! |
03-02-2015, 09:49 AM | #41 |
Rep 781
Omar - Sorry to hear that VO coding didn't fix your issues. You are a resourceful and persistent guy and I know you will get it sorted out. What a pain to have to go through this.
03-02-2015, 09:53 AM | #42 | |
Rep 3,990
Thanks, Bill . Yes, it is rather annoying, but hey, that's life. What doesn't break you makes you stronger . To top it off, my rear view dash camera is upside down! Pretty funny that we didn't notice this when we installed; to be fair, the trunk was open and the camera angle was facing straight to the ground from the raised glass (it was late when we did the install)....I know, I know ---> .
03-02-2015, 10:06 AM | #43 |
Rep 1,886
can you at minimum work with the dealer to get the 6WB to be recognized as part of the car since they are offering the cluster as an upgrade on existing models? There is no way they swap back and forth on cars they upgrade.
03-02-2015, 10:11 AM | #44 |
Rep 3,990
I'll have to call and ask my SA and see what he says.
