      02-20-2015, 11:26 PM   #1167
opasha
opasha's Avatar
1329
Drives: 2014 BMW X5 50i
Originally Posted by OuKEnFoLdMX View Post
to chime on 3 both
PM sent.
      02-21-2015, 12:01 AM   #1168
OuKEnFoLdMX
OuKEnFoLdMX's Avatar
Mexico
26
Drives: BMW F15
thanks for coding opasha you are the men, bmw guru, it was disable right?
      02-21-2015, 12:04 AM   #1169
opasha
opasha's Avatar
1329
Anytime. Yes, since you have either a Euro or 2015 vehicle, seat belt chimes/gongs for front passenger (Beifahrer) coding is all disabled from factory (default).
      02-22-2015, 12:37 AM   #1170
opasha
opasha's Avatar
1329
delete
      02-22-2015, 01:06 AM   #1171
opasha
opasha's Avatar
1329
delete
      02-22-2015, 04:47 AM   #1172
opasha
opasha's Avatar
1329
If anyone with US LED headlights is free, PM me. I want to test something new. It may fix the anti-glare high beams.
Here is the coding I want you to test if you know how to do it on your own:
1) Remove 5AP and 8S4 from your FA
2) VO Code BDC_Body, Kafas2, LHM2 (both folders), TMS_03 (both folders)
3) Right click HU_NBT and fdl code the following:
HU_NBT / HIGH_BEAM_ASSISTANT / change to aktiv
4) Right click BDC_Body and fdl code the following so your auto high beam assist and glare free activate quicker:
BDC_Body / C_HBA_ENA_V_HI / default value = 46 (43 mph) change this to 2C (27 mph) - this is the speed when the HBA enables
BDC_Body / C_HBA_ENA_V_LO / default value = 3C (37 mph) change this to 1C (17 mph)- this is the speed when HBA disables
5) If the above doesn't make it work, add this final step: Right Click LHM2 (both of them) and fdl code the following:
LHM2 / M14 / change init_US_F015 to init_ECE_F015
LHM2 / M15 / change init_US_F015 to init_ECE_F015
      02-22-2015, 10:11 AM   #1173
@opasha, let me see if I can try them today.
PM for Everyday DEALS!!
      02-22-2015, 04:32 PM   #1174
opasha
opasha's Avatar
1329
You can also try making the HBA HI to 00 (so that it may enable from start) and HBA LO to FF (so that it stays on always). I'm not sure, but maybe 1 button push will keep it on for good then this way? Who knows? I just posted the lower speeds as a starting point. Thanks for testing, buddy.
      02-22-2015, 05:08 PM   #1175
Coded them already. Now waiting to get dark over here.
      02-22-2015, 10:39 PM   #1176
Trojanlaw
Trojanlaw's Avatar
Drives: 2019 X5 40i M
2019 BMW X5  [0.00]
Any results?
      02-22-2015, 11:38 PM   #1177
Originally Posted by Trojanlaw View Post
Any results?
On speed went down to 30mph, and Off speed went down to 20mph.
It is a bit hard for me to find out, too much traffic around here.
But, that number should be correct.
As far as tunneling, still not happening. Only on or off individually each headlight, instead of together both headlight.
      02-23-2015, 01:57 AM   #1178
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
I have these in my notes from a while back....not sure if worthwhile:
C_HBA_ENA_V_LO werte=18 (15 MPH)
C_HBA_ENA_V_HI werte=28 (25 MPH)
      02-23-2015, 08:57 AM   #1179
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
Omar has my files. The default for my MY2015 is on at 25 mph and off at 20 mph.
2019 X5 X40iM
      02-23-2015, 11:09 AM   #1180
Trojanlaw
Trojanlaw's Avatar
2019 BMW X5  [0.00]
What do you mean on or off for each headlight individually?
2019 X5 X40iM
      02-23-2015, 02:04 PM   #1181
Instead of creating a tunnel on the oncoming traffic like the Euro version, it just turn off the driver side high beam and turn back on once the opposite traffic clears.
By default, it just turn off or on both headlamp during oncoming traffic.
      02-24-2015, 04:38 PM   #1182
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
Originally Posted by skalberti View Post
@opasha I've always thought that maybe BMW put 1 or 2 codes elsewhere in another ECU that was the final piece to the puzzle. I've thought about VO coding all the ECU's except the DME, but didn't have the guts to do it
Well for the record, I've VO Coded my whole ECU before by mistake in the beginning last year and the only issue that came up was a CEL that was later cleared via ESYS (I know the CEL came from DME only and nothing else - this was also when I had the improper install of the RaceChip from my mechanic). Trojanlaw said he is happy to test this stuff again with me tonight. There are codes that turn off the high beam at certain speeds. So for the issue with auto high beam assist not coming on until 25mph - I will look for it to see if it can be lowered. The testing parameters behind the anti-glare are really annoying because of having to go "55mph or above" to see it work supposedly. That doesn't make sense to me, and I need to find that parameter. As you said, BMW likes to now throw a lot of random stuff all over the place (Easter Egg Coding) to make coding more tedious/difficult.
My HBA starts at 40 mph on both of my cars. It's set that way from the factory. How is yours set at 55 mph? Also there needs to be little ambient light to test. It was designed for use outside the city.
It's good to be bad
      02-24-2015, 04:44 PM   #1183
opasha
opasha's Avatar
1329
That was incorrect info on my part when discussing with Trojanlaw - I think that info came from anther foreign forum or something . The activation of HBA is either around 40mph for 2014 F15s or 25mph for 2015 models. Remember, I don't have LED lighting package, so I could never test anything myself.
      02-24-2015, 04:47 PM   #1184
skalberti
skalberti's Avatar
Well I saw on the other forums you saw where the euro and U.S. Headlights are different. Did you ever figure out if it's coding or hardware?
It's good to be bad
      02-24-2015, 05:04 PM   #1185
opasha
opasha's Avatar
1329
As far as our recent tests have shown, it still seems to be a hardware difference.
      02-25-2015, 08:38 PM   #1186
AHCPAX5
Drives: 2017 BMW X5 50i M Sport
Sorry to go off topic from anti-glare but on a similar topic regarding lighting. I tried searching old posts and cannot find any discussion on possibility to code the US based F15 rear tailights to light up the "panic light" everytime you brake, whether normal or hard braking. In other words, light up the "rear fogs" everytime we brake. Ive seen a few f15 hard brake in front of me and with those add'l lights, it gives car a overall better appearance especially if you have a signal light flashing. This way, there can be a dedicated "brake light" and "signal light".
      02-25-2015, 09:58 PM   #1187
hyde
hyde's Avatar
Drives: 2024 X3m40i
Originally Posted by opasha View Post
Yep, searched "warn" and "blink" and nothing like that in BDC_Body, unless they decided to be sneaky and throw it somewhere where it is not supposed to be, lol.
Hi Opasha
Before I ask in other forums about this, just wanted to know if you already reached out to anyone about this option? I really would love to have this.
      02-25-2015, 09:59 PM   #1188
opasha
opasha's Avatar
1329
Sorry, this type of coding is strictly for Euro vehicles and cannot be enabled on US vehicles. Doing so results in many errors/issues. If you want still want to attempt it, you can go through the hassle of ordering all Euro parts (wiring and lighting); I caution you ahead of time, it is not easy.
