View Poll Results: I#ve got screwed ... | |||
Replace it | 12 | 23.08% | |
Repair it | 40 | 76.92% | |
Voters: 52. You may not vote on this poll |
03-09-2015, 08:55 PM | #2 |
Rep 517
Drives: 2024 XM Label
LOL. Sadly - just replace it. Not worth the risk with these tires, plus the repair would likely give out when you're miles from a tire shop.
03-09-2015, 09:01 PM | #4 |
116
Rep 381
Repair it. I've repaired 2 on my e90 when they as <1000 miles and they lasted the life of the tire. If it were closer to the edge I wouldn't, but that looks fine.
03-09-2015, 09:11 PM | #6 |
Rep 3,990
http://www.bimmerfest.com/forums/sho...d.php?t=318060
I'm not sure, since it punctured the inner tread rather than the thick outer tread. I don't see any creasing, which is indication of a problem/bad tire if creasing is present. I would ask a good tire shop. The Delinte D8s I have are not marketed as RFTs but they are (not really sure how/why they are marketed as such); I got a thick deformed nail on the very outer tread about 3" to the right of your location in the rear right tire about 8 months ago. It was patched by my local tire shop that had installed my 22s. The tire has not lost air or had any issues whatsoever since then. It only cost me $20.
03-09-2015, 09:19 PM | #7 |
Rep 247
Drives: 2015 F15 50i, 2016 E89 35is
Have them do the internal patch where they drill out/clean out the hole and put a rubber plug that is attached to a patch that stays internal. It wears at the same rate as the tire and since yours is not on the tread I doubt you will ever have an issue.
It wouldn't hurt the run-flat capability of the tire either. Worse case is it doesn't hold air and you spend $20 to patch it. But if it does hold that is $400 you save. |
03-09-2015, 09:23 PM | #8 |
Rep 1,886
Repair Kit link.
You can buy the basic plugs from any auto parts store. I would try DIY, if it does not hold, then patch at tire shop. If you do the DIY plug, make sure you are fully inflated first as it easier to pull the screw out when there is a lot of pressure inside the tire. Have the plug ready, and insert, twist, pull out, cut out excess with any plier/cutter. |
03-09-2015, 10:33 PM | #10 |
Rep 18,716
Repair it. Don't buy that manufacturer telling you to not repair it a RFT.
If the damage is not on the sidewall, you are good to patch. It is not like you are going to go 100mph+ everyday with that tire where the inner threads of the tire will start falling apart. By the time you do 100mph+ for the x time, you may got pulled over already and spending money for the ticket and spend time in the jail while your car being towed, that's if you didn't hurt anyone.
03-09-2015, 11:41 PM | #11 | |
Rep 7,063
03-10-2015, 01:17 AM | #13 |
Rep 1,181
Repair. The worse that can happen is the tire can no longer hold air. Replace it if that happens. The RFT nature of the tire is not catastrophically damaged. The whole premise of a RFT is to be able to ride with little to no air on an extremely rigid carcass. One little repaired screw hole isn't gonna compare to the stresses of running with no air like it was designed to do.
03-10-2015, 01:19 AM | #14 | |
83
Rep 346
My rule of thumb with RFTs is simple: if the screw is anywhere near the sidewall and has been exposed to the road (i.e. pressure applied) for a long period of time after the "puncture" - just replace the RFT. Otherwise - patch it properly. |
03-10-2015, 03:31 AM | #16 |
Rep 1,067
Drives: 2017 M3 ZCP / 2017 RRS SC
This depends. It is in the center of the tread so that is good. How large was the penetration? Was it large or "just the tip"? Did you drive many miles w/ low tire message or did you take care of this right away. If you put some miles on the tire w/ low pressure, were you on the highway or in town?
These are all factors. I have plugged and patched(I do both at the same time) dozen's of tires with no issues or concerns. If you were driving on the autobahn then I would consider replacing. The reason why most shops will not patch a runflat is because running on very low or empty tire will destroy the "runflat" capability. Most drivers have no clue and the shop will not take the risk. My shop repairs my runflats because they know I pay attention to my air pressures. He I have 5 sets of rims and tires for my 2 cars(summer x2, winter x2, track set) and they know I pay attention. Q You will not have any issues if the puncture was addressed in a timely manner and you did not abuse the tire during the process.
17 M3 ZCP -- 2017 Range Rover Sport SC --RIP-- 12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500 |
03-10-2015, 05:27 AM | #17 |
Rep 1,417
As others stated if integrity of rubber is ok ( did not drive long at fast speeds) & not side wall, then repairable.
I had nail similar spot near dealer, BMW repaired it for $120 with warning: Repair tire is per customer request, no guarantee,& not liable for any damages incurred by failure. They cleaned the inside area, with grinder, patch. Tire was 2 years old so did not have to consider replacing in pairs. I would have went to my tire guy but he was closed on Saturday at 4pm. |
03-10-2015, 06:05 AM | #18 |
Rep 1,448
I have repaired RFs before with no issue after several 1000s of miles. Location is always the key issue.
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired R360c + EL, V1G2 + V1Driver, Uniden R8 |
03-10-2015, 06:15 AM | #19 |
Rep 30
I had a Michelin Pilot Super Sport tyre screwed in almost the same spot as yours. $20 to get it plugged and drove 40,000km without any issue before it worn out.
03-10-2015, 08:59 AM | #20 |
Rep 8,815
Patch it....its fine. The only time you can't/shouldn't repair any tire is if its too close to the sidewall where the flexing would cause the patch to fail.
Alan
03-10-2015, 10:13 AM | #21 |
Rep 1,772
Repair.
Unless your ran the tire on very low or zero pressure, repair it... the puncture doesn't appear to be close enough to the sidewall/shoulder of the tire. I fixed multiple RFT with DIY plug from the autoparts stores and the repairs always lasted. |
03-17-2015, 10:57 AM | #22 | |
Serving the masses since 75
36
Rep 36
