      02-02-2015, 04:05 PM   #23
retx
Drives: '18 F15 40e
Originally Posted by MattBianco View Post
wjbender ramsal Baunton I think it is safe to say that with a careful foot, open road, EcoPro, and cruise control (except on downhills I tap the brake to let EcoPro coast the car), one can beat the stated US MPG of 31 with the 30d/35d. Would you agree?
mrboon beats it with a 40d!
MattBianco,
What's the right process to coast the car? I thought, in the good conditions, the car is able to "automatically" coast itself under the Active Cruise Control.
      02-02-2015, 04:11 PM   #24
wjbender
wjbender's Avatar
Drives: 2022 X5 40i M Sport
This was on Maryland 301 and I-95 North from California MD to New Jersey. The last leg of my 1200 mile trip. Mostly open highway, frequent stops to stretch my legs, and potty. Engine was not past the break-in miles so I took it easy on the accelerator. Yes I was in Eco Pro mode.
      02-02-2015, 04:12 PM   #25
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
Originally Posted by retx View Post
MattBianco,
ACC maintains speed, so if you are on a downhill, it will brake. I tap my brakes on top of the hill while on EcoPro and ACC. Cruise deactivates, and EcoPro allows coasting. When my speed is gradually reduced to about my prior cruise setting, I reengage cruise.
      02-02-2015, 05:11 PM   #26
retx
Drives: '18 F15 40e
I got to figure this out in the next trip. Thanks.
It seems I'm still confused with the whole concept. I thought I already engaged the "coasting" during my short trip yesterday.
I took the short trip with the mixed local and highway outsides NYC. I was using eco pro, and activated ACC when on the highway.
Duration - 2:22h
Distance - 87 miles
Consumpt - 24.8 mpg
Speed - 38.0 mph
The distance in Highway is about 50 miles, and I used the Active Cruise Control in the speed range of 55-70 mph from the beginning to the end.
Since mine is still in break-in (less than 200 total miles), I bet its MPG can be better.
Based on my understanding, the owner manual indicated
"Coasting is a component of the ECO PRO..."
"Coasting is automatically activated when ECO PRO mode is called via the Driving Dynamics Control."
"The function is available in a certain speed range"."
"In ECO PRO mode, this function is available in a speed range from approximately 30 MPH/50kmh to 100 MPH/160kmh, if the following conditions are satisfied:
1. Accelerator pedal and brake pedal are not operated.
2. The selector levers is in transmission position D.
3. Engine and transmission are at operating temperature.
So isn't this feature is able to combine ACC and ECO PRO together, and the computer can automatically calculate the conditions and factors and make the car coast by itself without we physically touch it!?
      02-02-2015, 05:20 PM   #27
MattBianco
MattBianco's Avatar
Good point , but I'd say no. The aim of ACC is to maintain speed and reduce as necessary. Coasting increases speed. When in "N" via EcoPro coasting, even in gentle slopes, I have seen my speed go from 60mph to 75mph very quickly.
      02-04-2015, 08:33 AM   #28
retx
Drives: '18 F15 40e
Thanks. The ACC does conflict with "coasting" since ACC is to maintain the speed and coasting is to let it go!
If I set the ACC as 55 MPH, then accelerated to 70 MPH, and released the pedal, the car speed was slowly going down to 55 and wasn't coasting.
If I turned off ACC and stayed in ECO PRO, once I released the pedal in 70 MPH, the coasting mode was engaged almost right away and my instant MPG reading turned to 99+.
I guess this makes sense now why this F15 can achieve such high MPG during the "tests". And this car seems to gain more mileages in ECO PRO rather than in the cruise control.
Thanks for all the helps here.
      02-04-2015, 09:09 AM   #29
delviacv2
delviacv2's Avatar
Drives: 2014 X5 50i & 2015 535d
this is not as good as you guys got but compaired to my 2011 X5 35d that the most I can get is 24mpg on the same trip, this is awesome
2015 535d Xdrive Sophisto Grey Metallic
-DUDMD Stage 1
-xHP Transmission Flash
2014 X5 50i Carbon Black/ M Sport
-BM3 Stage 1
      02-04-2015, 10:02 AM   #30
wjbender
wjbender's Avatar
It's a good feeling to see that mpg creep up as you drive on a longer trip. I just completed 1200 miles on my way back from Greenville, SC - Hilton Head, NJ. On the trip from Greenville to Hilton Head (~240 mi) all I could get was about 31 mpg. After I got more miles on the clock the mpg seemed to improve. On the last leg of the trip from California Maryland (about 240 miles), to NJ I was able to easily get 35.6 mpg. From what I observed as the engine gets broken in the mpg improves.
      02-04-2015, 10:03 AM   #31
delviacv2
delviacv2's Avatar
Great, I have less than 500 on mine
-DUDMD Stage 1
-BM3 Stage 1
      02-04-2015, 10:14 AM   #32
Luxembourg
Luxembourg's Avatar
Luxembourg
119
Drives: F15 M-Sport 30d
Engine: 30d (US: 35d)
Mode: EcoPro data only
Negative / Positive Factors:
- usually fully loaded on long trips. Example: 4 adults + 2 kids in the baby-seats (3rd row) + roof box for approx 3000km (1800mi) through France and Spain.
- light foot on long trips due to: kids and "vacation spirit" and crazy number of speed-cameras all over EU these days (France the worse...)
- I try to use EcoPro only on long stretches. For cold start-off, fast driving, city-cruising I avoid the EcoPro as much as possible...
- depending on the country the average long-trip speeds: 100-110km/h (70mph) (F, L, ES, B, NL, etc), and around 150-160km/h (100mph) (DE, PL)
Data gathered with EcoPro analyser (iOS) during the first 20.000km (12K miles) of my car. Between May 1, 14 and Feb 1, 15
Average of all 74 trips recorded:
US MPG: 33.23
Imperial MPG: 27.67
L/100k: 8.5
the best starting at:
US MPG: 45.65
Imperial MPG: 37.94
L/100k: 6.2
the worst (usually on very short few-km trips, cold engine) around:
US MPG: 23.54
Imperial MPG: 19.6
L/100k: 12
      02-04-2015, 10:21 AM   #33
jlstyle
jlstyle's Avatar
355
Drives: Porsche Panamera
2014 Audi S7  [0.00]
2015 BMW X5  [0.00]
I guess I'm the only sucker.
I'm getting average of 10~12mpg on my 3.5i mostly local driving.
3rd tank so far.
Highest I got was about 18~20mpg when I did 70% highway.
      02-04-2015, 10:38 AM   #34
MattBianco
MattBianco's Avatar
I'm getting average of 10~12mpg on my 3.5i mostly local driving. 3rd tank so far. Highest I got was about 18~20mpg when I did 70% highway.
Gas vs diesel. Is car broken in? Are you enjoying thrilling acceleration? A/C? EcoPro? We have not seen posted pics but many 35i owners have reported 26-28 mpg for highway. Also, looks like after break-in, you do better.
- I try to use EcoPro only on long stretches. For cold start-off, fast driving, city-cruising I avoid the EcoPro as much as possible........
Impressive data. Your best is at US 38.5mpg! And, your overall which includes stops, traffic and city driving at US 27.7mpg is unbelievable.
It's a good feeling to see that mpg creep up... completed 1200 miles ...31 mpg. After I got more miles on the clock the mpg seemed to improve. On the last leg .... 35.6 mpg.
Seems to be what we are hearing from everyone, that after break-in MPG improves.
You have higher avg. speed. than the other comps. Also, be mindful my results were affected by net downhill.
      02-04-2015, 02:59 PM   #35
ramsal
Drives: 2017 X5 & 2018 M3
Matt, I would agree that with some effort you can likely reach if not beat the stated consumption. But to me that would defeat the benefit of having this vehicle. I hit my above consumption coming back from my kids' ski lesson with a fair bit of downhill and almost unrealistic foot control on the highway. My everyday driving includes the sport mode (for fun) and comes nowhere near my numbers above, I get on average 14.5L/100km in the winter.
      02-04-2015, 04:03 PM   #36
wjbender
wjbender's Avatar
Just a general FYI - Diesels almost always beat the advertised MPG, Gasoline (petrol) engines almost always under perform.
      02-04-2015, 11:42 PM   #37
Baunton
Baunton's Avatar
England
320
Drives: X5 45e 2021
wjbender sorry have to disagree with your statement about diesels almost always beating advertised MPG. I have never ever managed to get close to the claimed MPG. I don't drive with my foot glued to the floor nor do a Boy Racer from the lights. In all the BMW diesels I have owned over the lifetime of the car it's always been a good 5 MPG down on the claimed Combined Cycle.
      02-05-2015, 04:36 AM   #38
lapa
Sweden
150
Drives: BMW X5 M sport 40d 2017
+1
      02-05-2015, 03:30 PM   #39
wjbender
wjbender's Avatar
Originally Posted by lapa View Post
+1
Here is a link to an article describing 5 diesel vehicles that routinely exceed the EPA mpg rating. My own experience with my X35d confirms this as well.
http://www.greencarreports.com/news/...ileage-ratings
      02-05-2015, 04:22 PM   #40
MattBianco
MattBianco's Avatar
This conversation is suffering from basis risk.
You can't compare. You are looking at US MPG. The same car sold in the UK is advertised to achieve 47.9 Imperial (GSQ) mpg, which is US 39.9mpg. No one in this forum has achieved that so far, not with my downhill, not eqseric with a lower avg speed matching my mpg. I could totally understand Baunton 's comment. My guess is the laws are less stringent in the UK and BMW (and other makers), post the maximum achievable, as the disclosed mpg. But you are also right, we are seeing US 31mpg for highway easily beat here. And, as discussed in your article link.
image from UK configurator:
US Disclosed MPG:
Owner impressions, from the survey in my footnote:
      02-06-2015, 11:33 AM   #41
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
United Kingdom
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
Anyone driven the X5 M50D and what was the economy of it , thanks
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      02-06-2015, 12:54 PM   #42
coolmex200
Germany
117
Drives: F80 M3, 2016 X5 35i, F25d
Short trip to horse back riding lessons....combined hills, highway, windy, and flat terrain...had it on ECO. Also, have a MaxChip tune installed.
      02-06-2015, 02:13 PM   #43
MattBianco
MattBianco's Avatar
Unless that is UK MPG (imperial), and not US, you just beat everyone. And, if that is US MPG, then something to be said about your driving style and MaxChip! Wow.
Which of these Maxchips do you have? https://maxchip.de/en/catalog/catego...0038&xtyp=8321
You should do a review of the chip as that is not one that is well known here in the US.
      02-06-2015, 02:39 PM   #44
kip1
Drives: X5M50d
My M50d with 5000km overall city + subub mileage is 9.8-10.1 l/100 km = about 24 MPG! Very rarely highway driving.
