07-23-2015, 08:28 PM | #1 |
#dubspec
6337
Rep 5,201
Installed Spectrum LED turn signal and fogs
very happy with both color and brightness. however the car does send pulses to the bulbs randomly testing for bulb out. basically the turn signals and led fogs flash once every few minutes extremely fast. its almost impossible to notice looking at the car but the signal flash exists. i am going to try and find someone who can code this for me.
signal caught flashing
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
07-23-2015, 09:40 PM | #3 |
#dubspec
6337
Rep 5,201
Yes. No errors with either bulbs. Extemely easy to swap as well
07-23-2015, 10:11 PM | #4 |
170
Rep 386
I have the Weisslicht LED turn signals from bimmian. I also had the flickering, but with coding it goes away. I still do not understand why LED's are an upgrade, at least for turn signals.
07-24-2015, 11:37 AM | #6 |
#dubspec
6337
Rep 5,201
Yes. They don't flicker but send a pulse every few minutes. Unless u stare at the lights for 3 minutes straight you will not notice it. I am coding it regardless, just need to find someone who can do it for me locally
07-29-2015, 09:00 PM | #7 |
#dubspec
6337
Rep 5,201
what exactly did u code? im not familiar with bmw coding
07-29-2015, 10:21 PM | #8 |
Rep 222
From the Cheat Sheet and Instructions on this thread:
BMW Coding Thread Stop flickering of custom led FRONT TURN SIGNAL bulbs BDC_BODY FRA_V_L_KALTUEBERWACHUNG aktiv nicht_aktiv BDC_BODY FRA_V_L_WARMUEBERWACHUNG aktiv nicht_aktiv BDC_BODY FRA_V_L_IS_LED nicht_aktiv aktiv BDC_BODY FRA_V_R_KALTUEBERWACHUNG aktiv nicht_aktiv BDC_BODY FRA_V_R_WARMUEBERWACHUNG aktiv nicht_aktiv BDC_BODY FRA_V_R_IS_LED nicht_aktiv aktiv Stop flickering of custom led REAR TURN SIGNAL bulbs BDC_BODY FRA_H_L_KALTUEBERWACHUNG aktiv nicht_aktiv BDC_BODY FRA_H_L_WARMUEBERWACHUNG aktiv nicht_aktiv BDC_BODY FRA_H_L_IS_LED nicht_aktiv aktiv BDC_BODY FRA_H_R_KALTUEBERWACHUNG aktiv nicht_aktiv BDC_BODY FRA_H_R_WARMUEBERWACHUNG aktiv nicht_aktiv BDC_BODY FRA_H_R_IS_LED nicht_aktiv aktiv Stop flickering of custom led FOG LIGHTS BDC_BODY NSW_L_KALTUEBERWACHUNG aktiv nicht_aktiv BDC_BODY NSW_L_WARMUEBERWACHUNG aktiv nicht_aktiv BDC_BODY NSW_L_KURZSCHLUSS aktiv nicht_aktiv BDC_BODY NSW_L_IS_LED nicht_aktiv aktiv BDC_BODY NSW_R_KALTUEBERWACHUNG aktiv nicht_aktiv BDC_BODY NSW_R_WARMUEBERWACHUNG aktiv nicht_aktiv |
07-30-2015, 08:54 AM | #10 |
Rep 102
09-21-2015, 03:01 PM | #13 |
#dubspec
6337
Rep 5,201
Here are some photos to help some of you remove the foglights. There is a metal clip that is located on the top portion above the lens that needs to be pressed down to unlock the housing. Once you get it to release just wiggle out the housing
09-21-2015, 10:40 PM | #16 | |
Rep 1,886
Cost accountants dictating specs, it seems.
09-22-2015, 07:11 AM | #17 |
#dubspec
6337
Rep 5,201
Hid headlights come with halogen fogs. Led fogs come with led package
09-22-2015, 08:17 AM | #18 | |
Rep 222
also, I saw a thread where a UK car with NIGHT VISION has LED Headlights and HALOGEN Fogs, I'm not sure if that is true for the rest of the world (so few people have ordered Night Vision) UK F16 with Night Vision . I do have an extra set of LED fogs available .... $85 + $20 Priority Mail to Canada. . Last edited by wearenh; 09-22-2015 at 08:24 AM.. |
09-22-2015, 10:42 AM | #19 | |
Rep 174
To swap these one needs to remove the front bumper, and I am not sure if it's a simple bolt on or there's some work to be done in there. |
09-22-2015, 10:45 AM | #20 |
#dubspec
6337
Rep 5,201
definitely some coding involved. the bulbs literally cost me the same as what you are asking four entire housings and shipping haha.
09-22-2015, 01:05 PM | #21 | |
Rep 174
eBay link - http://goo.gl/y1s4cd |
09-22-2015, 03:55 PM | #22 |
#dubspec
6337
Rep 5,201
Yes I realize u can get ebay cheap ones. Some good some are crap and burn out in days or weeks. These are lifetime warranty and headache free. No cases of them burning out so far.
