      01-30-2016, 05:26 PM   #287
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
TortugaX5 PM Sent. Very bizarre. I recommend the USB be formatted as FAT32. Almost all are unless you have formatted it differently yourself.
Also, VIN input should produce and target the correct file to download.
I don't recall if in the past I unbundled the file or just let iDrive unzip it itself.
      01-30-2016, 06:19 PM   #288
TortugaX5
Drives: 2016 F15 X5 X35i
So after a few PM exchanges with MattBianco, we were able to determine the problem with my install was actually due to my X5 firmware being more current than what bmw.com/update was allowing me to download. My X5 is running the latest firmware (MN-003-003-01, TN-003-003-01)
I will post back with details if I experience issues again.
      02-01-2016, 07:31 AM   #289
TallTrees
TallTrees's Avatar
Drives: 2014 X5 35d M Sport
I tried the update also, same result. I'm on TN-003-003-01 also. Thanks for the tip TortugaX5
      02-03-2016, 01:35 PM   #290
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
527
Drives: 2020 Mineral White 30d MSport
Originally Posted by ramsal View Post
~10,000km
1. !! vibrations at 90-100km/h !!- currently worked on by the dealer but no solution or diagnosis so far
2. creaking from tailgate which apparently was fixed by dealer using new latch parts but I haven't yet confirmed.
3. knocking in the right front shock - entire shock needs to be replaced, currently awaiting parts
4. sunroof grinding noise - rubber seal replaced by dealer
5. car would not shut off a couple of times but issue seems to have resolved itself
6. Hatch would not close itself at low (-10 C) temperature. After 10th attempt finally closed. Dealer looked and could not find any problems.
I see you had issues (#3) with knocking in one of your front shocks, my car is just 1000miles old and has this bad, very bad knocking coming from the front of the car (engine bay), my dealer says it comes from a bad calibrated valve that controls the rigidity of the engine mounts (via an electric frequency or something like it.....)
They "fixed" the valve settings and the problem still there, nothing new and the knocking is like anything happened, I'm not sure, I'm not a mechanic but the sound comes more from the front suspension and only when I drive in very bad shape streets, can't replicate the sound on a regular street...
Is the same problem you experienced? did your dealer fix the problem?
Any feedback will be appreciated!
....Life is too short to drive boring cars
      02-17-2016, 01:14 PM   #291
QYN
Drives: 2016 X5 special edition
I am so "Lucky"
Watch the mileage....I cannot believe this is a brand new car...
      02-17-2016, 03:16 PM   #292
yvnrg1981
Drives: 2019 M5
How many of those miles are yours?
      02-17-2016, 03:32 PM   #293
QYN
I drove it from dealer center from 22 miles. And it is about 35 miles from dealer center to my home.
      02-17-2016, 03:37 PM   #294
kanvas
kanvas's Avatar
Drives: V8
He said brand new car, so must be all under his ownership. Unless it was a "new" demo car with some mileage already in it. But what could possibly go wrong in such a low mileage vehicle?
2014 X5 xDrive50i
      02-17-2016, 03:38 PM   #295
kanvas
kanvas's Avatar
Drives: V8
Have you tried inflating tires to proper PSI and resetting TPMS? I had proper inflation on all tires and once got low tire pressure warning. It went away a couple days later. Really dumb.
2014 X5 xDrive50i
      02-17-2016, 04:37 PM   #296
Gilly1964
Drives: F15 30d MSport
Just maybe, the nail in his rear right tyre (or tire if you prefer) doesn't know it was a new car?
      02-17-2016, 07:24 PM   #297
QYN
Yes, I tried.It does not go away. The other three tires are ok. But the rear right one drops 6 PSI per day. Just send the car to the service center to check, waiting for the inspection result...
      02-17-2016, 08:10 PM   #298
Doanster
Doanster's Avatar
627
If there's no nail in the tyre, it most likely is an improperly seated/torqued-down TPMS valve stem. PITA since it's your new car, but not the end of the world. You'll be back on the road in no time.
      02-18-2016, 10:57 AM   #299
QYN
It is the problem of valve . They replaced it...cannot believe this can happen.
      02-18-2016, 11:24 AM   #300
Doanster
Doanster's Avatar
627
Very nice! Like I said, bad timing, but one under/over torquing event and a leak can happen. Glad you're back to good.
      02-19-2016, 06:12 AM   #301
alphaod
alphaod's Avatar
A buddy of mine's car right front drops 2-3 psi every day and he's been filling it up for months. Finally he's annoyed and take it in; turns out hairline crack on the rim. So thank goodness yours was only a valve.
      02-22-2016, 10:15 PM   #302
GeorgeR
Drives: 2016 X6 XDrve35i 2009 335i E92
As we pulled the new X6 into the garage for the first time, noticed a number of scratches on the interior poplar wood trim. May not have noticed in the daylight glare but the fluorescent lights made the scratches easy to see.
Before taking delivery of the car we asked the dealer not to wash the exterior as we were taking it directly to a detailer to have CQuartz Finest applied.
While I was worried about the dealer scratching the paint, I never imagined the wood trim would be scratched on a brand new car.
My wife takes it in Thursday to show them but what can they do? I suppose they could replace the trim but I’ve never seen things go back the same way once removed and replaced.
The dealer has been great to work with so far so I am optimistic they will find a resolution but come on!
If regular joes like us know how to carefully wash and clean a car, you think a dealers detail shop could routinely clean cars that easily exceed $100K without damage.
      02-23-2016, 01:51 PM   #303
bjcarls
Drives: 22 Tahoe, 22 R1S, 23 Z07
Just got a call from the dealer for an ECU update, weird that they want me to come in just for this at 2,500 miles. Anyone know what it's for?
      02-23-2016, 04:14 PM   #304
ixlr8
Drives: 2016 X5 35i
The more I use the nav system in my 2016 X5, the more I dislike it. Main issue is lack of POI, or terribly outdated POI. I did a search for a store today, it showed me the location that they moved out of 7 years ago!!! Nice up to date maps!! My wife works at a home improvement store chain, they have 10 stores. The one she works at has been in existence for 20 years... it is not in the list. I think I am going to buy a $100 Garmin.. it works much better and has most all POI's. Sad that NAV system in a $60K vehicle can be beaten by a $100 unit.
      02-23-2016, 04:17 PM   #305
Taran.J
Taran.J's Avatar
Drives: BMW, LEX, MBZ, RAM, TESLA
Park sensors error none of them are working.
      02-23-2016, 04:29 PM   #306
ptt
Drives: M5
Blind spot detection does not always work. Sensitivity needs to be turned up?
      02-24-2016, 05:15 PM   #307
ramsal
Drives: 2017 X5 & 2018 M3
~10,000km
They had to replace the entire strut as they could not isolate the problem. The replacement fixed the issue for me.
2018 M3
2017 X5 35d xdrive Msport
Sold: 2014 X5 35i xdrive Msport
      03-06-2016, 02:14 AM   #308
pragueX5
pragueX5's Avatar
Czech_Republic
157
Drives: 2021 X5 M 40d mildhybrid
driver side window high oitch wind leake noise at higher highway speeds, should not be there. its like whistle........ noticed quiet a few popel have this without a cure, must be design flaw. ideas? nite its a brand new car, checked all the sealing and rubbers, seems all fine and aligned
