01-28-2015, 03:02 PM | #1 |
Rep 1,746
Low Washer Fluid warning even with full tank
I am not getting any washer fluid from the rear, not to mention I get Low Washer Fluid error on dash. I drained the previous washer fluid that was in there, and filled it up with a gallon of new stuff, but while it is spraying and cleaning fine on windshield, I am getting nothing on rear window.
Thread title edited, the reason it's not spraying in the back is because of Low Washer warning, despite having near full tank of fluid.
01-28-2015, 03:10 PM | #2 |
Rep 18,716
Have you tried to run it for a bit longer?
Maybe there is some air in the line since you just drained the tank.
01-28-2015, 04:20 PM | #3 |
Rep 1,746
Will try again, I ran it for a while but I was afraid of overheating the pump.
01-28-2015, 04:38 PM | #4 |
Rep 1,886
New stuff is the anti freeze variety, I presume. Very strange.
01-28-2015, 07:59 PM | #5 | |
Rep 1,746
Upon return to vehicle right when I started up, I held the sprayer and it sprayed, no problem, no sputter or anything, I thought it finally got to rear washer.. but then suddenly it stopped and I got the Low Washer warning again. So obviously there is a problem somewhere. When I held the sprayer down, it is not making any noise that I can hear, as if It stops spraying because it thinks there is no fluid in the reservoir. I think the pump is not pumping because it doesn't want to pump dry. We are all sure there is only one tank, right? There is something wrong with it definitely.
01-28-2015, 11:19 PM | #6 |
Rep 18,716
hyde , sounds like there is a leak to the rear sprayer.
Did you see a puddle under the car after doing that?
01-28-2015, 11:34 PM | #7 |
Rep 1,886
"All washer nozzles are supplied from one reservoir." pg 78.
Perhaps what @r33 said. |
01-29-2015, 07:59 AM | #8 |
Rep 450
I think the rear washed stops working when the low washer fluid warning comes on. Had it on mine recently with nothing frozen and as soon as the low washer fluid warning came on the rear washer stopped working. Couldn't even hear the pump running so it wasn't air in the line.
Went to wash the front window and it worked fine so it sounds like it must be deliberately like that. |
01-29-2015, 08:29 AM | #9 |
Rep 11,843
Drives: MY24 G01 AW Msport
i use the rainx orange and from time to time its freezes.. this morning front windshield i was able to spray but not the rear..
01-29-2015, 09:21 AM | #10 | |
Rep 1,886
That stinky BMW fluid is good for something! Try methyl alcohol in the washer. About 1/4 to 1/5t ratio. Pour only and only when engine is cold. |
01-29-2015, 09:32 AM | #11 |
Rep 213
If the low fluid light is on, then the rear will not work. I added more and started working. You'll be surprised how much it takes. I think I added almost two gallons.
01-29-2015, 10:10 AM | #12 | |
Rep 11,843
01-29-2015, 10:49 AM | #13 |
Rep 80
01-29-2015, 11:04 AM | #14 | |
Rep 1,886
01-29-2015, 11:21 AM | #15 |
Rep 11,843
Hyde
you should try using the rear spray now..if it doesnt work then theres a problem. I checked mine and it work so the line def froze. its 25deg |
01-29-2015, 11:44 AM | #16 | |||
Rep 1,746
01-29-2015, 11:46 AM | #17 | |
Rep 1,746
01-29-2015, 12:05 PM | #18 |
Rep 1,417
Hyde Wrote:
This sounds like the reason, but I don't understand how could it still be low after adding a whole gallon of stuff.. For my X3 the reservoir has an air hole at the top. When I parked on a steep incline, it would leak out on passenger side between door and qtr panel. But there was still plenty of fluid remaining. As R33 said maybe puddle/leak |
01-29-2015, 02:57 PM | #19 |
Rep 1,746
I missed this sorry. I'll have to try again. You mean leak when I try to spray the rear?
01-29-2015, 03:09 PM | #20 |
Rep 18,716
Well, if you have a puddle under the car, that's mean there is a leak or damaged hose in that area.
01-29-2015, 07:11 PM | #21 |
Rep 1,746
There is no puddle, I dumped nearly another gallon into the reservoir filled up to right below cap.
It's still spraying normally in the back right after engine start, and immediately stops when I get the low washer warning. No pump noise or anything. Will report back after driving tomorrow.
01-29-2015, 08:43 PM | #22 |
Rep 18,716
hyde , maybe NPickles is right. Once the warning is on, the rear washer will stop spraying. It could be a safety reason also, since you will need the front windshield to be clean more than the rear glass.
