      02-08-2022, 09:15 AM   #1
secretariat
Drives: 2016 X5M
Cost of replacing rear air suspension bags
Like the title reads, has anyone gone to BMW to have this done? Can you tell me the cost? Thanks
      02-08-2022, 09:31 AM   #2
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
Probably about $1500 at BMW.
      02-08-2022, 09:40 AM   #3
9vapors
Drives: CB X5M
So to first answer the question, you're looking at about $1300 (or more) at the dealer if they do both, which they're sure to push.
HOWEVER…
I grabbed two Arnott bags and did it myself. It took maybe 45 mins total for a network engineer who has never done it before to get it done. Since they tend to fail around the same time it's suggested by the dealer to do them at the same time.
This is a pretty good video and shows the small issues that arise. Like he did, use the jack to get the airbag snapped in.
640ijims195.50
musa547.50
      02-08-2022, 10:15 AM   #4
secretariat
Drives: 2016 X5M
Thanks guys
      02-18-2022, 11:41 AM   #5
SharpieX5M
SharpieX5M's Avatar
Drives: 335D
I Just did mine and Napa Auto had them 10% off, got both Arnott bags for $540 cnd. And ya takes like 45mins a side, not hard at all.
      02-18-2022, 01:52 PM   #6
Infamous039
Infamous039's Avatar
Drives: 2015 X5 Xdrive35i M-Sport
Yes definitely look into to completing this repair yourself, I did mine in about 45min-1hr and it was pretty simple and easy install. There's YouTube videos available for guidance.
BMW F06 M6 GC (Fun Ride)
BMW F15 M-Sport 35iXDrive (Family Ride)
BMW F48 X1 (Wife's Ride)
96 Camry (Daily Ride)
      02-18-2022, 08:07 PM   #7
Housekeeping
Drives: 2013 BMW M5
That jackstand placement was sketchy..
musa547.50
      02-18-2022, 11:32 PM   #8
musa
musa's Avatar
Drives: F86, E92, E53, E39.
Place the jack stands underneath the provided rear jack stand points (rear left and rear right). Also, don't stick your head underneath the vehicle like what he did with only the floor jack supporting the vehicle.
      02-26-2022, 03:04 PM   #9
Handcontrol
Drives: X5 M
2011 335/E93  [0.00]
2016 X5M  [0.00]
Backorder
Getting suspension bags replaced at 48k miles under my extended warranty.
Dealer has had my truck for 10 days, said the parts are on backorder from Germany. So i've had a brand new M340 xdrive as my loaner, so no complaints here. I will say I had no idea how fast this car is, it's shockingly fast off the line, but alas it's also pretty boring to drive.
      04-16-2022, 02:07 AM   #10
Cpove
Drives: 2014 camaro z/28 2017 BMW x5m
Is the correct part number from arnott A-2642? They are the same bags that come with the x50i correct?
      04-16-2022, 04:26 PM   #11
SharpieX5M
SharpieX5M's Avatar
Drives: 335D
Yes
      12-31-2022, 11:25 PM   #12
Beamerx5f15
Drives: BMW x5 f15
So mine just went bad the rear of my x5 is sagging and I’m between bilstein rear air bags or OEM from bmw? Has anyone before changed them and notice ride quality Difference? I personally think OEM is the best choice although I’m hearing good review on bilstein OE made in Germany
      01-02-2023, 05:01 PM   #13
LOW4LYF
LOW4LYF's Avatar
2298
Drives: E92 M3 & F85 X5M
Do you have a link for the Bilstein?
      01-02-2023, 05:38 PM   #14
yasavguy
Drives: '17 BMW X5M
So the process as well as part #s are identical for X5 & X5M?
      01-05-2023, 03:24 AM   #15
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
when i look this up in FCP euro it shows e70/71 fitment
      01-08-2023, 09:15 AM   #16
///Motivated
Drives: F85, F80, F25, G01
Just did mine yesterday. Can confirm the A2642 fit correctly. $275 shipped from RockAuto if you can find a 5% discount code.
      01-09-2023, 11:41 AM   #17
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i / X7 M50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
OEM is not the best choice hence why they failed on you. Replaced with Arnott (or bilstein, doubt its any different) like everyone is talking about.
'07 Yamaha R1 (sold)/'05 C230k (sold)/
'06 C55 AMG (sold)/'14 X5 50i (Dad’s now)
'20 M5
'21 X7 M50i DSE (Wife's)
      01-09-2023, 12:00 PM   #18
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
and buy from FCP euro so you have a lifetime warranty on the parts.
      12-16-2023, 12:29 PM   #19
BDO
Drives: 2016 X6 40d M-sport
How long are these supposed to last? I had mine changed (both sides) 25000 miles ago, and one side is sagging again (now on 75000 miles). Definitely not the pump, as it will level over after a couple of minutes, but then sag overnight.
First time replacement was OEM, this time I will definitely go aftermarket.
      12-17-2023, 09:23 AM   #20
pachieh
Drives: '17 X5M
My OEM lasted 50k (original ones too). Have Arnott on now for nearly 30k with zero issues.
For the OP… like others have said, very easy to do. Longest part was undoing the passenger side under panel cover and unscrewing the air compressor line. Just make sure you retighten the line at the compressor after both bags are installed. Oh, and remove the fuse for the air compressor first too.
Eisenmann Pro, Dinan Intake, BM3 Stage 1, XHP Stage 3
21" Vossen VFS-1 on Michelin PSS
