06-15-2023, 12:48 PM | #1 |
Rep 612
Lifted F15 Success!
I've had quite a few folks between the forums and bookface ask about the lift, so I thought I'd toss up a thread about it.
Is this the first lifted F15? Maybe! Might be some shops somewhere that have fabricated lifts for specific applications. I now have roughly 5k miles on this setup with zero issues. I have rear air, so I went with the ECS Tuning 1.5" lift kit for the E70. This was the only kit I could find that was listed as available that stated it was for both rear air and rear spring. I realize there are a couple companies that make 3 inch lifts for the E70, but none of their websites had an order button. With that said, I can not speak for the Ebay kits and wether or not they will work. They visually look to have a smaller center bore on the front spacers, which will cause issues when installing. You'll see why later on. Now, on to the good stuff. Everything bolted right in MINUS the front spacers. The F15 front strut top-hat has a lip thats 3.070" in diamter, and the center bore for the spacers is 3.000" in diameter. What I had to do was bevel out the spacer to clear the lip (see photos). It has been mentioned that you may be able to swap for E70 strut top-hats, but I can not confirm if they fit the F15 shock stem. Things to note** - F15 and E70 share the same rear air strut. No need to worry about fitment or air lines. - When installing the front you will need to remove the top-hat from the strut. Make sure you mark the spring in relation to the strut so you can reinstall in exactly the same spot. The top-hat bolts are not symmetrical and will only fit one direction, and if your spring gets clocked around even the slightest bit it makes reinstall a real pain. Ask me how I know... - It's not easy to press the suspension down to get the front struts back in place after the lift is installed. Get creative, but be mindful that you don't pull your axle joints apart, and if you do make sure you get them back in place. - The front spacer strut mount studs are a tad shorter than I would like to see. They engage all threads, but just. I may pull them out and install longer studs. They are pressed in. - The ECS kit will likely come with incorrect hardware for the rear spacers. I received M8 bolts, but it requires M10. This is not an issue with F15 vs E70 as the E70 uses the same M10 bolt and others have reported the same issue. I reached out to ECS and they didn't seem too concerned, they just offered to refund what new hardware costs. Double check your hardware before starting the install. Front top hat lip Lip diameter Spacer center bore diameter Spacer beveled out to fit the lip. I wish I would have jst turned this in a lathe, but was short on time. Fronts installed. Rear bag spacer installed Lift installed with factory wheels. The rear raised slightly more than the front. I'm not sure why, maybe teh rear air sensor arms are a different length between the years, but I like the slightly higher rear anyways, especially since I tow a lot. After wheels and tires are installed. Hooked up to the trailer with matching ride height, wheels and tires. Now, since everyone always asks, wheels and tires... I am running: 265/60R18 Falken Wildpeak AT3/W 18x8 +18 Drag DR79 20mm rear spacers 265/60 is the most common off-road tire size on the X5, which comes out to 30.5 inches tall. You MUST be at a minimum +20 offset to clear the front upper ball joint, but I recommend lower. If you run a wider tire or a taller tire you'll need to be around +10 minimum offset. With a 265/60 I have light rubbing on the front side of the front inner fenders at full lock. I had to trim the drivers side inner fender because the vents in the liner would catch the tire tread. Also, when searching for wheels keep in mind you need to pay attention to center bore and weight ratings, especially if you often have a full vehicle or tow a lot. Wheels need to be rated at minimum 1700lbs to meet GVWR specs. Most "tuner" aftermarket wheels do not have high enough weight ratings for our vehicle. Alright, that's it for now. I'll update as needed!
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread |
8
Monkeypoop39.00 zero2sixtyZ954.00 shimmy232363.50 Longboarder3437.00 crystalworks521.50 cfm56d7b5950.00 Vivek.1367.50 PGH_X562.50 |
06-15-2023, 07:05 PM | #2 |
F15 daddymobile
2364
Rep 3,537
nicely done and thanks for sharing! have you considered modifying OEM or adding additional yellow fog lights?
06-16-2023, 07:19 AM | #3 |
Rep 612
I have yellow film on the OEM fogs. I don't like the OEM placement though. I am ordering a overlanding basket today that I'll have a light bar on
06-16-2023, 08:52 PM | #4 |
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Nice work. Curious how the lifted X5 performs against other SUVs you have used for offroading and towing.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
06-17-2023, 11:02 AM | #5 | |
Rep 612
I dont suspect any issues towing offroad. Its not a crazy lift and retains all factory components, and rear air really helps keep things level and stable.
06-30-2023, 09:24 AM | #9 |
Rep 5,025
Looks great!
Yeah, the rear is higher bc you applied the same height spacer to a lever arm that’s farther away from the wheel. So, higher lift at the wheel. |
07-19-2023, 09:02 AM | #11 |
Rep 269
Great thread! Your F15 looks awesome with the beefy tires.
Couple questions: Any concerns or issues with CV/axle durability due to the increased operating angle? Have you done any research on the "F15" kits? They're about half the cost of the E70 kit you used. https://www.ebay.com/itm/16616011017...MaAlmEEALw_wcB I am running a 265/60/18 Hankook on Style 93s and could benefit from the increased ground clearance due to heavy snow here in WNY. Also thinking of throwing on some small fender flares as the 93s poke out a bit due to the use of a spacer to adapt from 74.1 to 72.56.
07-19-2023, 11:44 AM | #12 |
Rep 818
Drives: BMW X5 XDrive35i
Great stuff man, love to see it!
///d1837.50 |
07-19-2023, 12:08 PM | #13 | |
Rep 612
As stated in my original post, the ECS kit was the only one that specifically stated it worked with air suspension.
